SC10 Thread
Old 01-14-2012 | 08:09 PM
  #9001
Can someone post some tips on how to get rid of some of the slop in the steering of my SC10? Thanks.
Delawareguy is offline
Old 01-14-2012 | 08:17 PM
  #9002
CraigMBA's Avatar
Originally Posted by JEFFs SC10
Can upload a pic of your truck?
Sure.
What track conditions did you run on?
Hardpacked smooth/open track that veried between dry slick/w marbles on top and medium traction depending on when the water got there.
How did it feel?
Not as good as it did with blues and greens.
CraigMBA is offline
Old 01-14-2012 | 08:23 PM
  #9003
i got my truck in a trade, so idunno whats inside...guess i better pull it apart..
Originally Posted by njnewc
I've seen this on another forum and it's caused by people trying to put an old T4/B4 ball diff into the new SC10/T4.1/B4.1 diff case, which doesn't work because the case and outdrives have changed (as Asharus explained). There are two solutions:
1) Buy new outdrives and bearings. This is a fairly expensive route.
2) Buy the T4/B4 ball diff case and a T4/B4 rear chassis plate. This is really cheap (5-6 bucks), but could leave you or a future owner very confused.
I hope this helps./QUOTE]
I have purchased a brand new updated F/T ball diff, I purchased all brand new bearings straight out of the F/T parts breakdown and I purchased the case out of the same catalog. It does not fit. I have since purchased a ball diff case that was taken out of a F/T kit off of ebay. Hopefully this will solve my issue.
Biznak is offline
Old 01-14-2012 | 08:26 PM
  #9004
CraigMBA's Avatar
Originally Posted by Brian L
Craig-Did you run the buggy springs or did you find some truck ones? Haven't been able to find the 22T springs yet.
22 and 22T springs are going to be the same. Here is a link to the parts you need:
http://www.rctech.net/forum/10092874-post8971.html
Originally Posted by Bob Barry
Parts needed for Losi Big Bore Spring conversion
RPM spring collar #70322 / Traxxas version #3768 (use either or)
TLR Ft 12m spring , silver #5174
TLR Rear 12m spring , pink #5168
TLR Rear 12m spring , yellow #5167
TLR 12m spring cups #5095
yellow rear if you need more traction
TLR5169 Red (more steering)
TLR5170 Orange (less steering)
You need the TLR spring cups for the rear shocks, the front requires Traxxas else you can't get the preload correct, and the ride height is +5 or more too tall.
CraigMBA is offline
Old 01-14-2012 | 09:43 PM
  #9005
CoyoteSlash's Avatar
Mine is set up just like Craig's. I haven't gotten to the Track because I was locking down a steering tierod end, and I snapped the whole arm off. SO pissed.
CoyoteSlash is offline
Old 01-15-2012 | 09:45 AM
  #9006
suprdave's Avatar
Needing a little insight and help. My son has a sc10rs and while I can drive it decently he is having a really hard time with its handling. Seems too on edge especially corners. It heels way over and he ends up over-steering and then over correcting it. I have driven it back to back with a ft and my sc-r. Both trucks simply out handle his truck.
I'm toying with the idea of either giving him my kyosho and buying myself a new one, giving him my kyosho and getting myself a 22T, or trying to turn his truck into a ft.
I've tried up'ing the springs rates, thicker oil, more limiters, less steering EPA. Would simply putting some ft shocks and or ft arms front and rear take the looseness out of his truck?
suprdave is online now
Old 01-15-2012 | 10:00 AM
  #9007
If it's set up the same as the factory team version, it should handle the same. If it doesn't, there's something different about it. Maybe the differential? The ft shocks are simply easier to build and adjust, they don't perform any different. FT arms... are those the carbon ones? Pretty sure you won't see a difference in those either.
Wildewinds is offline
Old 01-15-2012 | 10:27 AM
  #9008
1Fastpede's Avatar
wow. umm I'm slipping like crazy. won't even wheelie(barely picks tires up on table) when it is locked down and I even tried HT pads. 8.5 20/87
1Fastpede is offline
Old 01-15-2012 | 10:43 AM
  #9009
Wild Cherry's Avatar
Set the slipper so the ft end only barely raises , less then a 1 inch.
Wild Cherry is offline
Old 01-15-2012 | 11:46 AM
  #9010
Mine seems to work pretty well.
I'd make sure it has the same setup as the FT. Same holes for all the dampers and stuff, same springs and ride height and all that sort of stuff. Then I'd rebuild the dampers with whatever you have in your FT. What about tires? Same tires? Any control arms binding? Anything broken (chassis cracked)?
M1Combat is offline
Old 01-15-2012 | 11:53 AM
  #9011
drhodes1989's Avatar
I'll assume you've taken the tire issue out of the equation (right tire for the track), have you tried adding weight to the rear or adding rear toe (either through the rear hubs or center toe block)? Have you tried adjusting the roll center with the shims under the ball studs?
Just a few ideas, hope that helps.
drhodes1989 is offline
Old 01-15-2012 | 11:58 AM
  #9012
JEFFs SC10's Avatar
I would check camber link locations and where shocks are mounted first. If hes running on those stock hard front tires that could be a big difference.
JEFFs SC10 is offline
Old 01-15-2012 | 12:08 PM
  #9013
Check out Sc10 set-ups on www.Rc10.com
pick out a set-up that fits your track conditions best...
You could try springs & oil , ect your self but advise to use the Team set-up as your best starting base before all that ...
Old 01-15-2012 | 02:05 PM
  #9014
MarqueeRc's Avatar
Originally Posted by CraigMBA
You can order this:
http://www.losi.com/Products/Feature...rodId=LOSB2903
Keep the spring buckets, and toss out the rest. You need to massage the springs over the buckets, but they stay centered on the shock and don't drag as much.
Hey Craig, I had that shock rebuild kit from for my Losi Highroller laying around and decided to try a bucket out and see if it eliminated the spring rub.
It didnt seem to seat the spring properly allowing the bucket to move/swivel easily, while constantly getting uncentered. If there is an impact or tumble it seems like the spring will move excessively, rendering them less effective.
Should I tighten or shorten up a bit the shock rod ends to add more pressure to the spring, possibly eleviating my issue? Did you run into a similar problem with the cups/buckets? I did read your previous post about making sure they are centered correctly, but do they move easily to your touch?
Thanks for any input in advance.
MarqueeRc is offline
Old 01-15-2012 | 02:53 PM
  #9015
nadan805's Avatar
Mee Too Please. it's so nasty.
nadan805 is offline
