SC10 Thread
Old 01-30-2012 | 09:24 PM
  #9481
JKrc717's Avatar
Originally Posted by AlanHall
Thanks. It wasa actually my first time ever running . I just tried different tires every round. We were indoors .. and ut was a little cooler out. I think alot maybe had to do with the bar codes being orange softs.instead of the ss green or new soft blue . Most have good luck with wishbones ..pressure points ..gridirons and subcultures. I think im going to get ss bar codes and double dee ..and maybe holeshots for next time.
Yes, try some green barcodes. I have used them on clay with good result... Orange is more for high temp outdoor blue groove. Also, referring back to your post on springs, try green out back and silver in the front, I never have had very good luck with green and blue, but green and silver seem to be a better balance for me..
JKrc717 is offline
Old 01-30-2012 | 11:44 PM
  #9482
wcrase101's Avatar
Originally Posted by kc_nitro_rc
Short as possible. Inside should be closest to center of chassis. That hole should be right about or near where the A-arm mounts. Then out by the wheel it will be the one closest to the chassis.
cool thank you will give it a try
wcrase101 is offline
Old 01-31-2012 | 12:43 AM
  #9483
CoyoteSlash's Avatar
What are you guys doing to stop the Torsional Flex?
Example: http://www.amainhobbies.com/product_...Fiber-Top-Deck
The Flex on this thing is insane, and mine's a FT Kit. I thought the Carbon Chassis would solve it. Heck no. I keep hearing how guys put that brace on their Kyosho's (PRCR) and they can start driving them like 2wd Buggies and fall in love with them.
What are we doing? Anything?
CoyoteSlash is offline
Old 01-31-2012 | 05:22 AM
  #9484
AlanHall's Avatar
I dunno. Buy I notice my battery strap fits so tight I figure it tweaks or supports the chassis some. I dunno if promatch uses bigger cases or what. But it puts the strap in a fever bind when I tightened the thumb screws
AlanHall is offline
Old 01-31-2012 | 05:31 AM
  #9485
AlanHall's Avatar
Thanks man. Tower sells them as soft. And that how JC marks the package. So I assumed they were a step over greens.. like the blues that just came out. So now jc has two tires labeled soft...I used paragon on them and softened them alot.
AlanHall is offline
Old 01-31-2012 | 06:01 AM
  #9486
Lake Ober's Avatar
Has anyone ever cut off the left and right side of their rear bumper with a dremel before? The best guy at my LHS did it to his LOSI XXX-SCT, and made me curious. Then, I saw it done again on an FT SC10 here: http://www.rctech.net/forum/r-c-item...es-extras.html
I thought it might help (and looks cooler IMO), b/c it wouldn't hit the ground as easily when landing from a jump weird... and also my body has cracks on it on each side, where it appears it is hitting the left and right side of the bumper. Let me know if anyone has done this
Lake Ober is offline
Old 01-31-2012 | 06:38 AM
  #9487
monty c's Avatar
From: Dont get any more northwest than me..........
yes, i have chopped mine. just used some snips and removed the sections with the mud flaps. not so much about hitting the ground, but it was destroying the body.
monty c is offline
Old 01-31-2012 | 06:40 AM
  #9488
Cain's Avatar
Tech Legend
my FTSC10 came with those parts cut off.
It does save the body from getting damaged back there.
Cain is offline
Old 01-31-2012 | 07:27 AM
  #9489
I trim my rear bumper to help save my bodies. The stock size bumper does a number on the tail light sections of bodies...tears it up on the very first run. And you don't have to use a dremel. Just some wire snips should cut right thru the plastic.
jamr1130 is offline
Old 01-31-2012 | 07:49 AM
  #9490
CraigMBA's Avatar
I did it so the mount would stop tearing up the body. On my 4w, it's helpful to let the body deflect a little more when you get that "Losi Push".
Was successful on the first part, not so much on the second part.
CraigMBA is offline
Old 01-31-2012 | 08:35 AM
  #9491
Lake Ober's Avatar
Sounds great... I'm gonna Dremel it off right now then. I'm glad to see others had problems with it screwing up the rear of their bodies as well, and it wasn't just me. I ran my new body 2x with the stock bumper, and now I had to shoe-goo 6 different spots on the rear. Hopefully this will help
Old 01-31-2012 | 08:47 AM
  #9492
CraigMBA's Avatar
Kinwald made some side plates that screw to the chassis. I built some, and it knocked the deflection down, but...my truck didn't handle any different.
Frankly, I think velcroing the sides of the body to the nerf wings may do more to help this than anything else. It's got tons of leverage, and the load path is already there - all you have to do is connect it. And the truck stops sounding like you kicked an empty 5 gallon bucket when it lands off jumps.
CraigMBA is offline
Old 01-31-2012 | 08:55 AM
  #9493
Wild Cherry's Avatar
Tech Legend
Winning ......
Hey Craig !!!
Those plates you see are only for ballast ...
Wild Cherry is offline
Old 01-31-2012 | 09:26 AM
  #9494
Mizchief's Avatar
These trucks are so light I don't think it's going to flex enough to make a difference.
Mizchief is offline
Old 01-31-2012 | 09:34 AM
  #9495
CraigMBA's Avatar
I agree. Their effect on torsional stiffness was minimal, all they did was add weight, so IMO there can't be another rational reason to use them.
CraigMBA is offline
