Serpent 710
Originally posted by InitialD
How can he ask for forgiveness when the person whom you think can give him absolution is committing the same sin?
Look carefully Mark and look harder...
Eh, did Onkel Sow steal your microscope?
Part number has already been given.
Originally posted by B4
I hate to say this but I used the Kyosho shim set as you get more of all the shims and they cost less. Don't have the part number at the moment but if you're interested I'll check for you.
If you that thing to run you better use the Serpent shims.
Originally posted by markp27
Originally posted by Pyramid
Just a side note: dont look at the smoke, trust your temp gun.. give this configuration a try at last and please share with us of what you find yo be the best setups: 0.4-0.6 clucth gap, 2mm spring (centax 2) tension, 0.2mm end play, yellow shoes, mod fliyweights (Glenn C).
Bro, what are you temping the engine at? 120 degree C?
2mm spring from the 705? Swoooosh!
I'm using the black clutch shoe cut up (thanks Fmolzer) which gives a nice lump of acceleration in comparison to the normal fly weights.
Remember I will be running at 10C outside temps at first, so it may be difficult to get to the 120C.
Should I also run it in a bit hotter than normal? or is 90-95C ok?
That P/S Mark's posted can do at 190C without get fried Bro.. of course it will automatically slowing down
*faint* *thud* *smoke*
