SC10 4x4 Thread
Front:
1*toe in
0 camber
yellow springs
yellow sway bar
30k dif fluid (kyosho grease works best)
shock outside on arm middle on tower
24mm ride height
4mm Roll center shims
camber link on outside
REAR:
3-2 block
-2* camber
Front green or white springs
blue sway bar
5k grease in dif
shock inside on arm middle on tower
24mmride height
1mm Roll center shim
camber link on inside and #2 from the inside on hub (no 8mm mod yet)
this is a very neutral setup and works well on everything, at the very least its a great base. Since i have had this truck for over a year and a half i tend to know alot about it!! If you start here i can tell you exactly what to do to get it to act like you want. As of right now your going to get way too many opinions and you will get lost!
Closed wheel classes always seem to trash bodies. The body is the first thing to take the impact. I reinforced mine to make it weight 2x as much as it should lol. I use a Marine silicon sealant around the outside. It is flexible and easy to apply. It is made by the same people that make shoe goo.
Man, your truck is all over the place on setup, just by your RC shims alone it will have entirely too much steering and most of that is due to the back coming around because of the 8mm mod and not having enough inside shims (6mm minimum). The thing is that you need to start off with a working setup BEFORE you start throwing other things in the mix. I feel safe and saying ( and i think alot will feel the same) that my base setup is really good on outdoor tracks with or without the Cdif and 2 stage pistons. Try this setup EXACTLY, tell me what it is doing and we can go from there. This is also assuming you are running the VTS, in which case i highly recommend the Garodisc ASAP, if you want any kind of consistency . I am leaving shock oils out because i have no idea what works with stock pistons, never used them!!
Front:
1*toe in
0 camber
yellow springs
yellow sway bar
24mm ride height
REAR:
3-2 block
-2* camber
blue sway bar
5k grease in dif
24mmride height
Front:
1*toe in
0 camber
yellow springs
yellow sway bar
24mm ride height
REAR:
3-2 block
-2* camber
blue sway bar
5k grease in dif
24mmride height
Front:
1*toe in - check
0 camber - check
yellow springs -check
yellow sway bar - check
30k dif fluid (kyosho grease works best) check check
shock outside on arm middle on tower check check
24mm ride height - no idea, lol. my ride high gauge will be here in a few days.
4mm Roll center shims - I had 5mm, will take one out
camber link on outside - check
REAR:
3-2 block - broke mine, need a new one
-2* camber - umm, ok. I had 1 deg
Front green or white springs - would need to buy, have rear yeallow and front blues atm
blue sway bar - check
5k grease in dif - check
shock inside on arm middle on tower - check
24mmride height
1mm Roll center shim - umm, ok.
camber link on inside and #2 from the inside on hub (no 8mm mod yet) - umm ok.
This is pretty close to my original setup. Yes, I have the VTS.
***** I do not have a FT and no chassis brace and saddle packs.
1*toe in - check
0 camber - check
REAR:
24mmride height
Front:
1*toe in - check
0 camber - check
REAR:
3-2 block - broke mine, need a new one so you are using the 3-3?
Front green or white springs - would need to buy, have rear yeallow and front blues atm front blues will work but are a little stiff
24mmride height
1*toe in - check
0 camber - check
REAR:
24mmride height
If you are using the 3-3 block this also makes the truck unstable on entry but will give you better onpower steering and rear traction while accelerating
There isn't really anywhere close to run nitro though, so I got a sct. Fun class to race though and the accommodations at a indoor track blow away most outdoor tracks.
Westcoast raceway is starting to allow 1/8 with 2 cell though so im close to pulling the motor & stuff out of my mbx-5 and replacing it with E gear
Maybe even convert it to a sct and race it, but then I'm back to burning through bodies. Damn! Where did I go with that?
Yes that setup is very close to where I am at currently, very safe base setup to tune from do doubt.
As always, make one change at a time and test...Rinse and repeat until it drives how you want. The only thing I would not change is spring rate balance front to rear, once you have the truck jumping and driving level leave the springs alone and tune with everything else to get it to turn how you want.
I think I just like painting bodies, and if anyone is not good at painting... short course will give you plenty of practice
Other than that looks good to me.
5Likes
