Old 10-10-2007, 09:29 PM   #2551
rcabj's Avatar
Default STS .12 ENGINE( RED HEAT SINK)
HI GUYS...just sharing
yesterday a guy with this engine sts ( red heat sink) had this problem where the engine would stall each time put full throttle almost in the middle of the long straight( exact same place every time). it was still new just pass brekin in i was told.
he uses skyline pipe, 25% nitro, with stock shimiing i think 0.5. / i didn't check what plug
anyway i tried to help tune it....but for almost 2 hours it still the same...the best we could do was going 3-5 laps than it stall.
we also try reducing and adding 0.1 shims but still to no avail.
** the engine was always easy to starts and idle's well ...temp were somewhere around 100celcius.
somehow i feel pretty bad couldn't help him get the motor running ...
i hope it is tuning issues or a matter of bad plug...i did not try to lean it to much coz i might mess up his new motor.
but i notice that this motor reaches high rpm very fast.....
p/s : anybody knows what base needle setting for it..thanks
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 10-11-2007, 05:03 PM   #2552
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
check for air leaks if there is any one the has a nova carb try it, it could have a bad o ring. try 4-4 1/2 bottom 3 1/2- 4 top thats what mine liked but mine was a modded team engine
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 10-11-2007, 06:47 PM   #2553
CurveTracer's Avatar
First double check the settings like 20 Smoke listed in the previous post.
Second you said that the engine revs very quickly, my D3R does not like overgearing, it needs big gears and a good flowing pipe. He could be overgearing the engine and be running too rich on the LSN. How is the acceleration from a dead stop after a 5-10 second wait?
"Yellow Jacket" Mugen MTX-6, Picco Torque
TeamNITRO RC Club, Lynwood, Illinois
CurveTracer is offline   Reply With Quote
Old 10-15-2007, 09:29 PM   #2554
rcabj's Avatar
thanks
it accelerated well it seems...anyway i haven't meet up with the guy yet, i'll try to give feedback what was the problem once i get in touch with him....thanks guys.
p/s : just for you guys info's once i had the same problem (with my TZ) but was resolve by adding shims.
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
Old 10-16-2007, 08:46 AM   #2555
jameslow's Avatar
Default STS d12ex
hi guys, i have some problems with my sts d12ex engine and need some advice!
when i throttle for the first 1/2, the engine is running smooth, but once i goes to full throttle, the engine speed remains and the exhaust song become very rough (sound like there are bubble in the exhaust) im using JPL pipes, 25% fuel and OS P6 plug. I would say most of the time i can see quite a lot of smoke coming out the exhaust. I did try to lean the high end but seem like no changes to the speed but temp increase.
Any ideas what going on? hehe! Thanks a lot!
jameslow is offline   Reply With Quote
Old 10-16-2007, 12:30 PM   #2556
Default Tuning
Unfortunately I don't know the base settings. In fact I don't usually carry them with me to the track or parking lot. But this is what I do to get in the ball park.
Empty all excess fuel out of the engine, remove glow plug, motor engine, remove air cleaner turn car upside down etc.
Remove the air cleaner, open the carb 60% open. Adjust the LSN until it is at the tip of the spray bar. This setting will usually get you an initial adjustment on the LSN.
Start with the HSN flush and start the car up. If it doesn't start lean it 1/2 turn and attempt to start it again. Do this until the engine starts.
Adjust idle and begin HSN adjustments while running the car on the track.
Next begin LSN tuning, but keep it in small increments. If this is a new engine you should not have to continually adjust the LSN, and if you stay with the same fuel, only small amounts after break in completion.
Old 10-16-2007, 08:55 PM   #2557
rccobra705's Avatar
Originally Posted by charlesd View Post
rccobra705 -- how do you like your sts d12ex?
Don't know what too say. The last month I have think many time to buy a other engine and that will not be an STS. I think that say all.
Regards
rccobra705 is offline   Reply With Quote
Old 10-17-2007, 05:45 PM   #2558
20 SMOKE's Avatar
jameslow, it could be a timing issue betwen the fuel and plug combo
Jamie W
Old 10-17-2007, 05:53 PM   #2559
1. The head button is set up for Nova Rossi type glow plugs, Some racers have bee successful using the OS plugs others have found them to leak. I have always used RB or Nova Rossi plugs. Ensure that your glow plug is sealing correctly.
2. Sounds like your mixture is overly rich. I bet your LSN is too rich. Reset the LSN and HSN to factory settings.
Old 10-17-2007, 06:09 PM   #2560
20 SMOKE's Avatar
i forgot i used one os in my sts and went to nova plugs
Jamie W
Old 10-18-2007, 03:15 AM   #2561
jameslow's Avatar
ok thanks a lot. i just got myself a new novarossis plug. but haven try running it. btw can i know which plug number did u guys usually use? the one i buy is G05tf (not very sure need to go back and check again) what is the different between the short body and the long body? i read from the novarossis thread, some say the short body is a cold plug while the long body is the hot plug....while some said it the other way.....so im very confuse now! lolz!
Old 10-18-2007, 02:17 PM   #2562
20 SMOKE's Avatar
http://www.novarossi.com/products/glowplugs/index.html
Jamie W
Old 10-24-2007, 07:16 PM   #2563
Kemorc's Avatar
Send a message via AIM to Kemorc Send a message via MSN to Kemorc
The suggested setting to start with is:
.12
High Speed needle -- 4 turns out from the end
Low Speed needle -- 4 turns out from the end
Mid Range needle -- Flush with the housing
Idle -- 0.5mm open
I've got gas, and I'm PROUD of it... 1/5th scalers unite!
Kemorc is offline   Reply With Quote
Old 10-25-2007, 03:25 AM   #2564
Bundy_Bear's Avatar
G'Day
I just a got a new STS D3R from RcMart. It looks like it now has the D5R larger size head on it. Also the carby now has insert in it... Should start to run it in this weekend
BB
Bundy_Bear is offline   Reply With Quote
Old 11-14-2007, 08:30 PM   #2565
Kemorc's Avatar
I think they did that to get to IFMAR legal
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
