Like Tree352Likes
NOVAROSSI Engine thread....
Old 08-14-2017 | 10:12 AM
  #9661
Originally Posted by rcmoe
Tko also sells that bearing too
Link? I could be wrong but I am pretty sure they do not have it due the patent
Roelof is offline
Old 08-14-2017 | 03:44 PM
  #9662
They do. I have a ceramic one in mines. I don't have a link
rcmoe is offline
Old 08-15-2017 | 02:19 AM
  #9663
Tzicul's Avatar
Open the engine, get a caliper and measure the bearing. I'm sure you can find it on boca, for example, or amain. You can't get a patent on some dimensions.
Tzicul is offline
Old 08-15-2017 | 02:55 AM
  #9664
I Know it is a 14.5x26x6 bearingand I know the 14.5x26x5.7x6 can be found on the TKO site but ths is a 14.5x26x5.7x4.7 bearing made to fit the dam they kept in the crank case
kgombe, stanleyw808 and dan_vector like this.
Roelof is offline
Old 08-15-2017 | 10:09 AM
  #9665
Has anyone put a standard 607RS bearing into a Novarossi engine and had any problems? The 607RS is a standard 6mm width whereas the Novarossi bearing is 6.3mm wide. The guy at TKO said the 607 fits, but it doesn't have the offset inner race. Curious if the 607 would pose any problems.
Also - does anyone know how the quality of TKO bearings compare to WIB bearings?
RCTecher12 is offline
Old 08-15-2017 | 12:36 PM
  #9666
It works, it is to give the flywheel more space from the crank case. without needing a shim behind the collar. With a normal beraring you could add a 0.3mm shimm to get the same but it is not needed.
offroad dude and stanleyw808 like this.
Roelof is offline
Old 08-15-2017 | 02:34 PM
  #9667
That's what I figured. Thanks.
Old 08-16-2017 | 04:52 PM
  #9668
SEF's Avatar
SEF
Anyone run the Mantra in buggy yet? How is it compared to the Mito 4 or older 21-4 type motors?
SEF is offline
Old 08-16-2017 | 05:06 PM
  #9669
Just for fun other than the Novarossi name, which engine companies are using a Novarossi based engine?
Please feel free to list them off.
190mph is offline
Old 08-16-2017 | 05:29 PM
  #9670
Big B's Avatar
Protek
Kinetic RC
LEF
Tesla
Fusion X
Ultimate Engines
I am sure there are more that's are the ones I have come across
Big B is offline
Old 08-16-2017 | 05:33 PM
  #9671
mourinho's Avatar
Protek, Ultimate, FusionX, Rex, Ielasi, Murnan Modified, Kinetic RC
mourinho is offline
Old 08-16-2017 | 07:39 PM
  #9672
rcmania74's Avatar
Anyone tried a mantra...running a b2102 and not super impressed
rcmania74 is offline
Old 08-17-2017 | 12:58 AM
  #9673
MAX Ninja, Gi-Mar
Roelof is offline
Old 08-17-2017 | 05:04 AM
  #9674
MAX Ninja, Gi-Mar
RB Products
But RB closed doors
Pedro Jesus is offline
Old 08-18-2017 | 02:28 AM
  #9675
slodsm's Avatar
I miss RB . Still call em the best engines I ever had back in the day.
wichitafc98 and Pedro Jesus like this.
slodsm is offline
