Like Tree5Likes
SC10 4x4 Thread
Old 05-02-2012 | 03:39 PM
  #22531
Originally Posted by n8b
After working on my original truck and then building the ft kit the ft did feel stiff. Even after backing the case screws out. After one pack it went back to a normal feel.
OK cool. Mine is the FT kit, I forgot to add that.
straycat40 is offline
Old 05-02-2012 | 03:44 PM
  #22532
fq06's Avatar
fgO6
8mm is just right , helps stop the CDA's from hitting out-drives on hard landings...
Oh yeah, I guess that is figuring in the rubber bumper on the shaft. I run a 1mm & 2mm clip under the rubber bumper.
I guess that rubber bumper thing must be 5mm?
fq06 is offline
Old 05-02-2012 | 04:00 PM
  #22533
BlueGlowBoy's Avatar
fgO6
And hard cornering....or landing on one corner....
BlueGlowBoy is offline
Old 05-02-2012 | 04:22 PM
  #22534
fq06's Avatar
Yeah, hard flat landing is not a problem. It's when you land on one wheel and push it up to full compression.
I was thinking 8mm of clips and was like... what?!?!
fq06 is offline
Old 05-02-2012 | 04:23 PM
  #22535
Evil Genius jr.'s Avatar
Up travel limiters servilely limit performance on my bumpy track, anything else I can do?
Evil Genius jr. is offline
Old 05-02-2012 | 04:25 PM
  #22536
fq06's Avatar
Not that I've seen. You need to limit the up travel to where under full compression the cvd nor the a arm is hitting the outdrive or you will be replacing the sun gear washer every 2 races.
Rubber bumper + 3mm of clips keeps my diffs happy.
Edit: you don't notice the limiters if you land flat, only if you land on one tire and you have other issues with your lap time if that happens because you will be squirrely on your landing anyway.
fq06 is offline
Old 05-02-2012 | 04:31 PM
  #22537
fq06's Avatar
Relocate the diff 8mm higher?
fq06 is offline
Old 05-02-2012 | 04:33 PM
  #22538
Are you limiting it too much? Do you have the boots AND 8mm of limiters installed? Without the boots, 8mm seems to be the magic number....not sure what to use with the boots.
You can either limit up-travel by putting the spacers on the shock shafts, or just let the CVD hit the out-drive....either way, your uptravel will be limited essentially the same. The difference is that one way will damage your sun gear, diff housing, your out-drive, and your CVD....and the other won't.
I set my up-travel by fully compressing the shock, then turn the wheel....if the out-drive catches on the CVD, add 1mm. keep going until the outdrive no-longer binds on the CVD. Golden.
Old 05-02-2012 | 04:34 PM
  #22539
lol.
The track is so bumpy that if I add limiters it bounces around. I will try it with the 2 stage pistons installed and see how that works.
Old 05-02-2012 | 04:37 PM
  #22540
JEFFs SC10's Avatar
GeeZ how bumpy is it?
JEFFs SC10 is offline
Old 05-02-2012 | 04:38 PM
  #22541
This bumpy:
Old 05-02-2012 | 04:40 PM
  #22542
Wild Cherry's Avatar
lol.
If you do ?
Only have the same suspension travel as with out limiters...
try a softer spring or a lighter oil ....
Wild Cherry is offline
Old 05-02-2012 | 04:41 PM
  #22543
Thanks I will,
Running 30/25 w/ 2-stage for the first time.
Have yellow/B4.3s but will try Blue/FWhite also
Old 05-02-2012 | 04:42 PM
  #22544
JEFFs SC10's Avatar
The two ways with 25-27.5 wt oil will help, the rebound on these is great.
Old 05-02-2012 | 04:43 PM
  #22545
fq06's Avatar
lol.
You gotta limit the uptravel to preserve you sun gear washers so your stuck with that.
The 2 stagers should help with a real bumpy track because there it allows the suspension to come back down faster to deal with the next bump. Standard pistons will have your suspension higher up in the travel with less up travel ready to absorb the next bump.
Try them, I have them on all of my offroad rc's. It was a huge difference on my mugen mbx-5.
fq06 is offline
