Tamiya TT02 Thread >
Tamiya TT02 Thread
Old 12-31-1969, 04:00 PM
Last edit by:
Print Wikipost
Like Tree1387Likes
Tamiya TT02 Thread
Last edit by:
Print Wikipost
Old 02-03-2020 | 09:34 AM
  #2296
Default TCS TT02
anyone racing in TCS this year with the TT02? do you mind sharing some setup?
raytay112 is offline
Old 02-04-2020 | 04:33 PM
  #2297
thirtydaZe's Avatar
subscribed
thirtydaZe is offline
Old 02-07-2020 | 08:20 PM
  #2298
proliteandsc's Avatar
Anyone know when Tamiya will start selling that Type-sr TT-02 and what they want for it?
proliteandsc is offline
Old 02-08-2020 | 02:56 AM
  #2299
Raman's Avatar
Should be out by late March / Early April
rippen likes this.
Raman is offline
Old 02-08-2020 | 03:49 AM
  #2300
Sorry im just not reading through al 154 pages but how is it to drive with the alu drift conversion kit? The one that adds alot of steering angle but makes it RWD. I meen without a gyro (which i consider cheating )
kickerzx is offline
Old 02-08-2020 | 12:06 PM
  #2301
fat500's Avatar
fat500 is offline
Old 02-08-2020 | 01:43 PM
  #2302
Looking to probably get a Type-S if the SR doesn't come out soon for VTA racing. Found a few upgrades and was wondering if anyone has any experience with them.
3Racing
TT02-03 steering system
TT02-08 graphite main shaft. Are ends steel or aluminum?
TT02-09 gear diff
Yeah Racing
TATT019BU rear adjustable suspension mount. Will this work with the Type-S arms?
TT02-015 universal joints
TT02-013BU motor mount
TT02-042BU steering set
TT02-014BU main drive shaft
TT02-016BU main shaft joints
Square
SQ-STD-442SPR 42mm axle
Wanted to know if anyone used any of these and their experience with them. Thanks
Old 02-08-2020 | 01:55 PM
  #2303
wtcc's Avatar
The 3racing gear diff is the best for this chassis. Just check the left right play after the first runs and shim if necessary. Also don’t use the bevel gear that comes with the diff!
The Yeah racing motor mount works fine.
Everything else would I buy from Tamiya, because the quality of Yeah- and 3Racing aluminium parts is questionable...
For the suspension go for Tamiya graphite arms and hubs. They will stiffen up the suspension and make the car a lot better. If possible not the 416 arms, because they will make the car even narrower. If your wallet allows it go for dcj in front.
wtcc is offline
Old 02-09-2020 | 02:00 AM
  #2304
CTE
By bevel gears on the 3 racing diff, do you mean the internal diff gears or the one on the end of the prop shaft? Do the tamiya gears fit inside the diff if it is these you are talking about? Been considering getting one of these diffs for my Type S.
CTE is offline
Old 02-09-2020 | 07:59 AM
  #2305
chucko's Avatar
I dont know about you all but I have an issue with the motor mounts by Yeah.......... seams when trying to tighten the top bolt it tightens the spear.... I have had to drill out the mount to get it to work right. is any one else having this issue ?
chucko is offline
Old 02-09-2020 | 09:48 PM
  #2306
Has anyone tried installing the TRF419 upgrade kit #54886 ? Tamiya said it will work on the Type-S.
nrtv20 likes this.
Old 02-10-2020 | 06:33 AM
  #2307
Hoyle33's Avatar
Hey all, I have a TT-02 roller with upgrades for sale. PM me if you're interested!
Might save some of you some $$$
Tamiya TT-02 Subaru roller
Hoyle33 is offline
Old 02-10-2020 | 07:18 AM
  #2308
So.. lets say you don't want to spend the $35 for the tamiya screw kit. Here's what you need to buy:
  • M3 x 8 Button - 8
  • M3 x 10 Button - 39
  • M3 x 12 Button - 7
  • M3 x 15 Button - 4
  • M3 x 18 Button - 2
  • M3 x 10 Flat - 7
Then Tamiya specific screws.
  • M3 x 18 Step - 2
  • M3 x 14 Step - 10
These are both available from Tamiya as low friction screws. I beleive they are "Tamiya specific."
Nerobro is offline
Old 02-10-2020 | 08:29 AM
  #2309
Is that for Type-S?
Old 02-10-2020 | 09:20 AM
  #2310
No, just a plain TT02. The shock towers, shocks, will need different fasteners.
Nerobro is offline
