Like Tree352Likes
NOVAROSSI Engine thread....
Old 05-05-2021 | 07:30 AM
  #10846
So...I’ve always had some trouble running for idle with this motor and I realized now that it’s because I was setting idle with the restrictor in... set it without it and everything seems good now.
im almost through break in so hopefully I’ll get to do some tuning this weekend.
ray4624 is offline
Old 05-05-2021 | 07:32 AM
  #10847
nitro_mt_racer's Avatar
What did you set the idle gap at?
nitro_mt_racer is offline
Old 05-05-2021 | 11:10 AM
  #10848
The thickness of your Xacto blade (.5mm) or so.
Cardiak is offline
Old 05-05-2021 | 01:15 PM
  #10849
You set his gap?
Old 05-05-2021 | 04:13 PM
  #10850
.7mm
I have drill bits that are .5mm and .7mm I use to set the gap with
ray4624 is offline
Old 05-05-2021 | 06:21 PM
  #10851
Originally Posted by ray4624
.7mm
Did your Nova manual say that was the correct gap? Seems like .5-.55mm is more common.
Old 05-05-2021 | 07:23 PM
  #10852
wow going back it says .6mm. Idk where I read .7mm
ray4624 is offline
Old 05-05-2021 | 07:25 PM
  #10853
I've not dealt with any .28 engines so that's why I suggested checking the manual. .5-.55 is pretty common for .21 engines.
ray4624 likes this.
Old 05-05-2021 | 07:27 PM
  #10854
.7mm
I have learned that you should set the idle gap with the restrictor removed. That can make a difference. Hope this helps
nitro_mt_racer and ray4624 like this.
Micah78 is offline
Old 05-05-2021 | 09:28 PM
  #10855
Default Novarossi 28 Crankcase
Hi All, Does anyone have a clean Nova 28 crankcase (stripped and no bearings etc required) for sale? Preferably 7 or 8 port current generation. I race tether cars and plan to use one as a donor for a rear rotor project. Cheers, Scott
Scotto5000 is offline
Old 05-06-2021 | 02:00 AM
  #10856
I have learned to adjust the HSN and LSN to the max performance and adjust the idle to it.
Roelof is online now
Old 05-06-2021 | 02:31 AM
  #10857
At this point I just need it to get around the track haha. We’ll worry about performance when it counts.
I’ve got a couple more heat cycles for break in so I’ll try with a bit smaller idle gap and adjust accordingly.
ray4624 is offline
Old 05-06-2021 | 02:47 AM
  #10858
Also with a break in you adjust the needles to what you need to run rich and adjust the idle to it. For sure with a break in there is no way to hold on to a given idle gap, that will never work.
Old 05-06-2021 | 03:39 AM
  #10859
There’s a million ways to skin a cat.
token likes this.
Micah78 is offline
Old 05-06-2021 | 04:10 AM
  #10860
im not quite sure what you mean
the box settings have seemed to work for the break in heat cycles. looks/sounds rich and holds an idle decent
in general once its gone through heat cycles i should set high speed then low/idle?
nitro_mt_racer and token like this.
ray4624 is offline
