STS engines
Old 08-10-2006 | 02:49 PM
  #2401
Originally Posted by charlesd
Quick question: what's the difference between the d3r and the d3rb ?
Also, where do you get a dx12?
D3rb? Where did you retrieve that number?
You can get the D12x from: http://www.pro-hobby.net/
sook is offline
Old 08-10-2006 | 04:54 PM
  #2402
charlesd's Avatar
I saw it at Dinball rc mart and listed on ebay.
http://www.rcmart.com/catalog/defaul...ath=421_38_925
From the info, i can't see anything different apart from maybe the crank. One has info, the other does not.
charlesd is offline
Old 08-10-2006 | 05:14 PM
  #2403
Artificial-I's Avatar
I dont know why they have D3RB , that is #1023 , which is D3R ROAR/IFMAR Legal 3 port. 5.5mm carb , 7.5mm crankshaft.
Artificial-I is offline
Old 08-11-2006 | 05:57 AM
  #2404
Tabushi's Avatar
Anyone here can tell me the differences in performance between the STS .21B engine and the STS .21E engine ?
thanks a lot,
Tabushi is offline
Old 08-11-2006 | 06:40 PM
  #2405
jfc_tech's Avatar
technically im not sure, but performance wise, totally lots of different. the punch & acceleration is sometimes too much too handle.... if u get used to the 21B & switch to the 21T. its like u have to set the throttle to 80% to manage yer buggy.
jfc_tech is offline
Old 08-13-2006 | 03:26 PM
  #2406
BringItOn's Avatar
one thing i notice about the sts 21b is the carb ball that links to the servo is a bit smaller than standard novas and rb's. and risks popping off mroe easily. mine popped off during the race.
BringItOn is offline
Old 08-13-2006 | 03:59 PM
  #2407
Your STS engine should have come with a rod end that fits your sts carb perfect. If you dont have this in your box let me know and Ill send you the piece. I have a few that I never used from my own motors.
Old 08-14-2006 | 01:54 AM
  #2408
BringItOn's Avatar
thanks AI... how much to send it to sydney au?
Old 08-14-2006 | 03:36 AM
  #2409
Send me a pm with your name and address. Ill send it for free.
Old 08-14-2006 | 09:02 AM
  #2410
charlesd's Avatar
I had my first race with my d3r this weekend. End result, i'm happy with my purchase. To be quite honest, at first i was dissapointed because the engine seemed to have no top end at all. I followed recommendations of gearing up on my mongoose. I changed my stock gearing from 19 to 20 teeth and 24 to 25 on second.
Even with this change on sunday morning, i thought the car was slow. I was alone on the track and my acceleration out of the corners was good. Just as good as my RB V12. On the top end, i just could'nt feel it, the car felt to easy.
Then the fast guys got on the track for practice ( 710 with zx 12's- and good drivers). I thought they would blow past me on the straight. To my surprise i kept up with them, no one had the speed to pass me and the gap between me as lead car never diminished. The back straight is 225 feet long.
I guess the power band is so smooth and since this motor revs lower, i had the impression that i had no top end.
Time wise, i had one of my fastest laps this season.
charlesd is offline
Old 08-15-2006 | 10:56 AM
  #2411
Tabushi's Avatar
Im just asking because im about to go BB on my Monster Truck and i was thinking on the .21B engine, but if the performance its not much difference with the .21E, i would get the E version ...
any opinion ?
thanks,
Tabushi is offline
Old 08-15-2006 | 09:47 PM
  #2412
skengines's Avatar
Will be purchasing a D3R Modified from pro-hobby very soon.
I was wondering what plug choice is recommened for this engine? I have been hearing that O.S. plugs are both good and bad, and only used Nova based plugs.
All this has really got me confused on which plug to use with best results.
What pipe is recommened for this engine?
skengines is offline
Old 08-16-2006 | 01:02 AM
  #2413
jfc_tech's Avatar
any opinion ?
thanks,
ooopsss... sorry, i though u were asking between .21B & .21T.
my friend said, the fuel economy the most visible fact. the rest is just almost the same. but this on buggy.
jfc_tech is offline
Old 08-16-2006 | 06:17 AM
  #2414
Skyline VR12 Plus is a great current pipe. Works with a large range of motors , has a nice powerband throughout the rev range, (good high-end good low-end)..which is hard to find. It has the best finish ive seen , its durable and it has a great price.
I ran it on my D3R last weekend with great results. Ill be sticking with this pipe for awhile and durability wise itll be sticking with me. Last 2 pipes I ran dented the pipe the first race. This one made it through without even the slightest ding.
Os will leak , nova wont. I personally dont like os plugs cause Ive heard the wire filament when broken off can cause damage to the motor while a nova/rb plug will disintigrate causing no damage.
Old 08-16-2006 | 08:17 AM
  #2415
skengines's Avatar
what nitro percentage do you guys use? Is there any shim I need to remove with the D3R?
