Like Tree5Likes
SC10 4x4 Thread
Old 03-24-2012 | 10:19 AM
  #19891
darryl80's Avatar
Thumbs up
i will be putting a hitec 7955 servo in my sc10 4x4 when i get it in the mail.
darryl80 is offline
Old 03-24-2012 | 10:21 AM
  #19892
Default Garodisks
I'm running the stock slipper and just got the garodisks. Do I tighten the nut to the stock setting? all the way? or is it just personal preference?
math_rulez is offline
Old 03-24-2012 | 10:42 AM
  #19893
ilanstylz's Avatar
Well finally finished my FT SC10 4x4, I started yesterday and finished it up this morning (took me a little while because I was working on two of my other cars as well yesterday and my hands started to get tired since my power drill died lol)..........
Review out of the box, yes it is basically the same as the original SC10. The good things, I do like the shocks better on this one and I really like the new design on the slipper/clutch setup........The bad, if you are running saddle packs the gens ace 6000mah are a tight fit (any saddle with a 31.33mm height), you cannot use the stock screws to mount them.... I am not sure on the exact size since I just used some spares I had but I believe you'll need ones that are 20+mm in length.... So now I need to buy a longer set screw to install the battery strap lock (for now just using a washer in place of it)..........Also the space they leave you to install an esc is tight, I don't believe an RX8 (or with similar dimensions) will fit. Only fix for this is to put the esc on the same size as the motor and your RX on the other side.........Finally the chassis brace feels real flimsy and may break over time if you crash alot like me lol.....Other then that I can't wait to get this on the track and try AE's slipper setup.......
Here is the FT version next to my original SC10 (which I converted to center stick pack):
ilanstylz is offline
Old 03-24-2012 | 10:56 AM
  #19894
Finally had a chance to run my truck today, after having it for almost 2 months. LRP X12L 5.5 motor ran great, at most 65°C after 2 runs back to back, using a gens ace 100A sensored ESC. Only issue I had were some rollovers on high grip corners. Jumped fine on the jumps we have, good speed down the long straight.. only issue I have, as predicted in my first postings about the kit: The body already has some tears and bad ones at the rear, where the rear bumper smashes into the body on landing or rolling over.
Arakon is offline
Old 03-24-2012 | 11:10 AM
  #19895
ilanstylz's Avatar
Gens Ace makes an esc for cars? Got any pics of it?
Old 03-24-2012 | 11:16 AM
  #19896
They're re-branded ESCs actually.. http://www.gensace.com/epages/genspo...ESC/Car_Series
Arakon is offline
Old 03-24-2012 | 11:22 AM
  #19897
ilanstylz's Avatar
Nice, not bad for $80 bucks US.........
Are you running swaybars on your sc10? I haven't had a rollover since I installed them on mine.......
Old 03-24-2012 | 11:25 AM
  #19898
CoyoteSlash's Avatar
Originally Posted by sugs
Good to hear you like the truck again Coyote. You didn't mention if you were running front springs on the rear though.
Ah yes. I forgot. I am running blue fronts in the rear as well.
Originally Posted by vito
i need a new car a 22t or a new ft kit or just the slipper and brace. i like the ft kit a lot .
Kid. You gotta come out of mach 2.
I see alot of "not LHS guy, i'm human" and whatnot. /sigh
And do not fret my children! It is a humbling notion even for someone of my caliber. I know I sit at the precipice of divinity in my occupational choice to all of you, my... 'little people'. But I SHALL NOT FORGET your 'cute' mortal ways when the time to raise the RC Heroes into Valhalla has come!
oh my god, please find the humor in making fun and don't take it literally.
CoyoteSlash is offline
Old 03-24-2012 | 11:28 AM
  #19899
Yep, blue F/R at this time, and 35/30 oil with blue springs F/R.. it's high grip astroturf.
Arakon is offline
Old 03-24-2012 | 11:39 AM
  #19900
ilanstylz's Avatar
Have you tried lowering your ride height? Maybe go with a lighter shock oil and possibly a lighter spring rate?
Old 03-24-2012 | 11:43 AM
  #19901
nice to see you got your sense of humor back coyote....back on your meds?
beaven is offline
Old 03-24-2012 | 12:35 PM
  #19902
vito's Avatar
thanks guys found a way to buy the disc fro rc shox my moms best friend had pay pal i used her pay pal to get the iam am sorry .
vito is offline
Old 03-24-2012 | 12:49 PM
  #19903
kjohnsiii's Avatar
Guys, will the rx8 fit ok with the inline saddle config.?
Pics would be awesome.
kjohnsiii is offline
Old 03-24-2012 | 01:43 PM
  #19904
Cameron Kellogg's Avatar
From what I hear NO, but I am sure you guys will come up with something.
Cameron Kellogg is offline
Old 03-24-2012 | 01:50 PM
  #19905
ilanstylz's Avatar
Cameron is right, the rx8 will not fit because of the belt cover, only fix is to switch sides...... Put the rx8 where the receiver goes, vice versa..........
