Like Tree5Likes
SC10 4x4 Thread
Old 02-05-2012 | 06:40 AM
  #16636
symmetricon's Avatar
Originally Posted by bohdi
Sorry you had a bad day but nowhere did anybody state the track would open at 8 for practice. I also had the diff and did much better in SC than I ever thought placing 2nd in the B only to get booted by the bigger Losi' at the start and then made stupid mistakes and lost a great opp to make the A.
Sounds like you are making the same conclusion about the truck I did 60 or so pages ago but got flamed for
what place did you finish in the b main? if you got second you should have gotten the bump.
were you the guy with the camo hat working your ass off by the big triples after the b main?
symmetricon is offline
Old 02-05-2012 | 06:56 AM
  #16637
Ok WC, just watched some Trcr vid of your track, and its not even close to what we have to deal with down here in H-town. Trcr is a nice looking 1/10 track that is nice a smooth. Our track, well is a completly different beast. The speed bumps in the chicane are bigger than any jumps I sam at your track.
  #16638
1Fastpede's Avatar
this is why I like my pin. makes air control easier.
1Fastpede is offline
Old 02-05-2012 | 07:03 AM
  #16639
No, I started 2nd and fell apart in the main. Lost my aggression, played is safe and screwed up? Finished 7th.
bohdi is offline
Old 02-05-2012 | 07:06 AM
  #16640
MantisWorx's Avatar
We called the track thursday and were told by the manager that the track would be open for practice at 8, about a dozen of us were told the same thing!
As Sym stated high speed long jumps are not this trucks forte well except for Wild cherry's magical FT with Ryan and Cody's golden signatures embossed in gold on each tire with wireless electronically controlled gyros that keep the truck level no matter what
SO Cherry lets see some video. You talk alot of smack for someone with no proof! I promise i will beat you on any track at anytime especially if you run that setup.
MantisWorx is offline
Old 02-05-2012 | 07:08 AM
  #16641
MantisWorx's Avatar
we tried that and it was the same, absolutely no difference.
Old 02-05-2012 | 07:11 AM
  #16642
MantisWorx's Avatar
Ok WC, just watched some Trcr vid of your track, and its not even close to what we have to deal with down here in H-town. Trcr is a nice looking 1/10 track that is nice a smooth. Our track, well is a completly different beast. The speed bums in the chicane are bigger than any jumps I sam at your track.
well that absolutely cannot be possible, you and I are both are stupid and dont know how to drive I mean a jump is a jump and wind has no effect on short course trucks..........
Old 02-05-2012 | 07:16 AM
  #16643
MantisWorx's Avatar
well anyway ,time to move on and fix the issue. What do you guys think about an idler gear and reversing the motor? pretty easy to do and worth a shot, it will either get better or worse!
Old 02-05-2012 | 07:21 AM
  #16644
How bout getting rid of belt drive all together
rickybobbyxxx is offline
Old 02-05-2012 | 07:25 AM
  #16645
Matt Howard's Avatar
I hate it when the bums hang out in the chicane
Matt Howard is offline
Old 02-05-2012 | 07:43 AM
  #16646
Cain's Avatar
are these issues being seen with the regular chassis too? Just asking as it seems everyone confirming the same issue seems to be running the exotek chassis.
Cain is offline
Old 02-05-2012 | 08:07 AM
  #16647
Cameron Kellogg's Avatar
If I am thinking correct the motor rotation torque is throwing weight forward? So the idler would move it back?
Team Losi drivers here run their trucks run ride height at 27mm. This helps them jump! Sounds like a little thing but it does give the truck more hop. Makes the SC10 flip over all the time though.
Cameron Kellogg is offline
Old 02-05-2012 | 08:39 AM
  #16648
marksp's Avatar
Originally Posted by Misfit138
I cut the tab off the ESC side and ground off about 2mm on the receiver side.
Where the reviver box and ESC sit plus having the battery straps secure the batteries won't go anywhere. I'm going to put a thin piece of foam on my ESC as a buffer between the battery and it.
Brilliant, thanks!
I'd much rather trim the Exotek saddle mount, than hack up my RX8. Eye balling it looked like it could fit with some trimming, so thanks for the confirmation and picture! Appreciate it!
Cheers
marksp is offline
Old 02-05-2012 | 08:41 AM
  #16649
Farmer_John's Avatar
I really thank Marcus for all the hard work he's put into trying to make this a better platform and he has accomplished offering options for many setups.
But let's be honest with each other. This truck (or any other SC truck 2 or 4wd) was not designed with supercross style 1/8th scale tracks in mind.
The jumps Buggys and truggys laugh at, SC trucks struggle with or at best are inconsistent with.
I ran both my E buggy and SC104x yesterday, I pretty much flew the buggy and drove the SC. Although I'm not the fastest apple in the basket, I'm a fairly consistent driver with both (CQ'd and won the..C in SC and qualed 4th, finished 3rd in the Ebuggy...C. Lap times within a second of each other.).
I'd rather double single a triple CONSISTENTLY than alternately spiking/casing/flatlanding a triple designed with a much heavier, easier to control in the air car/truck in mind.
Simple truth: You can't accelerate in the air. Get it up and back down as quickly as possible. BTW, our scale like trucks look more scale like when driven with this in mind.
K. I. S. S.
Oh, the only "mod" beyond swaybars I've done so far have been Marcus' Garodiscs. Perfect. Though I still want to try the center dif and feel a need for a center brace. YRMV.
Farmer_John is offline
Old 02-05-2012 | 09:08 AM
  #16650
SCTDan's Avatar
well... I started in 10th in the B main, and finished 4th.Not bad considering the amount of skilled drivers at the race. There was not 1 ae truck that could clear the triples, and no ae could clear the quads consistently. I believe only 1 ae quaified into the a main, and one ae got the bump. The changing track conditions made it real hard to get consistency from round to round, or making noticable adjustments. I even tried to run without the center diff, and found I was 1 sec slower per lap on average. My real problem was that I could not get the truck to jump consistently at WOT of the big jumps. sometimes it would go nose up, sometimes nose down. In either case, I could not correct the truck with throttle or break imputs. I tried approaching th jumps evrey way, on throttle, off throttle, and everything in between. I have never had such a hard time driving my truck hard. I am discouraged that I couldnt drive it like i wanted to. On a good note, I had no breakages at all.
Just throwing out an idea but what about adding lead foil inside the wheel rims to add rotating mass. It may help with in air adjustments. Not sure how it would effect handling.
SCTDan is offline
