Viper RC -
#3691
#3693
Pardon my ignorance...
In theory, given the same battery and gearing (2s, in this case) a lower KV motor would net a smoother throttle response and more top end vs a higher KV which would net a better bottom, with limited top end, perhaps even a shorter powerband... But the higher KV motor would likely generate more heat. < Is this thinking correct?
I have a friend who is looking for a new system and might be interested in the CopperHead, Thx to the great price point.
base your motor buying on watts not mainly off KV even more so when buying a spec class motor 13.5, 17.5 etc
#3694
#3699
The VX4.39 is a 540 4-Pole motor that would legal for racing though.
As far as a comparison the R.51 would be a little bit more power, and the R.45 would be about the same, and similar driving characteristics. The Copperhead/VX4 systems are sensor-less, but allot of R&D has been done to make the systems as smooth and drivable as a un-sensored system could be. During testing, drivers reported that the systems were just as smooth as sensored systems.
#3700
Congrats to ending the wait and making (some) Copperheads are available! Would you give a it more detail on the motors? I am most interested in magnet size and winding of the different versions. Also will a 5mm shaft version or optional rotor be made for the 540 size version?
#3701
Just converted an 810 to electric and looking at motors/esc's. I have a MMP and 3800 sitting here. Not sure if I should try running that or get a new Copperhead system.
I am trying to keep this as light as possible and would like to run on 2s, maybe 3s, but trying to stay with 2s. I don't plan to race it, just run it on 2 tracks. Both are outdoor, one is pretty small, the other is a medium/large size track.
I know this is the Viper thread, just thought I would ask for some opinions.
#3705
Check your local rules first. Both the VX4R.45 and VX4R.51 are 550 series motors, but of a 4-pole design. ROAR does not allow 4-Pole 550 Motors in the 4wd SCT class, but allot of the places in the country allow it. It just would not be legal at a ROAR event.
Also ROAR rules will not apply to this system becaust it is not a pro race system although it will perform just as well as other systems. Our aim was to provide a budget system that you can race at club/race level.
If you have any questions please let me know.
4Likes
