Tekno RC EB48 Thread
I added the same update to my SL and I am wondering if was a bad idea because with the buggy off the ground it results in some major bump steer, the front tires get some serious toe out at full droop. I haven't had the chance to run it yet but I will report back with my findings in a few week once I have done a back to back comparison. I'm not 100% sure the newer .4 steering set up was intended for the SL.
Also be sure that you shorten your steering links approximately 2-3mm per side so that you have enough adjustment to achieve the correct static toe.
New eb48
Good morning everyone,
Here is one that is considering buying this car and wanted to know what parts would be good to have spare parts and which springs are usually used, those that come in the box?
I don't think your looking at the EB48, if your buying new, then look at the EB48.4 thread. But to answer your question on spares, Hinge pins, shock shafts, and spur gears. 2 sets of each in your pit box. that will get you through most issues.
Does the EB48.2 accept the .4 front towers?
