Like Tree5Likes
SC10 4x4 Thread
Old 11-23-2011 | 07:26 PM
  #11386
symmetricon's Avatar
Originally Posted by JEFFs SC10
What effect does shimming the front camber mounts do? Is this shimming by the shock tower or near the hub?
I might be running a hard packed dusty surface this weekend.
You put shims under the the ballstuds mounted at the shocktowers.
Raising the inner mount lowers the roll center, lowering the inner mount raises the roll center...
EFFECTS OF FRONT ROLL CENTER ADJUSTMENT
Front roll center has most effect on on-throttle steering during mid-corner and corner exit.
Lower
• More on-throttle steering.
• Car is less responsive.
• More weight transfer at front of car.
• Better on smooth, high grip tracks with long fast corners.
Higher
• Less on-throttle steering.
• Car is more responsive.
• Less weight transfer at front of car.
• Use in high grip conditions to avoid traction rolling.
• Use on tracks with quick direction changes (chicanes).
symmetricon is offline
Old 11-23-2011 | 07:27 PM
  #11387
socalrcer's Avatar
this is from the manual.
Front Camber Link Length & Number of Washers Under Ballstuds:
Changing the length of the camber link is considered a bigger step than adjusting the ballstud height. Your first setting change on the track should be to try the inside vs. outside locations on the shock tower. Typically shortening the camber link (or lowering the ballstud) will give the front end less grip which is more stable. Lengthening the camber link (or raising the ballstud) will give the front more grip at low speed but it can have slower steering response mid-to -exit of the turns.
XRay has a great offroad tuning guide that is free on their site that goes into a little more detail.
socalrcer is offline
Old 11-23-2011 | 07:29 PM
  #11388
socalrcer's Avatar
Originally Posted by BLbound
We need 11,000+ more posts to catch up to the losi sc thread ...just sayin'
Pat, have you tried out the new chassis yet? 1 post closer to 11,000
Old 11-23-2011 | 07:31 PM
  #11389
socalrcer's Avatar
Here is the link to XRays setup guide. Look for the PDF Offroad and Truggy setup guide
http://www.teamxray.com/teamxray/pro...e=XRAY%20XB808
Old 11-23-2011 | 07:43 PM
  #11390
JEFFs SC10's Avatar
so by raising the ball stud it sounds like I can take some of the steering away which is what i'd like to do.
JEFFs SC10 is offline
Old 11-23-2011 | 07:51 PM
  #11391
MantisWorx's Avatar
The ACKbar works quite well at this too!!
MantisWorx is offline
Old 11-23-2011 | 07:55 PM
  #11392
MantisWorx's Avatar
Originally Posted by tony montana
marcus I was looking at your youtube videos a few pages back. The track you were running on is similar looking traction wise to some I run on. What setup are you running on it minus the mods you have on the truck
sorda confused on what you are asking , my setup without the mods is a moot point as theya ll work together!! what specifically do you want to know?
Old 11-23-2011 | 08:04 PM
  #11393
cbaranski's Avatar
Finally got all the parts to do my chassis with the saddle packs today. Cant wait to try it all out on Saturday.
cbaranski is offline
Old 11-23-2011 | 08:41 PM
  #11394
CoyoteSlash's Avatar
Originally Posted by Chad Smith
Sc10 4x4 for sale. Take a look or PM me for more info.
http://www.ebay.com/itm/270859711638...84.m1586.l2649
What. The ... Is a losi body doing on my truck...
Originally Posted by symmetricon
I had no problem switching to the ft shock bodies and shock shafts using the origional shock cartridge assembly. I did however have problems with a set of new shock cartridges, they would not align when screwed together. I called AE, and they had me send them in, then they promptly rreplaced them for me.
I personaly prefer emulsion style.
After a little pushing and assistance from you guys, I totally prefer the Emulsion. What a 'dead' shock. And it eats the rough track.
Also we can run 10+ min mains and finish the race. That to me makes this truck alot better!
So why are you selling it then?
Yes but our thread has more helpfull people in it. I asked a question on that thread and took more than a day to get a answer back. If I ask a question on this thread look back in 5 min and you got a answer
......SO WHY ARE YOU SELLING IT THEN?
CoyoteSlash is offline
Old 11-23-2011 | 08:53 PM
  #11395
n8b
That little cheat sheet 1fastpede posted on 475 works great for eliminating the spring rub on the shock bodies.
New shocks complete. Butter...
n8b is offline
Old 11-23-2011 | 09:08 PM
  #11396
Grouchman's Avatar
I just installed the Ackbar, that I purchase from you..... What hole is best to start out with?
Grouchman is offline
Old 11-23-2011 | 09:12 PM
  #11397
CraigMBA's Avatar
The one that is a straight line between all the screws.
CraigMBA is offline
Old 11-23-2011 | 09:15 PM
  #11398
do you have parts numbers for the conversion you did.
dougwalter911 is offline
  #11399
lodhammerdin's Avatar
i love this book.
lodhammerdin is offline
Old 11-23-2011 | 09:44 PM
  #11400
Chad Smith's Avatar
Originally Posted by CoyoteSlash
What. The FUCK... Is a losi body doing on my truck...
Nice use of language I am only selling for the money not to buy a losi. I had a extra body laying around and included it with the truck. A average person is not going to care what "name brand" the body is.
Chad Smith is offline
