Serpent 811E Buggy Thread >
Like Tree5Likes
Old 01-09-2013 | 08:53 PM
  #3286
jk1152's Avatar
Originally Posted by rdeppen
What your missing is Serpent has adjusted the diff cup and ring gear dimensions. They no longer require the shims. They just havent bothered to updat the manual LOL
When the ebuggy came out there was an addendum that said to make sure the gear mesh is tight as it will loosen up after running it. I followed these instructions and everything came out fine.
jk1152 is offline
Old 01-10-2013 | 05:36 AM
  #3287
Maxxingout's Avatar
Yes but the changes to the diff cup and ring gears are after that. those instructions are correct if you do not have the latest cups and gears.
Maxxingout is offline
Old 01-10-2013 | 02:12 PM
  #3288
I am currently running the stock shock set up on my Serpent. I like the feel as they are plush but have ample pack. I am thinking of going up a bit in oil wt. Problem being I am used to wt and not cst. From what I gather the stock oil is equivalent to 25. I am thinking of using 27.5 or 30. What is everyone using? Also what benefit do the webbed bladders have? What pistons are people using? I know Serpent has an aftermarket piston. Lastly what does it mean when the set up sheet says the hole is closed?
IOP_Racer is offline
Old 01-10-2013 | 03:26 PM
  #3289
Hey folks, I'm about to take the plunge for a new 811be and wanted to get some input. I've searched the thread but can't find what I'm looking for. For electronics, I was planning on the Tekin Rx8/2050 combo. I also wanted to run a 1267 or 1268 servo, but I don't want to run into the brown out 'glitch' problem. I will be using the Airtronics 461 receiver. I run the Rx8 with this receiver in my SCTE with a 1258 and I had to add an external BEC. Sooooo, anyone here running this combo on 4s without the BEC? I've seen servo recommendations and different ESCs, but just curious on this combo. Thoughts?
RC_Tactical is offline
Old 01-10-2013 | 07:46 PM
  #3290
cpt_RedBeard's Avatar
I'm running a 1258/RX8/T8 2050 in my serpent with a Airtronics RX-371 Receiver and I have no brown out issues. However I am also running a 1258/RX8/tenshock sc411 in my scte with a Airtronics RX-461 and still no brown outs. Have you set your end points correctly?
cpt_RedBeard is offline
Old 01-11-2013 | 02:29 PM
  #3291
Yes, I've doubled and triple checked my end points to ensure there's no overtravel or binding. I first ran an Orion Vortex SC in a Kyosho Ultima with a Savox 1258 and never had an issue. I then picked up a Losi SCTE and ran the Rx8 with the 1258 and it would drop out with just part way turning. Sooooo, now I'm on the fence about what to run in the new Serpent. I guess I really don't mind the external BEC, but I'd rather not use it if I don't have to. I like the Rx8 ESC and I'd like to just deal with one product line.
Redbeard, have you ever found the 1258 to not be powerful enough for the Serpent? It seems most folks opt for something well into the 200s for torque in their 1/8 buggies. The 1258 is rated at 166oz-in; still pretty darn stout for sure.
Old 01-12-2013 | 08:38 AM
  #3292
teeforb's Avatar
Up for grabs
http://www.rctech.net/forum/r-c-item...nt-s811be.html
teeforb is offline
Old 01-14-2013 | 07:19 AM
  #3293
Here is a different way to run your wires.
400units is offline
Old 01-14-2013 | 11:24 AM
  #3294
kaptain8's Avatar
The webbed bladders help by letting the shocks achieve the true rebound. I am running on indoor high bite track currently using serpent 8 hole conical pistons. 50 wt front with blue spring and 40 in the rear with yellow. You can also try 35 in the rear with green springs.
kaptain8 is offline
Old 01-17-2013 | 10:57 AM
  #3295
So I just bought and built an 811e. The drive train seems to be binding. Is this normal with this car? I've never had a 8th scale with such a stiff drive train.
The diffs aren't crunchy, but there seems to be some binding in front and rear diffs when I put the diff in the housing and the diff pinions. I can't really see the mesh very well because of how the diff cases are designed.
I am going to have to break down the entire front and rear of the car again.
Edumakated is offline
Old 01-17-2013 | 01:27 PM
  #3296
The diffs are supposed to be a little tight at first. After the first hour or two they will be smooth.
Old 01-17-2013 | 01:33 PM
  #3297
I'm not talking about the diffs. The diffs seem smooth when I turn the outdrives. It is just when I put the diffs into the diff case and tighten the diff case down, there appears to be some binding either with diff case or the diff doesn't mesh properly with the front and rear drivetrain pinions that go into the diff case.
Old 01-17-2013 | 03:37 PM
  #3298
Check to see if the ring gear is rubbing on one of the screws that holds the pinion assembly in place.
Also try backing the bottom diff case screws out a bit
jsorwell is offline
Old 01-17-2013 | 05:12 PM
  #3299
bigjayjay1's Avatar
Your drivetrain will be tight but as stated make sure you don't over-tighten the diff cases to much this will cause extra binding.
bigjayjay1 is offline
Old 01-18-2013 | 07:15 AM
  #3300
RC MARKET's Avatar
Serpent Release new alu. rear upright 2.0
RC MARKET is offline
