Like Tree7Likes
Old 12-09-2007, 08:47 AM   #2236
Osiris 75's Avatar
Trader Rating: 17 (100%+)
I am getting so frustrated with stripping my second gears, it's starting to get ridiculous. I tighten the screws down so hard, but it still doesn't help. I have a perfect mesh according to everyone, but they still strip. it seems as though my last option is to try longer screws.
SPONSORS: AWESOMATIX USA / HOBBYWING USA / AVID CONCEPTS / R1 WURKS / POWERMASTER FUELS (VP RACING) / 2MM DESIGNS
RC TARGET/CAPRICORN USA / REFLEX RACING / ULTI TIRES
Chris Kemper
Osiris 75 is offline   Reply With Quote
Old 12-09-2007, 09:20 AM   #2237
ssc-rc's Avatar
I've seen, and done for that matter,where people have tighten the bottom screws and forget to tighten the top screws that hold the motor to the mount.
ssc-rc is offline   Reply With Quote
Old 12-09-2007, 09:25 AM   #2238
rmdhawaii's Avatar
Stripping 2nd gear? Hmmm.... Just some ideas...
Check your clutch bell and 2-speed shaft bearings. Make sure your 2-speed shaft isn't bent. Are the clutch bell gears worn at all? Have you replaced them since you got the car? How are your engine front/rear bearing?
rmdhawaii is offline   Reply With Quote
Old 12-09-2007, 09:51 AM   #2239
asw7576's Avatar
I haven't ( touch wood ) get into stripping gears situation since 2004. Only one time with my MTX3 and I solved it once for all ever since. One of my solution was using longer screws everywhere to make rear & front bulkheads stronger and stiff.
I would check these for your case :
Remove first spur gear to see the gear mesh on the second spur gear. Are you sure you have proper gear mesh after removing the first spur gear now ? ---> 1T bigger on the 2nd pinion gear might help.
Make sure the clutchbell doesn't wobble ---> check clutchbell's bearings and thrust bearing.
It's time to replace rear bulkheads with new one.
Old 12-09-2007, 09:58 AM   #2240
Osiris 75's Avatar
Thanks, I'll give it a try.
Chris Kemper
Old 12-09-2007, 10:31 AM   #2241
BigPapa's Avatar
Thumbs up xraynt1 1.2.3.3.4
i would like to say thanks to the guys teamxray James Burrows. Mark Harrison
Art Jensen,great run mark also thanks to one of the xray guys for the stearing block, and for the support from the team drivers. I had a bad weekend due to the motor issues, but still had fun! Mark you were the one to beat, great showing for the xray (A)1.2.3.4 This track is fun, fast flowing track. congratulations all the winners and thanks everyone that came out. tampa:tir e: SSpeedway LR
BigPapa is offline   Reply With Quote
Old 12-10-2007, 11:08 PM   #2242
hi guys,
can someone give me a run down on the difference between running a 25T and 26T side pulley?
what effect does it have on overall ratio? should you use 25T or 26T for long tracks?
what else does it effect?
implusepro is offline   Reply With Quote
Old 12-11-2007, 03:21 AM   #2243
Originally Posted by implusepro View Post
hi guys,
2t = less drive to the front, therefore more taily feel. 25t = more front drive so a more planted feel. i'd go with a 26t on a long track, but it also depends ont he traction, and how you like the car to feel. 26t may give you understeer.
woops wrong way around...fixed now
TomB is offline   Reply With Quote
Old 12-11-2007, 03:34 AM   #2244
asw7576's Avatar
26T = 1 : 1 = front and rear rotate equally
25T = 1.04 : 1 = front tires rotate 4% faster than rear.
Old 12-11-2007, 03:55 AM   #2245
If you're running Rubber Tyres use 26T whatever the size of track.
jonrg is offline   Reply With Quote
Old 12-11-2007, 05:01 AM   #2246
M7H
M7H's Avatar
Originally Posted by TomB View Post
25t = less drive to the front, therefore more taily feel. 26t = more front drive so a more planted feel.
You guys are really helpfull....
You both stated exactly the opposite....
TomB, read your post again....
M7H is offline   Reply With Quote
Old 12-11-2007, 03:24 PM   #2247
Send a message via ICQ to _cyclops_
Originally Posted by grub View Post
gidday
can anyone advice me how to get traction to the rear as after 20 minutes i have gone from 62.5 mm 40 shore foam rear tyres to 100 shore hard plastic and other guys still have plenty of tyre left, i have been told than my cars is consantly spinning out of the corners,, it did seem slow out of the corners but i throught it was my clutch running 100k frount diff oil 60 rear with pink springs 33lb please help grub
How does your rear end feel? Is is solid or is it loose?
you also can use 42sh in rear!
_cyclops_ is offline   Reply With Quote
Old 12-11-2007, 03:27 PM   #2248
hi guys,
http://www.teamxray.com/teamxray/sho...p?file_id=3580
Go with 25T. So with 25T you would need smaller tires in front to have the same rollout on all tires. I use 2mm smaller tires in front with 25T.
I think 26T is for ruber tires, since they don't wear... in general the rear tires wear faster and if you end up with smaller rear tires the car goes really weird...
Old 12-11-2007, 08:17 PM   #2249
rocca30's Avatar
i had this issue also , check your bearings on your clutch bell. the small bearing was the problem for mine replaced it working perfect now.
RC AMERICA / / HUDY // SRC / / JC JEWELERS/ / GOT GOLD // MAXX POWER // EXTREME RACING FUEL //
rocca30 is offline   Reply With Quote
Old 12-11-2007, 09:55 PM   #2250
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
I am pretty sure I saw this answered somewhere, but do any modifications need to be made to get a Novarossi 12-3SCT into the NT1?
I am not too keen on dremeling a $500 brand new engine
Do any after market engine mounts fix this problem?
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
