Like Tree352Likes
NOVAROSSI Engine thread....
Old 05-13-2021 | 11:07 AM
  #10876
Never had issues switching brand plugs on an engine. Only Novarossi plugs will not be totally tightened in other brand engines but even then it is easy to make them fit (I recently did once on a Picco).
Somewhere in an old topic on this forum a guy could measure the taper angle on several plugs using an electronic magnifier and the tapers were just a few degrees different.
bratan likes this.
Roelof is offline
Old 05-13-2021 | 05:48 PM
  #10877
Originally Posted by ray4624
the claim is that the taper is different and once you seat the p3 you wont seat the novarossi ever again
i THINK the tgh is the older version of the CT0 series
My god 🙆‍♂️
What about protek t5 medium?
I won't go with p3 cause it's ultra hot plug. Probably not gonna work for me.
bratan is offline
Old 05-13-2021 | 06:04 PM
  #10878
Tnx, and what about this hot/cold plug thing, am I right with going medium/cold for 80+ degrees weather?
bratan is offline
Old 05-14-2021 | 06:10 AM
  #10879
kgombe's Avatar
all my Novarossi engines we ran the number 5 plug regardless of weather.. you should be fine..
kgombe is offline
Old 05-14-2021 | 06:17 AM
  #10880
nitro_mt_racer's Avatar
My god 🙆‍♂️
My guess is that plug heat ranges are like lipo c ratings, there's no standard. If a p3 and a ct06 are the standard plugs for their respective engines then my guess would be they are probably the same heat range. Only way to know is check your burn pattern.
nitro_mt_racer is offline
Old 05-14-2021 | 03:36 PM
  #10881
Appreciate your help guys, will post here what I've found to work for me.
bratan is offline
Old 05-14-2021 | 04:29 PM
  #10882
It can be tricky knowing what advice to follow. I had similar questions regarding switching from nova plugs, here is a video by RWMODS which might help explain.
bratan likes this.
cornonthecob is offline
Old 05-15-2021 | 01:34 AM
  #10883
fyrstormer's Avatar
What purpose is served by the little holes below the exhaust port in this sleeve? They don't line-up with any cutouts in the crankcase; they're just little holes that lead nowhere. What are they for?
fyrstormer is offline
Old 05-15-2021 | 07:00 AM
  #10884
EBMods's Avatar
They help with sealing, cooling and lubrication on the piston. The piston face on the exhaust side gets hot, more so than the intake side.
petersen114 likes this.
EBMods is offline
Old 05-15-2021 | 08:46 AM
  #10885
What he did not mention is that this is a Picco sleeve and to my knowledge Picco havn't used such holes....
Roelof is offline
Old 05-16-2021 | 11:52 PM
  #10886
fyrstormer's Avatar
Yes, it is a Picco sleeve. I posted it here because Picco and Novarossi share a lot of design features, and this seemed like the fastest way to get an answer. Whatever the answer is, it should be applicable to any brand of engine, including Novarossi. I'm not sure why you say Picco doesn't use these holes when this the sleeve came from a brand-new Picco engine and it clearly has the holes.
Old 05-23-2021 | 04:24 PM
  #10887
Me again needing help🥲
finally started putting this thing together and I encountered a problem. When I tighten cluch bell it gets stuck, doesnt spin freely. Reason behind it is position of my flywhell. I will post coulpe of pics, basically my crankshaft is too short using this combination of motor, collet, flywheel and cluch bell
I have 2 collets actually but they position flywhell at the same place, and you can see it's not in the center.
Help me out good people.
bratan is offline
Old 05-23-2021 | 04:49 PM
  #10888
petersen114's Avatar
Is that a Losi clutch bell? Also what clutch is this? Kinda looks like a Protek or Serpent.
petersen114 is offline
Old 05-23-2021 | 05:58 PM
  #10889
kgombe's Avatar
you need something like this
https://www.amainhobbies.com/reds-lo...qu0018/p742396
kgombe is offline
Old 05-23-2021 | 06:07 PM
  #10890
finally started putting this thing together and I encountered a problem. When I tighten cluch bell it gets stuck, doesnt spin freely. Reason behind it is position of my flywhell. I will post coulpe of pics, basically my crankshaft is too short using this combination of motor, collet, flywheel and cluch bell. I have 2 collets actually but they position flywhell at the same place, and you can see it's not in the center.
Do you have the washer behind the collet? You need the short collet with the losi clutch.
