Tekno RC EB48 Thread >
Like Tree2Likes
Old 08-24-2013 | 07:41 PM
  #8791
flameoutgarrett's Avatar
Usually with a savox on 2s you need the cap but I've never needed one with a big boy speedo, only on the 2wd cars.. With small speedos
flameoutgarrett is offline
Old 08-24-2013 | 09:23 PM
  #8792
May have been answered but I am trying a new setup other than my own and there is many ways to measure droop and I'm wanting to make sure on the method that everyone is using to measure on the downloadable set up sheets
scorpion51503 is offline
Old 08-24-2013 | 10:46 PM
  #8793
SMR 510RR's Avatar
Eye to eye on the shock unless otherwise noted.
SMR 510RR is offline
Old 08-25-2013 | 12:01 AM
  #8794
Thank you for clarifying that wow that's a lot more droop than I had then
Old 08-25-2013 | 04:02 AM
  #8795
Motorman007's Avatar
Originally Posted by Antimullet
Pro9 cap? If you mean a glitch buster for your servo-not necessary with a 4s setup and a vtx8 ESC. That thing will drive any servo no worries.
Also-not sure where your at but I think amain is selling the same rc proplus connectors for a bit cheaper.
http://www.rctech.net/forum/12450676-post8704.html
Amain don't have these and don't have a 5 set pack at all
http://www.amainhobbies.com/index.ph...cturers_id/843
Motorman007 is offline
Old 08-25-2013 | 06:08 PM
  #8796
samuelsonmark71's Avatar
She is almost ready for the track:
samuelsonmark71 is offline
Old 08-25-2013 | 06:47 PM
  #8797
Gene158's Avatar
So I was driving my brothers eb48 the other day and decided I liked the way his drives better than mine. We're running the same electronics and gearing but different setups. He's running the box stock setup and I'm basically running the Curtis door setup. My buggy feels kinda "assy." I've felt for a while now that it's somewhat hard to drive and unstable. His felt much more planted to the track and a little easier to drive but I don't know what I need to change on my setup to achieve a more planted feel. Someone please help!!!
Gene158 is offline
Old 08-25-2013 | 08:37 PM
  #8798
Bernard_Jr's Avatar
Are you using the same tires?
Bernard_Jr is offline
Old 08-26-2013 | 03:30 AM
  #8799
Well i got my nice new Fioroni pistons in for the races this last weekend. For the guys using them. Im running 35/30 green front, orange rear springs. It felt nice. Plush and really wouldn't bottom out on anything, unless it went really big and sloppy. I do feel like i lost some steering. I was running the same setup with CSI with good results. I lost the ability to rotate the rear end around.
Dont Hack Me is offline
Old 08-26-2013 | 04:29 AM
  #8800
Genebaby's Avatar
Looks fantastic!
Genebaby is offline
Old 08-26-2013 | 04:30 AM
  #8801
Genebaby's Avatar
I'm keen to give these a try now as well when I can get some. Thanks for the info.
Genebaby is offline
Old 08-26-2013 | 05:46 AM
  #8802
hi guys im thinking of getting in to this buggy but dont know what gearing i should run ill be running a 2000kv sensorless motor on 4s what would be a goo starting point for the gearing?
traxxasrockhead is offline
Old 08-26-2013 | 06:56 AM
  #8803
Is that green and orange tekno springs, or green and orange Kyosho springs?
MX304 is offline
Old 08-26-2013 | 07:07 AM
  #8804
Graham11's Avatar
Depends on the size/type of track?
Graham11 is offline
Old 08-26-2013 | 07:09 AM
  #8805
17T would be a could start point probably
merkyworks is offline
