MTX 5
#1533
#1535
For those of you who uses LiPo batteries on the MTX5.... can you please explain me where do you put the regulator?
If you can post some photos or so...
Wanna know if you put it on the left or right on the car... and which is the best place to keep it safe from fast (wet) refueling.
Thank you
and wish you to enjoy this days
Thank you
#1536
Thank you
Thank you
#1537
Thank you
Thank you
I am running my regulator in the reciever box, i am using the one from xceed, it is a tight squeeze but keeps everything very neat.
#1538
Pass you soon...
#1540
we have just instaled brace 2 get rid of bent plate after some mods 2 stop brakes draging ptate is dead flat now used 1/8 stering arm grandson sead it still handels good at brendale was bent about 3mm at each end will have get new one when all the shit stops
#1541
Carbon chassis plates make the car lighter, can be made very strong and completely eliminate chassis tweak. But unfortunately; they reduce weight at the lowest point; where most of the weight should be located to lower CG. They also don't dissipate heat from engines like aluminium chassis plates are designed to do.
That’s why manufacturers of gas cars don’t use them; it’s not to make money from replacing bent chassis plates. Some manufacturers use little flex with very strong chassis plates that are very hard to twist; but Mugen chooses to go for heaps of flex.
Kindest regards,
Lars.
Kindest regards,
Lars.
#1545
Hi
I had my MTX5 out yesterday at Sunny Coast with my brother. It has lost drive and engine just free revs, it sounds like one way bearing in 2 speed to me.... But wasn't sure what effect the diffs stripping had, can someone elaborate for me?
Thanks in advance
Andrew
Thanks in advance
Andrew
