SC10 4x4 Thread
Thanx u guys for the qwik replys. The reason I was asking is that when I back the truck up I hear it click but when I go forward and ez on the throttle I hear nothing unless I get on the throttle or punch it then it clicks and I have the tenioners all the way down so do u guys think I should change the belt out or look at something else?
O yea my clicker is locked down so it is not that
ok im havin a issue at corner exit on power the truck is spinnin out(rear end comes around)at a slow speed, setup is back to 7k front 5k rear32.5 fr 27.5 rr stock slipper with garos exo chassis with stick pack setup.also rear camber has 2mm washers on inner mount and outside on hub.yellow springs fr/rr. does this set up seem ok and how can i remedy that spin out prob.i was thinkin of changing current limiter but i dont want to sacrifice the smoothness and throttle response with current setup. hmmm
I am still on my first belt, and I have had it since the first shipment.
A quick FYI for those who have ordered the ACKbar, the installation manual is posted up on http://www.rcshox.com/instructions/ackbar-installation/
Damn I love this truck!
Sc10 4x4 for sale. Take a look or PM me for more info.
http://www.ebay.com/itm/270859711638...84.m1586.l2649
I am assuing you have no drag break, and no drivetrain drag.Are the barcodes the go to tire? It sounds to me like it may be a tire problem. Have you tried enduros, holeshot2.0 , or dd's? Also, is your rear end loos, or is it over rotation?
marcus I was looking at your youtube videos a few pages back. The track you were running on is similar looking traction wise to some I run on. What setup are you running on it minus the mods you have on the truck
5Likes
