Speed Passion Thread >
Like Tree4Likes
Old 03-29-2015 | 05:34 PM
  #5461
DuncanT4.2's Avatar
Default Reventon burnt up before first Run
I just finished a new stadium truck kit and had all my electronic installed except the servo, so I turned the Reventon on so I could center the Servo before installing it and noticed a spark on the ESC between the orange and yellow motor wires and within a few seconds purple smoke started pouring out the ESC, before I could hit the off button or disconnect the battery. apparently whoever soldered the motor wires to the ESC at Speed Passion accidentally let solder connect the orange motor wire to the yellow motor wire which created a short on the ESC. So the brand new ESC is ruined and also I now have a partially melted stadium truck chassis before I ever even got to run it. Pictures of the damage are attached. [IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
DuncanT4.2 is offline
Old 04-06-2015 | 06:01 PM
  #5462
HSV427's Avatar
Hi peeps i need some help, i have a reventon pro in my 22-4 and the buggy only runs for 4 minutes at full throttle and then dies as if the battery is dead and the buggy goes real slow exactly like the battery was dead so to test the battery i put it in another buggy and it still has plenty of punch,and i can easily get another 10 minutes of run time out off the same battery in another buggy, I'm running a 6.5t motor and i have the voltage cut off disabled. Any advise would be great.
HSV427 is offline
Old 04-06-2015 | 08:44 PM
  #5463
[IMG][/IMG]
[IMG][/IMG]
Weird that your's was soldered from the factory. Both the Reventons I have I had to solider them up my self.
It should still be under warranty, I'd contact them and see about sending it in under warranty.
Riverbluff is offline
Old 04-07-2015 | 04:05 AM
  #5464
just a thought - try putting low voltage cutoff on.
I've never seen this problem.
eragot is offline
Old 04-07-2015 | 07:26 AM
  #5465
Jpdanger's Avatar
I have two Rev Rs and both of them came pre-soldered and each had different length wires on them . Only my Pro 1.1 came not soldered.
BTW, from my experiences, their customer service is non-existent!
Jpdanger is offline
Old 04-09-2015 | 03:50 AM
  #5466
Have just bought 2 Pro's to go in a BMax 4 III and a RC10 Worlds rere. I'm running these with 10.5t motors in each.
Can someone explain Percentage Braking ABS and Initial Braking Force? Think I've got both on 100% ABS and 60% Initial Force (think this is max for both). The BMax feels OK but think the braking force is too much for the RC10 - just feels like an on/off switch.
Also, does anyone use drag brake?
Eddscott is offline
Old 04-12-2015 | 12:25 PM
  #5467
Kremzeek's Avatar
Are there any promo codes for http://shop.speedpowerrc.com/ right now?
Kremzeek is offline
Old 04-12-2015 | 08:09 PM
  #5468
J2O
Does anyone know if SP replaces/repairs esc's under 1 year old?
J2O is offline
Old 04-13-2015 | 04:18 AM
  #5469
SP will repair (it's taking forever) or offer a discount for a new one (much faster)
eragot is offline
Old 04-13-2015 | 03:36 PM
  #5470
Default reventon pro.
Wondering if anyone know why or have this happen before. I drove the buggy yesterday everything was perfectly fine. Today I turned it on and no throttle. Checked all the wiring it was fine. Changed sensor wires. No change. Redid the calibration and then it worked fine. Never had that happen before. Been using sp Speedo's for years no issues ever. Could be a sign of a failing Speedo.
rc8 racer is offline
Old 04-14-2015 | 08:22 AM
  #5471
DuncanT4.2's Avatar
Yeah the Reventon S comes presoldered as well. I have not had very much luck with getting a replacement through SP but luckily the hobbyshop I ordered from was nice enough to give me a replacement for 30$ shipped. The new one I just recieved has motor wires that are approx 40mm shorter and they aren't long enough to reach my motor now Im done trying to save money with these cheap SP and Hobbywing electronics. Im just going to order a decent system from Novak, Tekin or Trakpower and be done with it.
Old 04-14-2015 | 01:22 PM
  #5472
Jpdanger's Avatar
I had this happen too. No rhyme or reason as to what caused this. However, it took several recalibrations until it started working properly. I even dug out the manual to make sure I was calibrating It correctly and I was. It was a head scratcher...
Jpdanger is offline
Old 04-16-2015 | 12:44 PM
  #5473
MOmo's Avatar
Curious if anyone else is getting any sort of Thermal issues?
Was helping a fellow racer running SP.
His car (Schumi K1 running Mod on carpet). His car would shut down after about 3 min run. Initially the LVC was set to High, or so he thought. I brought a prog. box and we adjusted it down to NO LVC, and in the next race, it again stopped. He ran back to his pit, powered it off and on, and it ran fine.
When we temped it after the race, ESC, W/ the Fan was coming off at over 140.
The motor (the new V4) came off well over 160.
I remember Olorosky (sp) having trouble at an EOS that his ESC was turning off.
Anyone know if its a software glitch or possible signal loss with a receiver causing troubles?
My Pro 1.1 all seem to run around 120-140 and motors around 120.
MOmo
MOmo is offline
Old 04-16-2015 | 12:49 PM
  #5474
MOmo
Generally a hot or very hot motor is a result of over gearing. A hot or very hot ESC can be a result of under gearing.
Most guys, including myself, will race with voltage and heat disable. At EOS it was not an ESC issue. From what I was told it was the battery.
Nexus is offline
Old 04-25-2015 | 10:01 PM
  #5475
can the reventon pro ex 1.1 handle a tekin pro4?
i downloaded the manual but it does not specify...
kongluc is offline
