Like Tree5Likes
SC10 4x4 Thread
Old 07-10-2012 | 07:32 PM
  #26356
fq06's Avatar
I am all about saving money lol.
No doubt! I've never gone through so many bodies in so little time. 1/8 buggy bodies lasted up to a season. I guess my learning curve getting used to the sct had something to do with it, but not 3 bodies in about 9 months worth!
fq06 is offline
Old 07-10-2012 | 07:34 PM
  #26357
JEFFs SC10's Avatar
I dont have any weight up front. I'm going to try 60 g, I'm sure it'll help it nose over even better.
JEFFs SC10 is offline
Old 07-10-2012 | 07:35 PM
  #26358
MantisWorx's Avatar
My dr is at 50%......... lol. I am about to steal my kids slow servo from her truck.
@MantisWorx I know its doing what its setup to do, lol. I need it setup to do something else. I am using the 8mm mod, zero shims in the back would be bad, no?
Man, your truck is all over the place on setup, just by your RC shims alone it will have entirely too much steering and most of that is due to the back coming around because of the 8mm mod and not having enough inside shims (6mm minimum). The thing is that you need to start off with a working setup BEFORE you start throwing other things in the mix. I feel safe and saying ( and i think alot will feel the same) that my base setup is really good on outdoor tracks with or without the Cdif and 2 stage pistons. Try this setup EXACTLY, tell me what it is doing and we can go from there. This is also assuming you are running the VTS, in which case i highly recommend the Garodisc ASAP, if you want any kind of consistency . I am leaving shock oils out because i have no idea what works with stock pistons, never used them!!
Front:
1*toe in
0 camber
yellow springs
yellow sway bar
30k dif fluid (kyosho grease works best)
shock outside on arm middle on tower
24mm ride height
4mm Roll center shims
camber link on outside
REAR:
3-2 block
-2* camber
Front green or white springs
blue sway bar
5k grease in dif
shock inside on arm middle on tower
24mmride height
1mm Roll center shim
camber link on inside and #2 from the inside on hub (no 8mm mod yet)
this is a very neutral setup and works well on everything, at the very least its a great base. Since i have had this truck for over a year and a half i tend to know alot about it!! If you start here i can tell you exactly what to do to get it to act like you want. As of right now your going to get way too many opinions and you will get lost!
MantisWorx is offline
Old 07-10-2012 | 07:37 PM
  #26359
Wildcat1971's Avatar
Tech Prophet
Closed wheel classes always seem to trash bodies. The body is the first thing to take the impact. I reinforced mine to make it weight 2x as much as it should lol. I use a Marine silicon sealant around the outside. It is flexible and easy to apply. It is made by the same people that make shoe goo.
Wildcat1971 is offline
Old 07-10-2012 | 07:40 PM
  #26360
Tech Prophet
Front:
1*toe in
0 camber
yellow springs
yellow sway bar
24mm ride height
REAR:
3-2 block
-2* camber
blue sway bar
5k grease in dif
24mmride height
The stock pistons often use 32.5 and 27.5 little more or less temp depending. Yeah, I have been talking to like 100 people about the truck, so I am sure it is all over the place. What do the gasto disks do for me.
  #26361
JEFFs SC10's Avatar
I say use one body to practice with and keep your nice one only for race days.
Ive seen someone use a mesh along with shoo goo to really make the body strong.
Old 07-10-2012 | 07:46 PM
  #26362
Tech Prophet
Front:
1*toe in - check
0 camber - check
yellow springs -check
yellow sway bar - check
30k dif fluid (kyosho grease works best) check check
shock outside on arm middle on tower check check
24mm ride height - no idea, lol. my ride high gauge will be here in a few days.
4mm Roll center shims - I had 5mm, will take one out
camber link on outside - check
REAR:
3-2 block - broke mine, need a new one
-2* camber - umm, ok. I had 1 deg
Front green or white springs - would need to buy, have rear yeallow and front blues atm
blue sway bar - check
5k grease in dif - check
shock inside on arm middle on tower - check
24mmride height
1mm Roll center shim - umm, ok.
camber link on inside and #2 from the inside on hub (no 8mm mod yet) - umm ok.
This is pretty close to my original setup. Yes, I have the VTS.
***** I do not have a FT and no chassis brace and saddle packs.
Old 07-10-2012 | 08:11 PM
  #26363
MantisWorx's Avatar
Front:
1*toe in - check
0 camber - check
REAR:
3-2 block - broke mine, need a new one so you are using the 3-3?
Front green or white springs - would need to buy, have rear yeallow and front blues atm front blues will work but are a little stiff
24mmride height
Garodisc are slipper pads the never wear out and never glaze, on top of that you can actually set them to slip without fear of overheating the entire drivetrain.Once you set them they never need to be re adjusted!
If you are using the 3-3 block this also makes the truck unstable on entry but will give you better onpower steering and rear traction while accelerating
Old 07-10-2012 | 08:13 PM
  #26364
fq06's Avatar
Yea, I figured out shoe goo and drywall tape after the 1st body... even still it doesn't last nearly as long as 1/8.
There isn't really anywhere close to run nitro though, so I got a sct. Fun class to race though and the accommodations at a indoor track blow away most outdoor tracks.
Westcoast raceway is starting to allow 1/8 with 2 cell though so im close to pulling the motor & stuff out of my mbx-5 and replacing it with E gear
Maybe even convert it to a sct and race it, but then I'm back to burning through bodies. Damn! Where did I go with that?
fq06 is offline
Old 07-10-2012 | 08:16 PM
  #26365
SMR 510RR's Avatar
Yes that setup is very close to where I am at currently, very safe base setup to tune from do doubt.
As always, make one change at a time and test...Rinse and repeat until it drives how you want. The only thing I would not change is spring rate balance front to rear, once you have the truck jumping and driving level leave the springs alone and tune with everything else to get it to turn how you want.
SMR 510RR is offline
Old 07-10-2012 | 08:19 PM
  #26366
fq06's Avatar
Body #2 is still in decent shape but a little ugly and gets used for the first 2 or so packs to warm up and then body #3 comes out for the rest of the day. Gave body #1 (mad max) to a friend that just picked up a AE and has never driven before.
I think I just like painting bodies, and if anyone is not good at painting... short course will give you plenty of practice
fq06 is offline
Old 07-10-2012 | 08:20 PM
  #26367
Tech Prophet
Mantis, does this look right?
By titilate1971 at 2012-07-10
Old 07-10-2012 | 08:43 PM
  #26368
SMR 510RR's Avatar
Minus the 2mm of bump steer washers and the F/R roll center adjustment should be in mm.
Other than that looks good to me.
Old 07-10-2012 | 08:51 PM
  #26369
MantisWorx's Avatar
correct!
Old 07-10-2012 | 08:57 PM
  #26370
Can someone please post the front and rear shock lengths eye-to-eye compressed and extended? I'm trying to see if they'll work on my ride. Thanks in advance!
ufoDziner is offline
