Like Tree5Likes
SC10 4x4 Thread
Old 02-13-2012 | 07:05 PM
  #17446
Wild Cherry's Avatar
Originally Posted by heavyjeffd
I run everything at 100% on the esc and turn it down as needed on the radio. Easier that way.
more betta to adjust
drag brake with ESC .....
radio way ?
could go forward on the throttle trim , works , has limitations as it effects the throttle performance ....
Wild Cherry is offline
Old 02-13-2012 | 07:06 PM
  #17447
lodhammerdin's Avatar
Originally Posted by sedemente
Was at the local track Friday night and Fast Lap Products was testing a new front slipper hub. Looks interesting.I talked to Billy and he has been testing this for about 6-10 weeks . Final version is done.
Hmm... now this is intriguing...
lodhammerdin is offline
Old 02-13-2012 | 07:09 PM
  #17448
Cameron Kellogg's Avatar
Originally Posted by JEFFs SC10
hey guys , someone try this setup out. this is what cav and maifield ran at the reedy race. notice how there truck jumps.
http://www.youtube.com/watch?v=qkYpT...eature=related
setup http://www.teamassociated.com/pdf/ca..._Cavalieri.pdf
did you miss the 12 pages of everyone bashing Wild Cherry because he said that was a good set up and to try and run it to fix the jumping problem.
Cameron Kellogg is offline
  #17449
Your using to much battery that way. I was told by someone very knowledge with Tekin that
you should always have everything turned up all the way in your radio, and regulate your power through the speedo. More so with throttle then brakes. I do fine tune my brakes with my radio.
Mark K is offline
Old 02-13-2012 | 07:15 PM
  #17450
Orion drivers have their brakes set to 65 on the speedo and then adjust on the radio. I have done the same with the new Tekin 222 software and found the braking power to still be very good more modulated when using them. Brakes on the radio turned down to 80 from 100. Drag brake 10 to 15.
Old 02-13-2012 | 07:27 PM
  #17451
Originally Posted by SC-Racer
I would like to try a Sonic 550 can in my truck. I am thinking the 5.5 will be all thats needed. Does this sound correct? I would also like to stick with a LRP esc. What model do I need with a sonic 550? Thanks for the help.
I currently run a reedy 550 4.5 with my lrp tc spec v2. SUPPPPPER smooth, tons of power and torque anywhere in the power band. What size track do you run on?
Old 02-13-2012 | 07:47 PM
  #17452
JEFFs SC10's Avatar
oh I didn't know he was referring to this setup.
hahah yea I remember that lynch mob LOL.
I know those jumps aren't as big but look how they nice they are jumping. Notice how much of the back is cut out of Steve Hartson. I don't believe there was any wind and that does matter.
The big jumps in that vid are about the size I run on here. I do believe its how you come off the jump with throttle on or let off as you leave. Everybody that runs here when they go nose up, hit the brake the and the nose comes down. Of course these are Ofna's and Losi's though.
JEFFs SC10 is offline
Old 02-13-2012 | 08:06 PM
  #17453
heavyjeffd's Avatar
radio way ?
Drag brake?
I don't run drag brake on anything except maybe 2wd buggy, even then I don't always.
heavyjeffd is offline
Old 02-13-2012 | 08:07 PM
  #17454
heavyjeffd's Avatar
Maybe, however battery isn't an issue. A 10min main doesn't even use 50% currently.
Old 02-13-2012 | 09:40 PM
  #17455
sugs's Avatar
That has not happened to me, but it did happen to a buddy of mine.
Comparing trucks the only difference was I always lube the whole axle/retainer cover/CVD assembly every time I do maintenance. His was dry. I use that Lucas "Sticky" red grease.
Maybe there was accelerated parts wear due to lack of lubrication? Just speculating.
Yeah, I don't lube mine at all. I'll take a closer look at a new retainer and the old one and try to compare the two. Couple other guys at the track I race at have had the same problem.
sugs is offline
Old 02-13-2012 | 10:19 PM
  #17456
IRM616's Avatar
I wonder what a center diff and ft basket will do?? Any ideas
IRM616 is offline
Old 02-13-2012 | 10:27 PM
  #17457
CoyoteSlash's Avatar
That doesn't make sense.
CoyoteSlash is offline
Old 02-13-2012 | 10:34 PM
  #17458
ilanstylz's Avatar
I think he may be talking about Mantis center diff, along with this front hub possibly?
http://www.fastlapproducts.net/Products.html
ilanstylz is offline
Old 02-13-2012 | 10:37 PM
  #17459
IRM616's Avatar
Yes, that's what I mean
IRM616 is offline
Old 02-13-2012 | 10:48 PM
  #17460
Default Fastlap front slipper.
More info on thebigrc
thebigrc.com
