SC10 4x4 Thread
#3856
Gear up and drive smart. Maybe some thicker shock oil since you will likely be hitting bigger jumps with harder landings.
Our 8th scale track has a bunch of SC guys grumbling that the jumps are too big, and because of the parachute effect of the body (even heavily vented ones) you can't jump that far consistently... My answer to that was "don't try!" double single the triple...take the rythem section as a double double double instead of trying a triple triple....
The guy who won the last race I watched had more consistent lap times than most of the 8th scale guys because he was driving smart, rather than trying to send the truck to the moon...
#3857
Today I decided to set my ride height on both sides of the truck for a true 25mm on both sides, front and rear and discovered that in order to get my ride height even accross the tub I have to go about three more revolutions on the shock preload collars on the battery side.
Seems to me that even though it looks odd when you look at the shock collars this should be the right way to go as the extra weight on the battery side is a constant throughout the stroke.
So, is this the right way to do it or should I split the difference?
#3859
Got bars today! Thanks MadRussian!
Anyway... thinking about trying a Durango SC, anyone have one and wants to trade?
I like the way the AE drives, Best I've driven, the Durango is the only truck I haven't tried.
#3861
Where is everyone measuring ride height from? Where the center chassis intersects the front and rear segments, or under the ends of the car? With the the way the bottom slopes it makes a big differece. Thanks guys.
I'm pretty happy with the way my truck handles on the ground, I just need the truck to land smoother. I am thinking about trying reducing the pack(larger holes in the pistons). Has anyone tried that yet? Results?
#3862
Just about to start the build on the sc10 4x4. I have heard people saying that there diffs in the kit sometimes doesnt come pre-assembled with enough diff fluid in it? If that is the case, is it better to just open the diff up and check? And if the diff doesnt have enough diff fluid in it, should I use more of the stock weight for the diffs, or are people changing to a heavery/lighter diff fluid? Any help would be appreciated
#3863
As for what to put in it, that all depends on your track/driving style/rest of the truck's setup.
Many seem to like 5k or 7k in the back, and between 10k and 60k up front.
I built mine with 3k in both (stock setup) and don't like it at all, but I'm not you and I don't race at your track. I would honestly say try the 3k in the front and back, or 5k in both....get a feel for the truck...then make some small changes.
Several people earlier have stated that this truck rewards finesse driving, so keep that in mind as you learn to drive it. If it isn't handling well, think about the way you are driving it and see if there is any way that you can be more smooth on the throttle and steering.
If I get some time tonight or tomorrow, I will be cleaning them out and replacing it with 5k in the back and 10k up front, then try that out for a few packs. I'm not a fan of making big changes, or lots of them at the same time.
Change one thing...change it by a little bit...see if it helps or hurts.
(Also, remove all the oil from your shocks...remove the screws that hold the piston head on, clean the shaft and the screw with motor cleaner or brake cleaner, locktite the screw, put it back together and let the locktite set...overnight if possible. If you put them back together and fill them with oil before the locktite sets, it never will.... That was the other problem with the pre-built parts. Almost everyone who left the shocks the way they came from the factory have had problems with at least 1 screw backing out)
#3864
Also redo your shocks as well because they are preassembled, and there have been issues with the shocks as well, just read up on how to fix them because I haven't had any issues with mine. I run 32.5w front shocks and 25w rear...........
#3865
The Issue with the shocks is that team associated does not lock tite the shock shaft screw so when the screw backs out the shaft with the oil will come out of the bottom of the shock body.I hate when stuff is pre-assembled because you have to take it apart just in case it wasnt done right
#3866
I actually just looked up on Loctite's site...Blue Loctite threadlocker will set in about 10 minutes, but takes 24 hours to fully cure.
http://www.loctiteproducts.com/tds/T_LKR_BLUE_tds.pdf
Page 2.
#3868
"sometimes" is an incorrect statement. "most of the time" would be more correct. You need these diffs FULL of fluid.... the people assembling the diffs at the factory squirted oil in until it reached the top of the diff, then closed it up...didn't realize/care that there would be air trapped under the gears that needs to be worked to the surface.
#3869
"Proper" way to do it would be to find a way to reduce weight on the battery side or add weight to the RX/ESC side. I remember seeing somewhere back a few bzillion pages that many of the better racers (club and pro) were adding weight to the front left of the truck (I'm guessing in the empty space in front of the transponder mount). I don't think it needed much, but can't recall. 4 scales (1 under each wheel) will tell you exactly how much and when you have it balanced.
I have it setup now by ride height and I'm ignoring the collars. Tonight is track night so I'll know soon if it's going to do anything wierd.
#3870
You are SO lucky you insisted on prepaying, I had 12 ordered, 2 showed.
Now I have 15 fronts and 15 rears backordered, and already 11 spoken for
I would suggest driving a Durango SC 1st and talking to people about it that have one, its not built near as stout as the SC-10 4x4, and has had some issues. Examine the arms, they look like 10th scale buggy arms. That kinda turned me off when they first came out
5Likes
