NOVAROSSI Engine thread....
#4366
depends what you are after.... stock they are quite nice, they have good bottom/midrange and a reasonable top end...... Some people love them the way they are, others find them to be a little too mild....I cant speak for others but my modified version is a pretty substantial bump in power and RPM over stock....bottom end we gain a little, midrange we gain a fair bit and the top end of the modified absolutely sings compared to stock.......The modified version carries all the same characteristics as stock, except its a whole pile faster......... Some love them the way they are, others will like the modified version better..... just depends on how much juice you want .
#4367
Temps between 100 and 110º C. With full tank it shall be 100ºC. When the tank is nearly empty the temp will climp to a little under 110ºC.
Ambient temp between 15 and 25ºC.
3 tank at idle speed.
The next 4 tanks with a little more throttle after each tank so you start the 7th tank at 50% speed. The last 8th tank with various RPM and no full speed runs for more that a second or so at a time.
Maybe an extra shim under the head.
This is how I do it.
Cheers
#4368
Normally I run it easy until 2 liters if the balls hasn't droped. Then race tune.
One of my RC friends ran BTT engines until a team change. One of the engines had 6 liters on it, and the conrod was worn out... Why? Too low temp during break-in. Or that was what we concluded because he didn't leaned it enough to get the engine up to 100ºC even with the head wrapped.
#4370
#4372
You're so funny!
Minor detail... ToMato/tomAto
BTW: I run 20% nitro for the first half GALLON
Less nitro requires less compression so you don't have add an extra shim during break-in.
Less stress on crankpin and rod due to less powerfull combustion.
Easier to keep the temp high enough because high nitro percents cools the engine.
Lower fuel costs.
:Less nitro requires less compression so you don't have add an extra shim during break-in.
Lower fuel costs.
#4375
I have found the Xray with Lucky 7 air filters to be a great combo. I have a around 7 of these that i just replace when needed on race day. then wash and reoil when i get home and replace back in the zip lock bag for the next day.. Filters get used until i cant remove impregnated particles...then they get replaced with new ones.....
#4376
#4377
#4378
I would bet if you tried advantage racing filter you won't try another plus they are cheaper then all the rest. if you don't like them PM me.
#4380
352Likes
