Like Tree5Likes
SC10 4x4 Thread
Old 07-29-2012 | 05:30 PM
  #27421
Wildcat1971's Avatar
Tech Prophet
Pfff, I cant even get to full speed on an outdoor 8th scale track with my tekin 550 2 pole. All it does is spin all 4 wheels. If I could get off of my power to the ground I would fly.
Wildcat1971 is offline
  #27422
Evil Genius jr.'s Avatar
Am I the only one down on power lol.
Evil Genius jr. is offline
Old 07-29-2012 | 05:32 PM
  #27423
Tech Prophet
I never even had power issues with a 2 pole 540. Heat issues, but not power. Like i said, I cant get it to the ground.
Old 07-29-2012 | 05:39 PM
  #27424
Wild Cherry's Avatar
Originally Posted by Smittydidit
WC. The bottom end is all I can handle with the 12/62 gearing, My truck launches out of the corners. Especially with the Exoteck front locker. What it seems I'm down on is the last 30% of the straight. Not that anyone is blowing past me, Just seems as though I hit an acceleration "plateau" I guess you could say. Running no motor timing and 10 Deg through the ESC. Maybe I'm just looking for more without wanting to "Pay" for it. IE timing and boost.??
TIP
Don't favor a gear for top speed on the straights , anyone can go faster but the problem with that is they dive deep & wide into the sweeper losing time usually.
Try to gear the truck for the infield like the jumps & such .
Not the straight so much .
That is where you can find real speed , the straights you can even give a little time and still get faster lap times overall because most of the track is on the infield ...
But only you can judge ...
Sounds to me like you can try a larger pinion....
If you think your losing time on straights ?
gear up !
Do this before more timing or boost ...
Make sure to check your motor temps after 2 or 3 min ....
also before changing anything ?
ck ESC & radio settings if set correctly....
Wild Cherry is offline
Old 07-29-2012 | 05:49 PM
  #27425
Oasis's Avatar
Originally Posted by CraigMBA
Your honesty is appreciated. Believe it or not, so am I.
You mean I waisted a perfectly good troll....
Oasis is offline
Old 07-29-2012 | 05:53 PM
  #27426
Cain's Avatar
one thing to keep in mind with motor selection, at some point, the pinion size gets big enough that you can't get the motor out with the pinion on. Why does this matter?Putting the pinion on when the motor is already on can be a real pain without an angled wrench.
wonder if I coudl just dremel the opening larger?
Cain is offline
Old 07-29-2012 | 05:54 PM
  #27427
Yes you can.
Old 07-29-2012 | 06:15 PM
  #27428
i dremeled part of the belt cover so i can gt my non angled wrench onto the pinion.
twisted is offline
Old 07-29-2012 | 06:17 PM
  #27429
has anyone thought or gone ahead and drilled some holes under the motor for cooling ? idk if it would work and i dont want to be the guinea pig so i thought i would ask .
twisted is offline
Old 07-29-2012 | 06:18 PM
  #27430
Tech Prophet
lol, I dont get all of these cooling issues. Gear it correctly and go.
Old 07-29-2012 | 06:27 PM
  #27431
Maddog94's Avatar
Agreed. Castle 1410 here, geared 16/62 and I can run it until lipo cutoff (> 10 mins) and it's still only 155.
Maddog94 is offline
Old 07-29-2012 | 06:31 PM
  #27432
Jake S's Avatar
i drilled a hole from the bottom and countersunk it so i just put a normal 4-40 screw and nut on the other side to fill the hole
Jake S is offline
Old 07-29-2012 | 07:08 PM
  #27433
i have the afect is minamal but if you cant aford a fan every 2 weeks it helps any one know of a fan that will last
9turn is offline
Old 07-29-2012 | 07:13 PM
  #27434
any body know were to get the after market front and rear bumpers
9turn is offline
Old 07-29-2012 | 07:14 PM
  #27435
evil what motor you run that is under power
9turn is offline
