Serpent 811E Buggy Thread >
Like Tree5Likes
Old 03-18-2012 | 06:16 PM
  #1786
netmaster's Avatar
Originally Posted by GMS_Racing
Actually its the opposite...3 is the most aggressive and 1 is the mildest.
+1
Option 3 comes with the buggy
Option 3 has the least amount of Ackerman, thus has the most aggressive steering. (Outside wheel does not physically turn as far, this is because on the Serpent its the inside tire/knuckle that is limiting the steering throw)
Option 1 would have the most Ackerman, thus has less aggressive steering and is better for large flowing tracks, or when you generally want to tame the steering down
Option 2 is just in the middle of the two
Personally option 1 and 2 took too much initial turn in away for my liking.
netmaster is offline
Old 03-18-2012 | 06:32 PM
  #1787
I just got word on this subject from John, the owner of http://www.clockworkracingengines.com/
These guys customer service is OUTSTANDING!
anyway he says:
You should get most steering from option 3 but going to a 2 makes it easier to drive. If you want more off power go with 2 or 1 but you will lose some on power steering.
I go by this posted info that I read a while ago...
Less ackerman will be more aggressive steering but also harder to drive
More ackerman will be less aggressive steering and easier to drive
option 1 - more ackerman
option 2 - just the right amount
option 3 - less ackerman
Pretty sure Billy Easton preferred the option 2 overall.
I run 2 myself.
John
Vortexted is offline
Old 03-19-2012 | 07:27 AM
  #1788
Maxthepersonz's Avatar
If anyone want's to pick up a set of the Carbon Fiber Shock Towers SER600152 and SER600151 that I installed on my kit and then removed for the aluminum ones right away. They have never been ran and are new. Send me a PM with an offer will sell for quite a bit cheaper than anywhere online!
Maxthepersonz is offline
Old 03-19-2012 | 01:14 PM
  #1789
RCmayor's Avatar
Originally Posted by Vortexted
Welcome to the snake pit JP and Mrnizzles......great choice!
I've been giving my 811e a beating!
I even broke the rear chassis brace and wing Braces.
I discovered Serpent does make aluminum chassis braces for this car but they
Are only listed on Serpentamerica.com web site. There prices are the lowest I discovered as well but they do charge shipping, unlike Amain.
EDIT: I just spoke with John at http://www.clockworkracingengines.com/ and he is going to start stocking these aluminum chassis braces for this car.
I'm going to tear my car down And change diff fluids.
I'm running a large outdoor fast high bite track.
Should I stick with 5k-5k-3k diff fluid?
I'll post some pics later in the week when I get some new stuff installed.
I was just looking through a catalog at Absolute Hobbyz and they have the rear aluminum brace also.
RCmayor is offline
Old 03-19-2012 | 01:46 PM
  #1790
RCmayor's Avatar
I'm thinking about cutting down the receiver box so it is just a platform at the top. I have too much wire to pack in that little box. Probably would relocate the antenna also to a more horizontal so I don't have drill a hole in the body right over the receiver. Hmm, not sure what to do yet.
RCmayor is offline
Old 03-19-2012 | 02:49 PM
  #1791
tony montana's Avatar
I would stick with 5-5-3. No need to get away from what everyone else is running in case you need other setup help. My car was really good yesterday after making some more changes to settle the car down more
tony montana is offline
Old 03-19-2012 | 02:53 PM
  #1792
bronc4now's Avatar
i cut mine down so i didnt have to put a hole in the body but im sure ill end up with some air vent holes anyway..
bronc4now is offline
Old 03-19-2012 | 04:16 PM
  #1793
RCmayor's Avatar
Ya, I already had to modify the crap out of the esc/servo mount to fit the Hobbywing 150A speedo. It fits but it's a little bigger than I expected.
Wish you could buy the mount separate, so far I have just seen it included with the side guard/battery box package for $50 bucks.
RCmayor is offline
Old 03-19-2012 | 05:08 PM
  #1794
JPKinsella's Avatar
Default pulled the trigger
The snake is on the way should be her on Wednesday can't wait to start the build.. As for option parts I picked up the Alum. towers, the sway bar shaft and pins, webbed blatters, option #2 ankerman, blue taper pistons, and a tekin 1700kv motor. Question one what gearing should I run for the 1700kv? Question two are the serpent shock springs any good? Question three does anybody have a good setup posted yet for a tight high bite clay track???
JPKinsella is offline
Old 03-19-2012 | 05:14 PM
  #1795
Mine will be here wednesday too
PrestonG is offline
Old 03-19-2012 | 07:45 PM
  #1796
RCmayor's Avatar
A 16 tooth pinion comes with the kit, I'm going to try that with a 1900. But I got a 17 also just in case that doesn't work. Kinda new to the 1/8 e buggy so hopefully these are in the ball park.
RCmayor is offline
Old 03-19-2012 | 08:13 PM
  #1797
what springs should i run and pistons for a clay based outdoor 1/8th scale track with some blue groove?
HotBodiesVe8Boy is offline
Old 03-19-2012 | 09:01 PM
  #1798
KIK's Avatar
KIK
Click on the link
KIK is offline
Old 03-19-2012 | 09:45 PM
  #1799
JPKinsella's Avatar
Sorry link does not work
Old 03-19-2012 | 10:15 PM
  #1800
Where does the receiver go in this car. I cant get any receiver in the box not even the new Airtronics MT-4 ones....
