Like Tree5Likes
SC10 4x4 Thread
Old 07-25-2012 | 10:55 AM
  #27076
Originally Posted by Wildcat1971
ah, your going to try the pinned top shaft?
Pinning the top shaft and running the Exotek clutch are the same thing. Only difference is your idler gear is not stressed with the Exotek. You'll likely strip the rear pulley instead which is easier to replace.
jamr1130 is offline
Old 07-25-2012 | 11:03 AM
  #27077
Wildcat1971's Avatar
The pinned top shaft still slips right. The inside hub is just directly attached to the shaft instead of spinning, correct? The exotek spins on the shaft but locks up the front slipper. The pinned shaft makes it into a b4 style sipper where front and rear slip the same, but the exotek allows the rear to slip and the front to not slip. No?
Wildcat1971 is offline
Old 07-25-2012 | 11:27 AM
  #27078
Cain's Avatar
Tech Legend
saw the article about AE winning 7 classes at hot rod hobbies shootout. How did it do in the 4wd SCT classes?
Cain is offline
Old 07-25-2012 | 11:39 AM
  #27079
BlueGlowBoy's Avatar
Looks like Tanner Denney made the A - Main, but didn't podium.
BlueGlowBoy is offline
Old 07-25-2012 | 11:40 AM
  #27080
Wild Cherry's Avatar
Tech Legend
results on www.liverc.com
Wild Cherry is offline
Old 07-25-2012 | 12:02 PM
  #27081
Originally Posted by fq06
Me too, rx8 and It was useless... couldn't drive 5 seconds without a brown out.
Fine with external bec now, I didn't think I would have to go there with the rx8's 5a bec... but I did.
Wow. I run a 1258 with an RX8/Novak Ballistic 4.5t, and I never have any brownout issues.
Snafujg is offline
  #27082
Cain's Avatar
Tech Legend
must be missing it, was curious on who the drivers were for AE with the SC104x4
Cain is offline
Old 07-25-2012 | 12:06 PM
  #27083
Tech Legend
Seen it happen when using Spektrum radio, easy fix is to add a cap on the receiver side ....
  #27084
Denney placed 8th and looked to be the only AE driver in Pro 4 class.
Again the SC10 4x4 the red headed step child not really liked at the family reunion but had to be invited because he's family.
jamr1130 is offline
Old 07-25-2012 | 12:09 PM
  #27085
Cain's Avatar
Tech Legend
LMFAO.
Oh well, maybe the next race.
Cain is offline
Old 07-25-2012 | 12:15 PM
  #27086
Where is the article?
Old 07-25-2012 | 12:16 PM
  #27087
Cain's Avatar
Tech Legend
liverc and radiocontrolzone have some info up on it.
Cain is offline
Old 07-25-2012 | 12:17 PM
  #27088
murky123's Avatar
has anyone tried to make their own toe-block ? To give this truck more rear toe-in?
I made an aluminium toe-block ( hand made ) and it gave my truck somewhere around 4,5 degree of toe in.
I have tested it on medium / high bite outdoor dirt track and I have the feeling the truck will catch grip a few yards sooner when coming out of corner and going WOT coming up on the straight away.
ofpower steering into corner is also more controlable.
in all I have the feeling the truck can be pushed a bit harder and still remain predictable.
murky123 is offline
Old 07-25-2012 | 12:21 PM
  #27089
fq06's Avatar
The guy at the track shop said it's a crap shoot. One 1258 will have no issues with the rx8 and another one will. I got lucky I guess
Old school JR synthesized tx & rx with a novak cap. Never had an issue with the airtronics servo that I broke the casing on mid race... that's the only reason I bought the savox, it was about all they had for my application and I wanted to race the main.
Maybe it was for the best, I have the CC ext. BEC now and the esc is running about 10° cooler.
fq06 is offline
Old 07-25-2012 | 12:27 PM
  #27090
Cain's Avatar
Tech Legend
I was hoping that AE would make a hopup (or someone else) using replaceable inserts so you can adjust the toe-in, etc. that way.
Cain is offline
