Like Tree352Likes
NOVAROSSI Engine thread....
Old 03-05-2019 | 07:53 AM
  #10156
egobrkr's Avatar
egobrkr is offline
Old 03-05-2019 | 08:01 AM
  #10157
kgombe's Avatar
Nvrmnd
kgombe is offline
Old 03-05-2019 | 11:59 AM
  #10158
Any reviews about this engine here?
Is it any good?
https://www.absolutehobbyz.com/Novarossi-Paloma-21-Off-Road-7-Port-Engine-Extra-Long-Stroke-Steel-Bearings_p_516868.html
Niz55 is offline
Old 03-06-2019 | 01:32 PM
  #10159
Is it any good?
https://www.absolutehobbyz.com/Novar..._p_516868.html
I have this engine and I love it! tunes very easy, holds the tune well throughout the day. I have about 1/2 a gallon currently, no issues.
sebtarta is offline
Old 03-06-2019 | 02:06 PM
  #10160
Is it any good?
you were having issues with the Expensive REDS you bought saying it had too much power, it hadnt even broken in and loosened up yet, and you struggled to even get it to start.. apparently the "shocks" couldnt handle it and it squated down. are you running on the road? so many things to stop it squating
you're going to have this same power issue with the paloma and even deal with an even tighter engine over the reds.
My advise is get it EBIS broken in by adam drake or someone else.
iplaygames is offline
Old 03-07-2019 | 03:01 AM
  #10161
Niz55 is offline
Old 03-07-2019 | 11:54 AM
  #10162
New Engine
S21P5XLT/19 - NOVAROSSI WORLD
Pedro Jesus is offline
Old 03-07-2019 | 04:49 PM
  #10163
Originally Posted by Pedro Jesus
That makes sense now as to why I was seeing the P5XLT pipe combo going for so cheap! I should have bought the combo back then.
Here is an article from RedRC
Novarossi S21P5XLT/19 3.5cc nitro off-road engine
Novarossi have updated their popular P5 engine with the 2019 variant S21P5XLT/19 featuring a 14.5mm crankshaft with silicone filling as well as a 26mm bearing. Other features include a composite 3-needle carburettor, 5-port sleeve as well as the R7 lightweight aluminium conrod. The long stroke engine also sports a new cooling head design and it is available now.
Specifications:
– Displacement: 3.49cc
– R.P.M.: 34.000RPM
– Bore x stroke: 16.26×16.80mm
– Sleeve: 5 ports
– Rear ball bearings: steel
– Front ball bearings: steel
– Crankshaft: 14.5mm – turbo – with silicone insert
– Carburettor: plastic – 9mm – reverse
– Glow plug: Turbo (CTO6)
– Exhaust position: rear
– Starting: standard
– Weight: 375g
– Fuel type: 25% nitro
Source: Novarossi [novarossi.it]
sebtarta is offline
Old 03-07-2019 | 06:19 PM
  #10164
1/8 IC Fan's Avatar
With all the effort they put into their other motors, which is awesome, would it hurt them to put that cooling head on more of a diet. Make it smaller in O/D or add more lightening holes. I think that would bring the motor into the 2019's lol. My Original P5XLT makes my buggy look like its from the late 90's.
1/8 IC Fan is offline
Old 03-07-2019 | 10:52 PM
  #10165
Some drilled holes through the ribs is only saving a view grams, nothing important. To me the looks is less important than the performance, you can always mount an onroad head or something else smaller when it is cold outside but in hot conditions I will choose this head above the small low profile OS heads.
fastfreddie5754 likes this.
Roelof is offline
Old 03-07-2019 | 11:17 PM
  #10166
1/8 IC Fan's Avatar
Originally Posted by Roelof
Some drilled holes through the ribs is only saving a view grams, nothing important. To me the looks is less important than the performance, you can always mount an on road head or something else smaller when it is cold outside but in hot conditions I will choose this head above the small low profile OS heads.
I don't know, its just a shame that they did not put a little more updating to the Head, They could have used the Head from the Bloody or Loco - Live Range motors. Anodized Purple and re-engraved with the P5XLT logos.
I did machine an OS Head to fit my P5XLT two years ago...
Old 03-08-2019 | 03:29 AM
  #10167
roblupo's Avatar
Not sure why this is even a press release???? I love Nova engines, but wish they would concentrate on a race program and not a club race or basher program for off-road. They need to come out with an engine to compete with REDS, OS. I have tried my buddies Mephesto but even it is soft on the bottom. Great Top but that's about it. The Rolling has been my go to engine for awhile, even have had them modded by AMR. However one weekend running a Spec II style OS engine, has me rethinking my whole race engine plan due to the power, easy to drive and power out of the hole hence this game me better results and high consistency. The numbers really don't lie
roblupo is offline
Old 03-08-2019 | 04:04 AM
  #10168
Nice work. Calculate the weight of 1 hole you have drilled and calculate the total weight saving. the savings will not be more than 3 up to 5 gram, pinuts.....
Roelof is offline
Old 03-08-2019 | 11:28 AM
  #10169
TheWorstDriver's Avatar
Drilling holes increases surface area, and upwards/cross flow of the cooling head. Its not the weight that is the main benefit of newer drilled out designs in my opinion. The low CG heads Like FX and OS motors have now combine cross drilling with lower larger fins to get the best of both worlds. Hopefully Nova gets on board soon, people are noticing.
TheWorstDriver is offline
Old 03-08-2019 | 12:43 PM
  #10170
Yes, it will mess up the airflow by creating vortexes and will not give a better cooling. But peope are sensitive for the lightweight explenation while that doen't do a noticeable thing. I have seen engines with low placed heads and magnesium heads struggllin in hot weather conditions because they do not cool enough so such a old style head may not be fancy but for sure it works.
Roelof is offline
