Motor Testing and Comparisons >
Like Tree533Likes
Old 08-26-2025 | 04:01 PM
  #391
OffRoadJunkie's Avatar
Originally Posted by Roelof
With a price limit they sell you a motor and you can buy the faster rotor afterwards......
I think the ROAR did see that while doing tests in the field. On my club there was also a guy who did rewinding motors. By rounding the edges, using a much thinner isolation and a tight hand winding he ended up with a much shorter wire lowering the resistance. And keep in mind the purity of the copper also plays a role.
That's what bugs me about the factory select/factory certified motors. for a few dollars more, these companies can order the torquier rotor, but they choose to offer it as a pricey upgrade. Heck, Surpass was selling their motors for less than $100 and the rotors were stronger than $150 motors.
There are also guys who rewind their motors with 15.5 turns instead of 17.5 turns while using a thicker wire.
OffRoadJunkie is offline
Old 08-26-2025 | 04:10 PM
  #392
Team EAM
Originally Posted by biz77
Why did we have the motor-of-the-month scenario here in the States prior to ROAR implementing the blanket minimum IR rule?
Because Florida people are weird. I am sure it wasnt needed and it was monkey see monkey do so to speak.
Originally Posted by jdearhart
How often will a company be able to have a motor approved? Once a year, twice a year or more?
. They can get a motor approved anytime they want BUT do you realize the cost to design a motor, retool for the stator, can, endbell, etc, buy the min from the factory so they will make it and then the cost involved getting it approved by not only roar but efra and ifmar (every two years)? To do that cost several several thousand dollars. They need to sell motors an average of 1.5 years to even break even on the initial cost! So I dont see this being an issue anymore than it already was.
I see you joined in 2020. Were you involved in the hobby, specifically the racing portion of it, pre-2018 before ROAR implemented the blanket minimum IR rule for spec motors?
Who do you think lobbied ROAR to get rid of the blanket minimum IR rule and why did they do it?
. If you think it was a motor manufacture it was NOT. It was me that brought the idea to ROAR. Being IFMAR president and trying to get world wide rules on the same page this was a step. ROAR was the last one using different rules. Some areas of FEMCA or japan use different winde motors but they are slowly swtiching to Blinky speedo classes with same rules everyone else has.
EA
jdearhart and OffRoadJunkie like this.
EAMotorsports is offline
Old 08-26-2025 | 04:20 PM
  #393
STLNLST's Avatar
The way they get around set prices is by calling “Tuning” a service…..aka “LABOR” therefore they come under or right at said cap and the Gold/Certified/Team edition/or whatever the $180 motor is currently called still has its place. Its been done before and those of use that been in the hobby for a while already know whats coming.
OffRoadJunkie likes this.
STLNLST is offline
Old 08-26-2025 | 04:22 PM
  #394
gigaplex's Avatar
Originally Posted by OffRoadJunkie
I don't believe motor manufacturers will be updating motors more than once a year. The only company I have see change a motor in less than a year was Hobbywing and Trinity. Fantom changed the Helix after a year, but most will wait at least 2-3 years before dropping a new motor design. It costs a lot of money to change them out too fast, but if people are willing to drop over $150 on a motor, then I guess yearly motor designs will be a thing. However, motors are not like RC cars. There is only so much you can do to a motor to make it better. You can drop internal resistance to ridiculous levels, but then your talking about using rare metals and a $500 motor.
With motors reaching $200, I wouldn't doubt ROAR coming out with a maximum motor price, just like the brushed motor stock class, way back in the day. However, there are $120 motors that will keep up with a $180 motor.
What motor are you referring to with Hobbywing?
And ROAR already had a $150 limit that they never enforced when Trinity exceeded it.
STLNLST and OffRoadJunkie like this.
gigaplex is online now
Old 08-26-2025 | 04:23 PM
  #395
gigaplex's Avatar
"8.4.2.1 All motors used in ROAR competition must be on the list of approved brushless motors posted on the ROAR website. Instructions and requirements for submitting motors for approval can be found on the ROAR website. Motor approvals shall be valid for 4 years from date of approval. Manufacturers can renew an approval for motors still in production for no additional fee or inspection for an additional 4 years."
And again, new motors may be submitted at any time. This means if company A has the lowest IR and resulting "fastest" motor out in the field and company B comes along and gets a lower IR and "faster" motor approved, company A can then immediately submit a newer, lower-IR motor to keep up with or perform better than company B's motor. Company C then comes along and drops a motor that out does both company A and Company B's motors and you can see how the cycle of the next got-to-have fastest spec motor goes.
There's a lot more to a motor than just IR.
Old 08-26-2025 | 08:42 PM
  #396
I realize that, but it’s one spec that tends to be lower on faster motors of the same wind. I believe inductance plays as big or bigger role in performance. Nonetheless, if you have manufacturer’s constantly putting out the new “fast” motor, you’ll have racers buying it. I hope EA is correct here and it doesn’t have the impact I fear it will.
biz77 is offline
Old 08-27-2025 | 10:02 AM
  #397
I was wrong. The G4 was release in April 2022 and the G4R was March 2024. I thought the G4 was 2023.
gigaplex likes this.
Old 08-27-2025 | 10:08 AM
  #398
Inductance, IR, rotor strength, rotor diameter, rotor length, stator diameter, and stator length all have pretty much an equal importance to the performance of a motor. If the balance isn't right, you will get a motor that will overheat within the first two laps. I've jacked around with different rotors and cans and received all types of different data. When I crated an extremely fast a torquey and fast motor, it turned out to run extremely hot.
Old 08-27-2025 | 10:11 AM
  #399
The biggest problem with removing the IR regulation is not being able to tell if someone has tampered with the windings of a motor. You will have racers come out with a custom wound 15.5 in a 17.5 race and/or a 11.5 in a 13.5 race.
Old 08-27-2025 | 10:52 AM
  #400
Team EAM
The value of the motors will be recorded when inspected at ROAR. This number will then be posted on ROAR's site for each motor so that tracks and large races will know exactly what was submitted and legal. If its below that then its illegal. There is no variance. What is posted is the min resistance at 77F for that motor. If the motor is at a different temp there is a chart for copper resistance versus temp as its a direct correlation.
So it should be even easier for people to tech now than before.
EA
Old 08-27-2025 | 11:40 AM
  #401
Not sure how it would make tech easier. Instead of having a universal minimum IR for a given wind of motor, the tech official must now look up the minimum IR for each motor they tech. Instead of needing to know four different minimum IRs (one each for 25.5, 21.5, 17.5 and 13.5 motors) you'll need access to the minimum IR for 139 different motors (the current number of approved 25.5, 21.5, 17.5 and 13.5 turn motors) and this list will grow as manufacturers submit new motors as we get closer to the September 2026 switchover. In addition to that, in many cases there are multiple versions of the same brand and wind motor. For example ORCA has three different approved versions of the Blitreme3 25.5 motor with three different minimum IR's.
biz77 is offline
Old 08-27-2025 | 12:29 PM
  #402
jdearhart's Avatar
EA
I'm keeping my fingers crossed that you're correct, EA!
jdearhart is offline
Old 08-27-2025 | 12:44 PM
  #403
Mac The Knife's Avatar
When was the last time you had a motor teched? and what was the circumstances behind it?
For club racing, it won't matter. Trophy races? Maybe. Roar regional races and the worlds races, then it would matter, and it's on the Roar officials.
Otherwise, your just whinging just to whinge.
Mac The Knife is offline
Old 08-27-2025 | 02:26 PM
  #404
Yes, we do travel to regional races. Planning on going to on road carpet Nats in March. Not sure what "whingeing" is.
hunterdawg likes this.
biz77 is offline
Old 08-27-2025 | 02:36 PM
  #405
A dictionary, or Google can answer that for you.
Buckland and gigaplex like this.
