Like Tree5Likes
SC10 4x4 Thread
Old 08-02-2012 | 11:16 PM
  #27826
thanks fq6 i tried the 15 it was good and raised the limiter back to 70 or 80 then used ept at 85 and speed at 70 pt was beater but far from praised
got in the MIP pistons at least 30min install thanks to second shocks i can swop back ez but i don't think they are coming off i dropped 3s off my average lap times and most are better than my best from last night of a 33s it was like the truck wonted to be Divine fast less grip but control no more ice skating more like a losi but faster i used 35w in front and 30 in the rear ae oil
9turn is offline
Old 08-02-2012 | 11:18 PM
  #27827
MIP MIP MIP
9turn is offline
Old 08-02-2012 | 11:38 PM
  #27828
Originally Posted by Evil Genius jr.
Thanks WC, and yes I'm going to get a VTS lol
I'll get a new pinion. Hows this mesh look?
Originally Posted by Arakon
Looks way too tight to me, that'll give you drag (and a lot of fine, black plastic dust). The first setting was fine, maybe a tiny tad tighter. You'll want to be able to wiggle the spur back and forth a very small amount before it touches the pinion.
But as others said, get a new pinion.. that's likely half the reason for the shredded spurs right there.
One other suggestion here. Set the mesh pretty close to what you want, snug up the motor screws and spin the spur a little bit at a time while watching the mesh. Spurs are not perfectly round and there will be a spot where the mesh is tighter than elsewhere. The spot where the mesh is the tightest is where you want to set things up from.
AzFittin is offline
Old 08-03-2012 | 12:29 AM
  #27829
Good morning!
Do u guys think it would work to replace the clicker-spring with a little tube made of brass, to lock it without the need of glueing or additional tuningparts? I'm student and have to pay all my parts myself, so i'm looking for a low-cost alternative to try wether fulltime 4wd is good for me or not. The clicker parts are quite expensive in germany
Greets cody227
Cody227 is offline
Old 08-03-2012 | 02:35 AM
  #27830
Originally Posted by Cody227
Good morning!
Greets cody227
Er.. if you want to try full-time 4wd, you simply tighten down the nut. There's no need to glue anything. Especially for testing, this will work just fine.. I ran 4WD for 2 months with no issues whatsoever, no mods done.
Arakon is offline
Old 08-03-2012 | 02:52 AM
  #27831
Not for me. I tightened down the nut as much as possible and it didnt work. The clicker clicks even when the car is in the air (with fulltime 4WD) and i break a little bit. And the clicker is not damaged or something like that. I read often that the clicker dont work and usually they glue the clicker. There is also NO diference in handling with the locked clicker.
Cody227 is offline
Old 08-03-2012 | 03:02 AM
  #27832
Are you sure that was the clicker? The clicker buzzes when hitting the brakes. It could very well be your belt slipping instead.. I had the same issue with mine.
The clicker would also click if you spin both front wheels backwards by hand if it was slipping through.
Arakon is offline
Old 08-03-2012 | 03:10 AM
  #27833
I'm pretty sure it's not the belt. It clicks also when i hold the car in the hand, hit the throttle for a moment and then let the car roll out in the air. Same issue when i hold the rear-tires and turn the front-tires by hand.
Cody227 is offline
Old 08-03-2012 | 04:12 AM
  #27834
blown sv's Avatar
It is the diffs , shim the as stated earlier in this thread and your problem will be solved.
Has it been doing this fo some time ?, yours sounds to be on the very worn side.
blown sv is offline
Old 08-03-2012 | 04:16 AM
  #27835
blown sv's Avatar
Originally Posted by J61092
Can someone help me with a belt issue? I have it geared 20 tooth rear an 19 tooth front for overdrive, an my belt became loose or thats what I thought. I had the tensioners fully tightened an it was barely enough to keep the belt tight enough. So I bought a new belt an put it in an it is no tighter then the old belt. I still have to run the tensioners fully tightened to keep it barely tight enough. Anybody know why?!
How and where are you feeling the belt tension?
blown sv is offline
Old 08-03-2012 | 04:25 AM
  #27836
Why the slipper look many rub mark on it?It is not normal!.May be something wrong in slipper ,so made the friction too much for bend the teeth pf motor gear.
freeman118 is offline
Old 08-03-2012 | 05:00 AM
  #27837
@blown: that may sound a bit ungrateful, but i dont think it's the diff. The clicks come only when i spin the wheels in one direction, not in the other. The sound is also different from when i had the diff-issue in the rear. I'll check the diff, but i'm really sure its the clicker. The sound, and the other symptoms are typical for that. Anyway, do u think the brass tube will sustain (i dont know if its the right word) the forces from the clicker? Just for testing-porpuses.
Cody227 is offline
Old 08-03-2012 | 06:18 AM
  #27838
Wildcat1971's Avatar
Tech Prophet
show us a picture of your locked clicker. the clicker does not move if fully tightened.
Wildcat1971 is offline
Old 08-03-2012 | 06:29 AM
  #27839
wildcat look at my last post
9turn is offline
Old 08-03-2012 | 06:37 AM
  #27840
Tech Prophet
MIP Pistons?
