Like Tree352Likes
NOVAROSSI Engine thread....
Old 12-19-2016 | 03:35 PM
  #9286
mourinho's Avatar
Originally Posted by HaulinBass
The mito have a 14.5mm crank like the keep off 7 and virtus. Noone else makes that bearing cheapest I have found for a replacement ceramic for it is about 70us
you sure?
http://tkocompetitiondev.com/product...-woffset-race/
mourinho is offline
Old 12-19-2016 | 03:48 PM
  #9287
HaulinBass's Avatar
thats the replacement for 16002
HaulinBass is offline
Old 12-19-2016 | 06:56 PM
  #9288
kgombe's Avatar
I'm pretty sure that the bearing that is posted in the link is the one you're looking for...
kgombe is offline
Old 12-20-2016 | 02:40 AM
  #9289
DrNitro's Avatar
No that's the wrong bearing. For MITO4 you need a bearing with following dimensions:
Ø14,5x26x5,7x4,7mm - 11 balls
Will be hard to find a replacement.
Original NOVA numbers are:
16009 for steel bearing
16006 for ceramic bearing
DrNitro is offline
Old 12-20-2016 | 04:28 AM
  #9290
cczjordan's Avatar
Sorry, same as keep off 7,mito = virtus + keepoff technology
cczjordan is offline
Old 12-20-2016 | 12:26 PM
  #9291
warning to anyone runing novarossi engines seems there are some bad conrods
out there
after runing novarossi and novarossi based engines for nearly 20 years i had
my first new con rod fail and novarossi decided they do not warrantry replacment rods or the damage they cause to your engine.
rick oxley is offline
Old 12-20-2016 | 01:08 PM
  #9292
1/8 IC Fan's Avatar
out there
Any further link to this happening on others engines, or forums? What motor, how many gallons? Been running Nova based motors in On-road since around the time Serpent had the Nova/Mega 21's and TX15 and knock on wood, no conrod failures here. Offroad I have only run the P5XLT and a P3XS, Strange.
1/8 IC Fan is offline
Old 12-20-2016 | 02:31 PM
  #9293
HaulinBass's Avatar
out there
Please post up the engine model and batch and year from the case if possible.
Old 12-20-2016 | 02:40 PM
  #9294
His story in the Nova onroad topic:
http://www.rctech.net/forum/14774327-post5191.html
Roelof is offline
Old 12-20-2016 | 06:20 PM
  #9295
cczjordan's Avatar
Kinda funny, after 3 months of used. Within that period, anything can happened
Old 12-21-2016 | 04:53 AM
  #9296
If I am right he just placed a new rod. Not sure which one he have placed, this motor comes with a lighter new designed R4 rod which I do find it tricky. When a replace is needed I do replace them with the rock solid R7
Roelof is offline
Old 12-21-2016 | 10:20 AM
  #9297
the engine was a mito 35 on road engine had just about been fully broken in
and was in exellent condition when the r7 rod was replaced to keep the engine
reliable. the new r7 rod bush failed on the 5th tank of fuel.
Old 12-21-2016 | 10:25 AM
  #9298
not 3 months of use, novarossi have had my returned engine for 3 months
before looking at it.
Old 12-21-2016 | 10:38 AM
  #9299
the replacement r7 rod was purchased from my countrys distributor
in the first shipment novarossi sent out after there summer break
Old 12-21-2016 | 10:41 AM
  #9300
On the R7 rod there is also a number engraved, I believe the latest is around 15 or 16.
Roelof is offline
