MTX 5
Old 12-28-2011 | 01:49 AM
  #1531
Originally Posted by Chickentrader
A car needs shiny red bulkheads to be fast.
Kindest regards,
Lars.
Obvioulsy you're still intoxicated from Christmas celebrations too.
CDS70 is offline
Old 12-28-2011 | 07:19 AM
  #1532
Now that's funny!!
30Tooth is offline
Old 12-28-2011 | 03:28 PM
  #1533
DS Motorsport's Avatar
A car needs shiny red bulkheads to be fast. (Composed with assistance of my Microsoft Word spell checker)
Kindest regards,
Lars.
Somewhere we all know that's the truth.
Very anxious to see if the shiny red bulkheads are the secret as mine are matt black.
DS Motorsport is offline
Old 12-29-2011 | 01:55 AM
  #1534
Chickentrader's Avatar
Who? Me?
Kindest regards,
Inebriated Lars - the drunk.
Chickentrader is offline
Old 12-30-2011 | 12:26 PM
  #1535
NikoRacing's Avatar
For those of you who uses LiPo batteries on the MTX5.... can you please explain me where do you put the regulator?
If you can post some photos or so...
Wanna know if you put it on the left or right on the car... and which is the best place to keep it safe from fast (wet) refueling.
Thank you
and wish you to enjoy this days
NikoRacing is offline
Old 12-30-2011 | 01:18 PM
  #1536
Seisick's Avatar
Thank you
saw a friend of mine put it on top of the receiver cover, then he switched to life so he took out the regulator, sorry no pic,
Seisick is offline
Old 12-30-2011 | 02:42 PM
  #1537
Jeff Hamon's Avatar
Thank you
Hi,
I am running my regulator in the reciever box, i am using the one from xceed, it is a tight squeeze but keeps everything very neat.
Jeff Hamon is offline
Old 12-30-2011 | 05:56 PM
  #1538
lil-bump's Avatar
Originally Posted by Jeff Hamon
Hi,
Some switching regulators are very noisy(electronic noise). I would not run a regulator so close to your receiver. I done this once; with a regulator and my throttle servo would frequently shut down. It never effected my steering servo. I removed the regulator from the receiver box and never had another problem. I was running a KO Eurus with the 409 receiver and a KO servo.
Pass you soon...
lil-bump is offline
Old 12-30-2011 | 06:46 PM
  #1539
Is there any better on using carbon chassis?
ioxqq is offline
Old 12-31-2011 | 01:41 AM
  #1540
Default mtx5 brace
we have just instaled brace 2 get rid of bent plate after some mods 2 stop brakes draging ptate is dead flat now used 1/8 stering arm grandson sead it still handels good at brendale was bent about 3mm at each end will have get new one when all the shit stops
greg.dawn is offline
Old 12-31-2011 | 01:28 PM
  #1541
Carbon chassis plates make the car lighter, can be made very strong and completely eliminate chassis tweak. But unfortunately; they reduce weight at the lowest point; where most of the weight should be located to lower CG. They also don't dissipate heat from engines like aluminium chassis plates are designed to do.
That’s why manufacturers of gas cars don’t use them; it’s not to make money from replacing bent chassis plates. Some manufacturers use little flex with very strong chassis plates that are very hard to twist; but Mugen chooses to go for heaps of flex.
Kindest regards,
Lars.
Old 01-03-2012 | 04:08 AM
  #1542
how big is the inside diameter of the shock body?? maybe can someone measure it?
SebO is offline
Old 01-03-2012 | 05:19 PM
  #1543
rcmike's Avatar
10 mm inside dia. hope that helps
rcmike is offline
Old 01-04-2012 | 12:56 AM
  #1544
thanks al lot
SebO is offline
Old 01-05-2012 | 09:26 PM
  #1545
Bundy_Bear's Avatar
Hi
I had my MTX5 out yesterday at Sunny Coast with my brother. It has lost drive and engine just free revs, it sounds like one way bearing in 2 speed to me.... But wasn't sure what effect the diffs stripping had, can someone elaborate for me?
Thanks in advance
Andrew
Bundy_Bear is offline
