SC10 4x4 Thread
I don't what to come across saying bullet connection's don't perform well ..
However just feel how hot they get after a run and you will see they offer only more resistances to current flow.
Bullets between the motor & ESC produce more load & heat on the ESC , battery & motor ...
not much more (heat) mind you , but you can notice for sure.....
Wires A/A B/B C/C like Coyote mentions is essential since the sensors inside rely on this!
In a sensorless set up, swapping wires is not a problem since there is no sensor to deal with.
Most motors will go up to 170F without worry about failure, but that is as high as I'd push any of my (non-LRP) motors. (LRP motors tend to run hotter, but can withstand the extra heat.)
I don't have experience with the Reedy motors though. I know that back in the Brushed days, they were one of the better motors, but brushed and brushless are two different monsters.
Got it running the correct direction now. It was set to "reversed" in the castlelink software. Now in "normal" all is good. All I have to do now is get these new promatch 5000 50c's charged so I can see what breaks next! Yee haa! These trucks are a bit spendy.....
Thanks for the suggestions; I'm glad I didn't fry anything in the process.
pinned mod
ok i found the page with the pin mod explanation but can someone tell me how this works better. isnt the shaft and slipper plate already squared off so it doesnt turn on the shaft. so what exactly is the pin doing then??
Nobody ever runs a big race on a track like that, but a lot of us race on tracks like that week in and week out.
Better? Some like it some don't depends on your driving and track. I personally did not care for it.
Team Associated SC10 4x4 Carbon Fiber Chassis Brace & Heavy Duty Ends Kit
Finished up building some braces. I know others build these, but they are thinner and glue screws into the shaft. Mine are threaded into aluminum.
http://www.flickr.com/photos/49053815@N03/6708820819/
http://www.flickr.com/photos/49053815@N03/6708820931/
The brace kit removes chassis flex, which causes belt slippage, premature wear, or loss of the belt. The brace is also essential for high grip applications such as carpet or asphalt. The kit comes assembled with the rear mounting screw and locknut. Use what the pros use.
Three simple steps:
1. Remove front underbody mount and install brace end with screw.
2. Mark rear hole and drill through transmission brace with a 1/8" drill (not supplied).
3. Install brace with the supplied screw and locknut.
That's it! You are ready to race.
$18 with free shipping. Lower 48 states and to a verified address.
PayPal to: [email protected]
Shipment within 1 to 2 business days after payment.
If you have any questions check out our Facebook page or contact Jarodd at [email protected] or 607-316-1798.
Three simple steps:
Looking ace mate !!
Tp
Tp
No I temporarly gave up on that and for the same reasons Cherry stated a few post back.
For me the truck is more consistant driving through and out of corners with the standard pulley. The 19 give more on power steering but was causing over steer for me ocationaly because your steering was also depended on how much power you applied out of the corner. Video of my truck occationaly would do a "S" where I would apply throttle, oversteer then I would straighten up and need to correct to continue straight. I also found the truck to get loose under hard braking on our layout. 20t is more consistant for me and my lack of "Pro" driving skills; maybe for the right track I would try it again.
Trader Rating: 77 (100%+)
Three simple steps:
Shipping only to lower 48 states and to verified address.
Three simple steps:
Updated with price. $18 with free shipping to lower 48 states.
Is there a chassis brace that doesn't use the underbody holes to mount to? I have to run a underbody, I get too much track dust, clay, loam, sand, etc underneath and want to protect my electronics.
