SC10 Thread
Old 01-29-2012 | 05:00 PM
  #9451
Mizchief's Avatar
Originally Posted by ovalracer1m
The Epic D3 17.5. Runs cooler and more bottom end than any 17.5 i have ran
Old post but I can +1 that! I'm running 28/75 with the MMP using 20deg boost on smartsense and have the motor set to the 3rd to last tick mark, and still coming in under 110 after about 10 mins of almost all full throttle.
I'm not sure where to go from here, I want more midrange power and top end speed, should I go up in gearing and stick with smartsense or dial up more boost using the C.H.E.A.T settings?
Mizchief is offline
Old 01-29-2012 | 07:00 PM
  #9452
trickedout's Avatar
Well if your only at 110deg then you can prolly gear up a a couple and try that. or you can Boost it. I run mine 25/75 cheat mode 5200-17000 at 45deg of timing and full timing on the can. Its EXTREMELY fast and still plenty cool for me. about 140-150 after 5min.
trickedout is offline
Old 01-29-2012 | 07:33 PM
  #9453
Originally Posted by mark in wi
Just wondering if you can help me compare my shock set up to another. I am running the FT setup of #1 ft and #3 pistons rear with 30wt all around. Blue spring in front silver in the rear. Compared to 32.5wt in front 27.5 wt rear with #2 pistons all around and blue front and green rear springs. About how different are they?? What will the difference in handling be like??
I'm trying to compare my setup to someone else who probably knows a little more about setup. Thanks
Mark
Anyone??
Am I close thinking that a change from one piston to the next equals approx. 5wt change in oil; example a #2 to a #3 is about the same as going to 5wt thinner oil?? Or am I way off??
Any help is greatly appreciated!!
Mark
mark in wi is offline
Old 01-29-2012 | 07:39 PM
  #9454
what K spring is close to the ae silver rear?
Brandon Powell is offline
Old 01-30-2012 | 06:28 AM
  #9455
kc_nitro_rc's Avatar
Anyone??
Mark
Theoretically you are correct. I prefer going to the #2 piston in the rear to give it more 'pack'. Depending on the track you race on you might even want to go with the #3 (smallest) piston up front.
Changing piston changes 'pack'. This is what you adjust to keep the chassis from slapping after a jump. (Of course how you 'downside' a jump will too.)
kc_nitro_rc is offline
Old 01-30-2012 | 06:46 AM
  #9456
Asharus's Avatar
Originally Posted by supergleep
Bit of an old post, but since I didn't see anyone reply to it, thought I'd post up the answer since I replaced the screws in my JC Hex hubs today. The hubs use a 2mm x 4.5 screw stock and that gets you about 2-3 threads worth of engagement. (read: just enough to strip out.. ask me how I know )
I went to my LHS and found a 2mm x 6 Dubro screw that fits perfectly and engages all the threads and allows you to actually clamp them down as designed.
Thx for the info. I actually picked up ASC31511 M2x5mm capheads because I noticed the screw on the AE clamping hexes for the TC6 are the same as the JC hexes. I haven't tried them yet since it's just for my spare hex set. I don't even race my SC10 anymore so it may be a while before it even gets used.
Also, I have not seen anyone strip the actual hex, just the screws. It's odd because some of the capheads that it comes with are fine, but some do not go as deep as the others which is what causes the screw to get rounded out.
Asharus is offline
Old 01-30-2012 | 06:54 AM
  #9457
AlanHall's Avatar
Got to race my sc10 for the first time Saturday. Indoor clay track. Kinda bumpy. And would get a thin layer of light dust and get loose... ran blue fronts green rears with 32.5 f/r .. sooo hard to drive. Could anyone explain why when I put on silver and gold springs and stiffened it ,it got so much better? It didn't make sense to me. . but I tried it.possibly just my driving style? I grew up racing touring.. then recently raced 1/8th truggy. So im used to having a decent bit of traction. This 2wd stuff is crazy lol
AlanHall is offline
Old 01-30-2012 | 08:23 AM
  #9458
Lake Ober's Avatar
Hey guys,
I was searching around online and found what looks to be a nice aluminum steering servo saver set by Hot Racing http://www.toadzrc.com/aluminum-stee...c10-b4-t4.html
Has anyone tried this part by any chance? I'd be interested to give it a try... I've always thought the quality of HR stuff was pretty decent. Well, let me know what you guys think.
Lake Ober is offline
Old 01-30-2012 | 09:16 AM
  #9459
Chad Smith's Avatar
Originally Posted by Lake Ober
Hey guys,
Hey Lake, that looks nice I might have to pick one of those up
There is a ton of slop in the stock setup so that aluminum steering setup will definatly help with that promblem.
Chad Smith is offline
Old 01-30-2012 | 09:21 AM
  #9460
Lake Ober's Avatar
I know a guy on here who has a huge sale listing, and in it is (3) of these, brand new. I asked him what he wants for one of them, and he said he wants to sell all 3 of them together for $50 shipped. If you are seriously interested in them, I maybe can get him to sell 2 of them to me. Let me know, they'd prolly be like $20 each. No pressure, just thought I'd ask
Old 01-30-2012 | 09:29 AM
  #9461
Asharus's Avatar
He's probably selling them to get the new Avid solid steering set
Asharus is offline
Old 01-30-2012 | 09:41 AM
  #9462
Mizchief's Avatar
I got my set on the way!
Mizchief is offline
Old 01-30-2012 | 09:45 AM
  #9463
Lake Ober's Avatar
Haha, yeah possibly I was looking at the Avid one (looks sick!), but deided against it because of it's solid design. I am still fairly new to the sport of indoor R/C racing (been a basher for years) and still hit the walls quite frequently with my SC10. I read a few reviews online about the Avid one, that says it isn't very good for people whom aren't advanced drivers, b/c it puts all the stress onto the servo itself instead of the saver spring. I'm not sure if this HR steering set has a spring in it (it looks like it does), but if it doesn't, I may still get it and just hold on to it until I get a bit better at driving
Old 01-30-2012 | 10:17 AM
  #9464
Asharus's Avatar
Just glue your saver for now. A glued saver still has plenty of flex to absorb impacts but you will benefit from a more consistent feel. Then go with the solid setup once you feel more confident
Asharus is offline
Old 01-30-2012 | 10:22 AM
  #9465
Cain's Avatar
ran my sc10 with the GPM servo saver setup.
Loads of steering now, had to dial down the EXP on the servo as there was so much of it. for the price of it (I think it was $14 shipped), works quite well. I also did NOT use the center link. Kept the plastic for a bit of flex.
Cain is offline
