Serpent 811E Buggy Thread
#4786
#4787
Chicky,
I am converting from your old setup to your new and have a couple of questions.
The front aluminum spindles, I see those on Joe's etruggy setup also, what is the reasoning for those over the plastics? I also noticed you run them in the "high" position, which I assume is the one shim on the stock plastics, 2 shims on the aluminum, what does that change in the setup? I see the same on the Spyder a lot and not sure what spindle height does for handling. The setup seems to favor adding rear traction over the previous which has been an issue for me at one track, but not so much others. I'll have it out on Saturday and will see. I will also be by to bug you at AMS. We are heading up Thursday morning and I will have the ebuggy and etruggy.
Thanks!
Grant
Thanks!
Grant
#4788
Chicky,
Thanks!
Grant
Thanks!
Grant
The buggy I use them and Joe does not. The alu 600497 are the same as the stock steering blocks but have a little more throw. The 600611 are 0 deg steering blocks and we use them on truggy. They just seem to work better on truggy than the stock ones.
The higher spindle takes away a little steering.
Let us know how the setup works out. it has a lot more rear traction I think.
#4789
#4790
Chicky,
Thanks!
Grant
Thanks!
Grant
#4791
Triple/single jump our quad and my rear shock shaft separated from the tube. That seemed odd to me, so when I tore it down and inspected it, I found a sheared shaft piece. The shaft is hollow, and a 2.5 x 6mm screw holds the piston to the shaft. Where the shaft meets the piston, there is a different diameter section of the shaft. This part sheared off. When I got a replacement shaft from another Serpent owner, I finger-tightened the piston to the shaft with a 2.5 x 6mm screw, and the screw started very smooth. When I tightened it 1/4 to get it snug, the same thing happened. The part where the piston attaches to the shaft snapped off around the screw.
This must be a manufacturer defect because it did not take much force at all to do this, and it might be possible for the shaft speed to create enough force to cause this to happen off of big jumps. I want everyone to be aware of this issue. I really enjoyed driving my Serpent despite it scratching 3 races due to part failures.
#4793
I run a 16t with the 46 spur. Running setting 5 boost on the Hobbywing ESC and it comes off 140-150 after a 10 min main on our larger outdoor tracks. I could probably do a 17 if I either cut down the boost or opened some holes in the body for air flow, but speed has not been an issue so far compared to others.
I've been running Chicky's setup as well, but changed to Joe's piston/oil setup from the Mugen Challenge for a bit more pack. We have some pretty big air jumps and my car was getting un settled on landings. Now I love the way it drives everywhere. The sway bar play adjustment is especially clever.
#4795
So oddly enough I had a similar failure where the shoulder of the shock shaft separated from the shaft and came apart during practice. I put it back together with some elbow grease and prayers and it held the rest of the race day (3 quals and a main). I have never had that issue before, and this is a 2.0 rear shaft but fairly old. I just got new shafts in the mail yesterday to replace it, but I have not heard of this. Keep in mind the threads go beyond the shoulder so this should not happen as most of the thread engagement is below the shoulder. What pistons are you running and are you running the spacer with them?
#4796
I can't say if there is a defect or not, as my pieces are all older, but we will see with the new shafts I just got if there is any trouble screwing them in. I did get the ti-ni coated ones, vs the plain ones previously. I'll also measure my screws and make sure they are 6mm.
#4798
I just recently had 1 of my shock shaft break at the same point. The wall thickness after that part of the shaft has been turned down then tapped is not very thick. The new one's I just got are solid on that part with the threads cut on the outside, using a nut to hold the piston down. Should be a much stronger setup now.
#4799
OK OK, but to be fair, you probably broke it when you rear ended me with that piggy Kyosho of yours...
That is how the Spyder works, and would be great if that is how they are now. I didnt look closely at the ones that just arrived to see if they used the 2.6 screws or nuts.
#4800
5Likes
