SC10 4x4 Thread
MBX5 Prospec you say??? Awesome buggy! We ran those back in the day. Along with the Mugen Truggy.
I'll still stop by here and comment once in a while I really enjoyed my AE 4x4. It took work to get it right and now I thing i've taken it as far as I can. So I am intriqued with something new..
Durango on it's way for me
Hard anodized and Teflon coated bodies, ti-ni coated shafts, its better.
but what's the benefit of the hard anodized shock body?
I still think 13mm big bore shocks are already more than enough, especially most sc10 4x4 won't be competing in an outdoor track with big air, isn't it?
Cain - Many thanks for the info!
Lastly, to avoid the outdrive problem, how many spacers are recommended on the shock shaft? I take it its better to place them outside the shock body on the shaft, correct? Again, thanks!
Can someone help me with a belt issue? I have it geared 20 tooth rear an 19 tooth front for overdrive, an my belt became loose or thats what I thought. I had the tensioners fully tightened an it was barely enough to keep the belt tight enough. So I bought a new belt an put it in an it is no tighter then the old belt. I still have to run the tensioners fully tightened to keep it barely tight enough. Anybody know why?!
im running the 19t in the front 20t in the rear and i have my belt set so the truck free rolls about 10 feet.
i can go tighter and my belt is the same belt from when i bought the truck back in the middle of the winter.
whats your definition of loose ?
this is the ford raptor from jconcepts. i also have the proline flowtek and that worked well.
Loose as in my tensioners are maxed out an that keeps it just barely tight enough. I thought that when I threw a new belt on that it would tighten things up an I would have to loosen my rear tensioner but nope I still have to have them both maxed out to keep the belt just barely tight enought. By barely tight enough I mean tight enough to run, skips a little but could be a little tighter.
sweeping is way cheaper than a new set of tire$ ....
At Trcr we sweep before each heat even .
If you can't sweep ?
another tip
check what the faster trucks are using for tires & inserts , try those tires ...
J61092
Are you using a chassis brace ?
But as others said, get a new pinion.. that's likely half the reason for the shredded spurs right there.
5Likes
