B44.1 Thread
#1036
#1037
Ok, thanks so much for all your help man, you've been very helpful, and if this motor doesn't satisfy my speed needs I will get what you suggested, when you said your heart will race as fast as the car, well that's what I am looking for
Thanks and happy early new year!
Happy New Year.
#1038
they are quite fast even with 2 pole motors in it, 5.5 - 8.5 seems to be what most people run. i'd definitely be cautious with that torquey 4 pole motor, especially with the plastic diff and pinion gears this car has. make sure you adjust the slipper on the loose side
#1040
#1041
#1042
lipos doing 120 mph. But the 4 pole motor will have crazy torque in this little buggy. It sounds like a fun back yard basher for sure. Post a video on YouTube with the 4 pole I'm sure it would be funny to watch....!
#1045
My Viper system quit working in my B44 today so I put in a Castle Sidewinder ESC and a Castle 3800KV 4 pole to see how it would do. I like it better than the Viper 10R with Viper 6.5 motor. This thing is crazy quick now. There are to triple jumps on my backyard track that I couldn't clear with the Viper gear because of short run ups but I'm getting them now with the Castle combo. I think I'm going to get the Viper stuff fixed and sell it and keep the Castle combo in my B44. I think it's either the sensor wire or sensor board thats bad because the ESC wont sink with the motor now? Oh yeah the Castle stuff is staying a lot cooler also. The Viper ESC and motor would get pretty warm even in 50 degree temps.
#1046
does anyone have a problem with the bottom side of the rear transmission casing breaking?i noticed mine was cracked on both sides of the bottom rear screws. so i replaced them last night and after one heat tonight it was broke on both sides again... will it help if i boil the casing? does anyone have any tips on what i can do to stop this from happening every race.. thank you
#1047
#1048
thank you! I will double check the screws and the top deck. I race on a very tight technical track.. it is very hard to hit the backsides of each jump. A lot of air.. but have to use very little throttle if u want to hit them right... Everyone does a lot of flat landing.
1Likes
This is just a mess around and have fun buggy that needs to be silly fast.
