Serpent 811E Buggy Thread
#3316
+1. I run the t8 1900 and I run 80% for now on these tight indoor tracks. And your 2050 rips! Def test it out, your lap times will get better.
#3317
Thanks for the feedback folks. Theoretically, can I turn off the current limit and then use my radio's EPA to limit throttle? It should pretty much be the same thing, right? In my SC, I set the ESC to 70% and I would use my EPA to fine tune to wherever I was driving. Well, why not just set the ESC to full power and do the same thing? It sure would make it easier to make adjustments and be able to run it all out if I wanted to play out in the open.
And yes, the 2050 all out rips! I'm very happy I went with this combo.
#3318
Jkoiva (or others),
Do you have the current limiter set on your RX8? I just built up an 811be 2.0 and installed an RX8 and T8 2050Kv. I have my limiter set at 90% but was curious as to if I could run with it off. I've only just finished and run it up and down the street a few times. I haven't even discharged the packs yet.
Saw your last post, Yes
#3321
I haven't been to motorama before, just started racing in August. Now I have fallen in like a heroin addiction but loving it. Lol. All the local pros around me who went last year said the track doesn't get much maintenance throughout the weekend and its much like an outdoor track, loose and dusty. Everyone I have talked to has said to use larger pins like blockades or revolvers, holeshots. I'm bringing a variety... Just wasn't sure anyone had been last year a had a serpent setup.
#3323
Thanks. What are you running for shock oil out there? . I'm still running stock weight with webbed bladders. Seems a little light for the indoor packed tracks(body roll) up here. But for outdoor and motorama loose type tracks I think it will be ok? Suggestions? Thanks
#3325
#3326
Motorama tires that should work are gridirons, impacts, subcultures, hybrids, blockades, and anything else similar. I ran all Super soft last year. Track is pretty loose and gets blown out. But I did see guys running everything from HB Beams to Proline Badlands!
#3327
#3329
Beyond that, there really weren't any significant issues. I purchased all steel locknuts instead of using the plastic ones included and I got an aluminum servo arm. This thing is pretty nice overall once you get the nuances figured out. They include a mix of industrial bearings and basic sealed bearings - I see a full Acer Ceramic upgrade in the near future. I can't wait to install the electronics and try it out. I know it's gonna be solid here on out.
Don't waste your money on Ceramics. Bearings are $1 each just get some Avid revolutions every few months and toss old ones. You are likely to shatter ceramics especially if you use them in your hubs. But try if you want, you'll see.
I am installing a RX8 to my Serpent BE. Three questions.... Does anyone attach the ESC to the radio tray via screws? If so, what size are the screws? What does everyone use to put under the ESC to mount it and protect it? I have velcro, but I think there is a better solution somewhere....
Jkoiva (or others),
Thanks for the feedback folks. Theoretically, can I turn off the current limit and then use my radio's EPA to limit throttle? Well, why not just set the ESC to full power and do the same thing? It sure would make it easier to make adjustments and be able to run it all out if I wanted to play out in the open.
5Likes
. I'd drop it down to 75 or so to start off with and go up or down as needed.
