Like Tree1Likes
B44.1 Thread
Old 03-29-2012 | 10:31 PM
  #1786
fastchvy's Avatar
Originally Posted by OptimumRC
I would imagine about the same as the AE ceramic diff balls.
Ceramics are not standard in the kit though right?
fastchvy is offline
Old 03-29-2012 | 10:32 PM
  #1787
Originally Posted by forcewave
How do I tighten down my slipper while it is installed on the car? It appears to have a slot to hold the slipper nut in one location while you spin the gear but I am not really sure which direction to spin it or if I need to loosen the motor first etc.
Put an allen wrench through the top of the chassis into the slipper nuts hole, face the buggy away from you and grab the rear wheels.. Rotate the wheels forward to tighten the slipper, the other way to loosen.
Rotax125 is offline
Old 03-29-2012 | 10:45 PM
  #1788
OptimumRC's Avatar
Correct, carbides come in the kit AE#6581 and the ceramics are AE# 6584.
OptimumRC is offline
Old 03-29-2012 | 10:48 PM
  #1789
fastchvy's Avatar
Are the ceramics better? Do you run them?
fastchvy is offline
Old 03-29-2012 | 11:04 PM
  #1790
OptimumRC's Avatar
Yes I personally run them, and they are great! They are a little bit more money but because of the increased hardness of the ceramic balls you can go several diff rebuilds without having to replace them. Since they are significantly harder than the diff rings the only way they can get ruined is if steel from the diff ring is deposited and stuck on the diff ball. This only occurs if the diff barks (slips a lot) and allows the steel to get hot enough to stick to the ball. This issue is worse with a carbide ball and way worse with just a steel ball.
Old 03-30-2012 | 06:22 AM
  #1791
Default mip real shocks
just curious if anyone has used the mip realshocks bypass 1 kit in their 44.1. Ide like to hear. how the proform and what ways you placed the little shims. I have bought a set and am curious as to what people think about them.
Thanks,
klops
klopsided6r is offline
Old 03-30-2012 | 10:17 PM
  #1792
Mini8 Menace's Avatar
Default whats a good servo to run
whats a good servo to run i have the savox 1258-tg and is docent fit correctly not sure how to fit it exactly just wondering how to mount it right or if there is a better servo to run???
Mini8 Menace is offline
Old 03-30-2012 | 10:56 PM
  #1793
For those of you running kyosho big bore shocks, what springs are you running. Switching to big bores and was looking for a little help and direction. What oils and pistons are you running?
htrd03 is offline
Old 03-31-2012 | 12:14 PM
  #1794
which is better steel pinion or aluminum pinion for a 6.5 motor and which brand is best?
TheHillsPancake is offline
Old 03-31-2012 | 12:30 PM
  #1795
Default savox 1258-tg how to fit
i just purchased the savox 1258-tg any suggestions on how to fit it correctly or should i go with another servo???? do i cut the strengthening tabs on the front of the servo tabs and put the mounts in the front any tips or suggestions
Old 03-31-2012 | 02:35 PM
  #1796
Suspended
What gearing are most of you running? I'm going to be running on mostly indoor hard packed clay. It's a pretty technical track and I'll be using a 9.5turn motor.
With the stock spur what size pinions should I keep handy?
I will also be running some on my own backyard track pictured below. In these pics I hadn't finished running all the pipe but you get the idea of the size of it:
MattP is offline
Old 03-31-2012 | 03:36 PM
  #1797
Default what servo are you guys running
i have a savox 1258-tg and it doesn't fit its like a couple mils to long the steering rack rubs any suggestions on a servo that will fit looking for between 150 to 200 tq preferably somewhere in between
Old 03-31-2012 | 03:39 PM
  #1798
fastchvy's Avatar
I run the hitec 7940
fastchvy is offline
Old 03-31-2012 | 03:45 PM
  #1799
Thanks,
klops
I've been running them for a month now. I only have 3 official race nights (2 qaulies and a main per night) on them and they are performing really well. Buggy hooks up on large sweepers holding the inside line. Can't really see a big advantage on the jumps. My set up is in the rebound (reverse) position using the 3/4/5 valves. I have the option valves but have not installed them yet.
TeamOSG is offline
Old 03-31-2012 | 04:25 PM
  #1800
Default how do you like it
how is it and where did you buy it at cause i could only find them at RCplanet for 150 anywhere cheaper???
