SC10 Thread
#9451
I'm not sure where to go from here, I want more midrange power and top end speed, should I go up in gearing and stick with smartsense or dial up more boost using the C.H.E.A.T settings?
#9452
Old post but I can +1 that! I'm running 28/75 with the MMP using 20deg boost on smartsense and have the motor set to the 3rd to last tick mark, and still coming in under 110 after about 10 mins of almost all full throttle.
#9453
Just wondering if you can help me compare my shock set up to another. I am running the FT setup of #1 ft and #3 pistons rear with 30wt all around. Blue spring in front silver in the rear. Compared to 32.5wt in front 27.5 wt rear with #2 pistons all around and blue front and green rear springs. About how different are they?? What will the difference in handling be like??
I'm trying to compare my setup to someone else who probably knows a little more about setup. Thanks
Mark
Mark
Am I close thinking that a change from one piston to the next equals approx. 5wt change in oil; example a #2 to a #3 is about the same as going to 5wt thinner oil?? Or am I way off??
Any help is greatly appreciated!!
Mark
#9455
Changing piston changes 'pack'. This is what you adjust to keep the chassis from slapping after a jump. (Of course how you 'downside' a jump will too.)
#9456
Bit of an old post, but since I didn't see anyone reply to it, thought I'd post up the answer since I replaced the screws in my JC Hex hubs today. The hubs use a 2mm x 4.5 screw stock and that gets you about 2-3 threads worth of engagement. (read: just enough to strip out.. ask me how I know
I went to my LHS and found a 2mm x 6 Dubro screw that fits perfectly and engages all the threads and allows you to actually clamp them down as designed.
)I went to my LHS and found a 2mm x 6 Dubro screw that fits perfectly and engages all the threads and allows you to actually clamp them down as designed.
Also, I have not seen anyone strip the actual hex, just the screws. It's odd because some of the capheads that it comes with are fine, but some do not go as deep as the others which is what causes the screw to get rounded out.
#9457
Got to race my sc10 for the first time Saturday. Indoor clay track. Kinda bumpy. And would get a thin layer of light dust and get loose... ran blue fronts green rears with 32.5 f/r .. sooo hard to drive. Could anyone explain why when I put on silver and gold springs and stiffened it ,it got so much better? It didn't make sense to me. . but I tried it.possibly just my driving style? I grew up racing touring.. then recently raced 1/8th truggy. So im used to having a decent bit of traction. This 2wd stuff is crazy lol
#9458
Hey guys,
I was searching around online and found what looks to be a nice aluminum steering servo saver set by Hot Racing http://www.toadzrc.com/aluminum-stee...c10-b4-t4.html
Has anyone tried this part by any chance? I'd be interested to give it a try... I've always thought the quality of HR stuff was pretty decent. Well, let me know what you guys think.
#9459
Hey guys,
There is a ton of slop in the stock setup so that aluminum steering setup will definatly help with that promblem.
#9460
#9463
Haha, yeah possibly
I was looking at the Avid one (looks sick!), but deided against it because of it's solid design. I am still fairly new to the sport of indoor R/C racing (been a basher for years) and still hit the walls quite frequently with my SC10. I read a few reviews online about the Avid one, that says it isn't very good for people whom aren't advanced drivers, b/c it puts all the stress onto the servo itself instead of the saver spring. I'm not sure if this HR steering set has a spring in it (it looks like it does), but if it doesn't, I may still get it and just hold on to it until I get a bit better at driving
#9465
ran my sc10 with the GPM servo saver setup.
Loads of steering now, had to dial down the EXP on the servo as there was so much of it. for the price of it (I think it was $14 shipped), works quite well. I also did NOT use the center link. Kept the plastic for a bit of flex.
