Like Tree5Likes
SC10 4x4 Thread
Old 03-24-2012 | 06:56 AM
  #19861
bschanz's Avatar
hey guys, i have been running this truck since it was released, the kit version that is. the only mod I have is the center brace, made from carbon tube and threaded rod. it seems to be good, no splitting or anything. I still run the battery layout as stock. I am not racing it yet. pesky job is getting in the way. I am running the castle 3800 4 pole with the sidewinder esc. i mounted the fan on the esc and use the 48p spur. i recently put a 22t pinion in and did some wot runs to get to temps and still am in the 140 deg range. the esc is cool to the touch. I notice that there is a lot of front end lift with wot. I have 30k in the front diff and 10k in the rear. i have the white springs in the rear and stockers up front. how can i tame the front end lift a little? i am losing some of the front traction as the front wheels are nearly off the ground.
I get very little of the slipper fade that people with the 550 cans are getting. I checked it yesterday the pads are a little glazed. i scuffed them up and ordered new ones.
thanks in advance.
ben
bschanz is offline
Old 03-24-2012 | 07:26 AM
  #19862
JEFFs SC10's Avatar
On Live RC
My feed was horrible. I could not watch any of the races. I basically got audio with a still frame.
Cav was on the money for 2wd and 4wd buggy.
My receiver took a dump last night.
JEFFs SC10 is offline
Old 03-24-2012 | 07:35 AM
  #19863
J_Bone's Avatar
Originally Posted by darryl80
will the sc10 4x4 wheel hexes below fit on the sc10 2wd FT?
http://cgi.ebay.com/ws/eBayISAPI.dll...m=270928919048
any help would be very helpful.
No! Don't buy them.
J_Bone is offline
Old 03-24-2012 | 07:41 AM
  #19864
Jerm13's Avatar
thanks in advance.
ben
I would think of extending your wheel base in the rear. This would help put more weight over the front wheels at all times.
Jerm13 is offline
Old 03-24-2012 | 08:13 AM
  #19865
Robert421's Avatar
[QUOTE=bschanz;10509703]hey guys, i have been running this truck since it was released, the kit version that is. the only mod I have is the center brace, made from carbon tube and threaded rod. it seems to be good, no splitting or anything.
Is there a sorce for the carbon tube and what is the part number for the rod ends? I am sure that if I looked around my spare parts box I could find a sutible subsitute, maybe I am just being lazy. I would rather build a reliable previously tried center brace. Thanks for any infor you can offer
after doing some research I found a pdf file on google.com for this exact issue. I could post the pdf here, if I knew how
Robert421 is offline
Old 03-24-2012 | 08:27 AM
  #19866
JEFFs SC10's Avatar
bump up your shock oil in the rear. You shouldn't have that much weight transfer. You can also raise the ride height too.
Old 03-24-2012 | 08:43 AM
  #19867
Farmer_John's Avatar
thanks in advance.
ben
It's a weight transfer issue. Solve it through spring, oil and/or droop settings. If I remember correctly (without pulling out the wonderful Xray tuning guide), a tad less droop in the front should limit weight transfer to the rear wheels, giving you more front bite (and if I'm correct help keep your wheels planted). If it's the other way around...well, I'm human and don't work in a hobby shop...
Farmer_John is offline
Old 03-24-2012 | 08:53 AM
  #19868
JEFFs SC10's Avatar
LMAO
Old 03-24-2012 | 08:56 AM
  #19869
BorackBasher's Avatar
has anyone picked up one of the new FT kits yet? just curious on how the build is going and if there is any new tips/tricks they put in the manual..
BorackBasher is offline
Old 03-24-2012 | 08:58 AM
  #19870
Originally Posted by JEFFs SC10
LMAO
What? I'm enjoying my muscle relaxers...
Old 03-24-2012 | 08:59 AM
  #19871
vito's Avatar
i need a new car a 22t or a new ft kit or just the slipper and brace. i like the ft kit a lot .
vito is offline
Old 03-24-2012 | 09:01 AM
  #19872
Suspended
Default SC10 4x4 factory team
I just got a bunch of the facotory team sc10 4by4's in stock. I'm so excited to build one. I'll post pictures once it's done
Rboesen1 is offline
Old 03-24-2012 | 09:07 AM
  #19873
blakelenk521's Avatar
I just built up a factory team and there isnt anything much differant about the car except for th much better shocks, chassis brace, and the battery placement. The only problems I had were the o-rings wouldnt sit into the plastic diff halfs and they forgot to include the blue metal pivot balls that go into the sway bar links. Other than that it was a fun build and cant wait to get it on the track!
blakelenk521 is offline
Old 03-24-2012 | 09:09 AM
  #19874
you think you just got bad luck on the pivot balls? and for the o-rings did you fix the problem?
Old 03-24-2012 | 09:13 AM
  #19875
SOuthernFRIED's Avatar
AE is shipping the pivot balls to customer's. Some of the earliest kits did not have them included. I received my pivot balls like Tuesday,, kit won't arrive till Monday.
SOuthernFRIED is offline
