Like Tree5Likes
SC10 4x4 Thread
Old 07-29-2012 | 11:32 AM
  #27391
Cain's Avatar
got in my first race with my SC104x4 outdoors here using RC Shox starting setup. Our track was ran dry and was a hard dry surface, very loose, somewhat bumpy, with a layer or fluff on top. Tires were off, will hopefully get that fixed soon but I changed the following since rear traction was darn near non existent:
- White rear springs
- 25W losi in rear
- Rear shocks upper mount inside 1 position
Vehicle was awesome as far as handling goes other than traction issues. The Center diff is MONEY. the way it could pitch into turns and take them at speed ... you want this hop up.
Cain is offline
Old 07-29-2012 | 11:35 AM
  #27392
i am disapointed in tekin i had hoped the currint limiter was a true limiter but it is more like punch that currint the old stuff like 412clll limits currint
9turn is offline
Old 07-29-2012 | 11:42 AM
  #27393
vito's Avatar
got some jc 3mm off set wheels and new proline tires to and how big of a motor drive gear can fit in this kit iam at 12 62.
vito is offline
  #27394
Wild Cherry's Avatar
Originally Posted by Evil Genius jr.
Thanks!
Will it work on my outdoor track?
+ YouTube Video
Should perform great , how I would run my truck if I were racing with you .
The only changes I can suggest is to use the tire combo that working best at your track.
Wild Cherry is offline
Old 07-29-2012 | 11:43 AM
  #27395
Evil Genius jr.'s Avatar
Should perform great , how I would run my truck if I racing with you .
Okay thanks!
Evil Genius jr. is offline
Old 07-29-2012 | 11:51 AM
  #27396
CraigMBA's Avatar
CraigMBA is offline
Old 07-29-2012 | 11:56 AM
  #27397
CraigMBA's Avatar
A lot of guys here will tell you to try a smaller pinion, add boost , timing, ect to improve the trucks acceleration.
Instead if you need more acceleration ?
Gear up a tooth ..
Whats happens when you gear down a tooth ?
Just risks more wheel spin and this can kill the
acceleration your looking for ....
However
If the traction is good a smaller pinion is smoother & coast brake improves ....
( better for infield performance)
Suggest to always test a smaller & larger pinion just to see if there is a benefit with either...
Using the Reedy Sonic 550 4.5 *
( 32p/62 spur , 12t <> 13T pinion)
*Hauls azz fast
If I gear down, it's always because I need more torque. Wheel spin would be a welcome problem at that point.
With the four pole sensored motor, making torque is not an issue anymore.
CraigMBA is offline
Old 07-29-2012 | 11:59 AM
  #27398
craig whot the f is you problem i am a big fan of slower is faster and i like the 4600 tekin but it is a litle over powered and i like to limit the torq
9turn is offline
Old 07-29-2012 | 12:01 PM
  #27399
OldGuydust's Avatar
Originally Posted by CraigMBA
OldGuydust is offline
Old 07-29-2012 | 12:02 PM
  #27400
see that is it i dont like wheel spin hard to control
9turn is offline
Old 07-29-2012 | 12:11 PM
  #27401
so no reply
9turn is offline
Old 07-29-2012 | 12:12 PM
  #27402
CraigMBA's Avatar
Because:
Just saying.
CraigMBA is offline
Old 07-29-2012 | 12:20 PM
  #27403
and are you a spelling and grammer teacher or some thing
9turn is offline
  #27404
Selling some stuff
http://www.rctech.net/forum/r-c-item...l#post11030279
Old 07-29-2012 | 12:28 PM
  #27405
has any one tryed the 3300 tekin vs the 4600
9turn is offline
