Tekno RC EB48 Thread >
Like Tree2Likes
Old 06-17-2013 | 05:37 AM
  #7291
Slotmachine's Avatar
Originally Posted by jlfx car audio
Thank u . I'm running #3 on punch . and with the 13t it should b fine.
Remember............... if you over rev a motor it can get hot too. I almost always run 1 or 2 on punch, and 1 on timing with an 1800kv and an 18 pinion.
Slotmachine is offline
Old 06-17-2013 | 05:49 AM
  #7292
Originally Posted by xrayrc
having trouble getting through the 180 degree turns.
can anyone have a look at my setup and provide any tips.
my SCT410 steers twice as much as my EB48 might have to
look at my servo maybe its going bad???
Try a little thinner oil up front.
RokleM is offline
Old 06-17-2013 | 06:56 AM
  #7293
vfrninja's Avatar
Also what's the smallest pinion anyone has used ? I have a dynamic 8 2200 in my sons car but have a 14t on it and
Still gets warmer than I would like to see it on our small track . turned the epa down to 80% and still coming off at 165+- after 8min
You maybe under geared. I run a 16t indoors medium sized high bite track and a 17 outdoors on a large track and haven't seen over 150 on my dynamic 8 2200. LRP ix8 with standard power band, Reedy 3700mah. That's after a 10 min run.
vfrninja is offline
Old 06-17-2013 | 07:57 AM
  #7294
jlfx car audio's Avatar
OK good to know I'll try going bigger
jlfx car audio is offline
Old 06-17-2013 | 08:03 AM
  #7295
bcjoldbq's Avatar
Are the 180 degree turns smooth/flat, off camber, w/ step-ups or step-downs before the turn, high speed/low speed?
Which JConcepts tires you running? Attached setup sheet is kinda blurry.
bcjoldbq is offline
Old 06-17-2013 | 09:22 AM
  #7296
goehm's Avatar
Originally Posted by masin14
Hey everyone, I got my eb48, but my front steering hubs are locking up so it only steers part way. I know its the front hubs because when i took them off it works just fine. I dont know if I did something wrong or what, but I know its not supposed to be like that. Please help me out guys.
Make sure you have all the washers that holds the steering link to your steering spindle. Depending on the setup, the number varies on the amount above/below the ball. However, even if the ones above the ball aren't used to effect a geometry change they still do perform a function; they keep the bolt from over-extending out of the spindle and digging into the arm (thus causing steering to bind).
I think if you look at the arm you'll see some gouges which indicates where the bolt is hitting.
goehm is offline
Old 06-17-2013 | 09:26 AM
  #7297
justpoet's Avatar
Thumbs up
Big thanks to Tekno RC for the awesome car.
NorCal just finished up an outdoor summer series and the entire series podium was the EB48.
justpoet is offline
Old 06-17-2013 | 09:34 AM
  #7298
goehm's Avatar
You said 0 boost, I'd suggest you make sure 0 timing. My experience has been that timing/boost in 4 pole motors do make more speed, but not efficiently - so a lot of energy is lost in the form of heat.
14T on a 2200 is a little small, I suspect 16T. Make sure the body has some holes for air (I have some before and after so air can flow through the body).
If it's getting hotter over 10 minutes, make sure you don't have any driveline binding. I'm not familiar with the Dynamic 8 motors, but I believe 165 is still within normal operating temperatures .. so if that is the max temperature then you should be OK. Tekins can run in the 190 range with no damage.
goehm is offline
Old 06-17-2013 | 11:07 AM
  #7299
ChrisAttebery's Avatar
The ebuggy class at NorCal hobbies has been very competitive lately. This weekend's race was no exception. The qualifiers were really tight and it seemed like there was a new leader almost every lap. In the main Brian Tran and I fought for 10 solid minutes and in the end he beat me out by .18 seconds. Our fast laps were only .001 second apart.
The top 6 buggies were all EB48s. Tekno is dominating the ebuggy and 4wd SCT classes here.
ChrisAttebery is offline
Old 06-17-2013 | 11:47 AM
  #7300
brian94066's Avatar
Love this car, still drove amazing with 3 good tires
brian94066 is offline
Old 06-17-2013 | 11:50 AM
  #7301
rcboy1's Avatar
could you tekno guys do me a favor? I would like to know the distance between the two body post holes on the body, and also how wide the body is. thanks.
rcboy1 is offline
Old 06-17-2013 | 12:08 PM
  #7302
teknorc's Avatar
Dave, Chris,
Get us some write-ups with some podium pics and we can post it on our site!!
Congrats to the winners, that is awesome to hear!
teknorc is offline
Old 06-17-2013 | 06:31 PM
  #7303
Nope 0 boost . track is very loamy so its probably do to the extra wheel spin . I loaned the car to a guy to run this past weekend and for him it kept getting motor hot , tho I'm sure his trigger finger was a big part but was just wondering what's the smallest pinion anyone has got to fit .
My 1900 runs a 15t @145+- on this track
In answer to your question. You can go down to 12 for sure, but you have to remove the center brace.
rcmiket is offline
Old 06-18-2013 | 03:29 AM
  #7304
Genebaby's Avatar
Originally Posted by protc3
I dont know if you took the rear chassis brace out but if you did, the chassis can compress alot. This is why i left mine in. I took the center out only. I have been running the aluminum one for 3 full race days now and it is straight as an arrow. I have had my fair share of good flips and hits and it is holding strong.
I installed the aluminum center shaft in my second build but only installed the front brace like before.
Should I put the rear brace in with this shaft? Is that going to be required with the lightweight shaft?
Genebaby is offline
Old 06-18-2013 | 08:10 AM
  #7305
Hey guys I am running the tekin 1900 motor/Rx8 combo and my temps seem a little high (170-180). I am running on a medium/large style outdoor track. What pinion would you guys recommend as I believe that I have a 16 or 17 on there now.? Thanks
JoeC is offline
