MTX 5
#1516
dpes anyone have a link to an aftermarket manufacturer of brake pads for the MTX5? i find mine to not have enough bite even with maximum movement of the servo horn. Because i have to dial my radio up so high i find the rear pod of the chassis bends a lot.
even when i push the brake level with my hand, i can still turn the pulley from the belt side...not enough bite
PS: i just found these brake pads on the pro shop futaba site, deos anyone know if they have more bite than the standard pads?
http://translate.googleusercontent.c...VYAi7NH8iHgF3w
anyone?
#1517
[QUOTE=TomB;10055745]dpes anyone have a link to an aftermarket manufacturer of brake pads for the MTX5? i find mine to not have enough bite even with maximum movement of the servo horn. Because i have to dial my radio up so high i find the rear pod of the chassis bends a lot.
tom, the optional brake from mugen has been released, costs more but according to mugen the brake is more progressive and less prone to experience fade on long mains.
if you have a strong gas servo, id drill a lower hole on the brake arm so not to have too much leverage therefore flex,
like many people i sanded the brakes when new, and came alive after one liter of fuel
good luck
good luck
#1519
#1520
In regards on bearings there's an ten items package at better price than if getting two similar to eht 10x15 package
I dindnt like the philips so its a nice one and now longer so to prevent stripping on the cases
#1521
The diff and pulley screws are phillips, now here's an uptaded version to make them allen
#1522
#1523
Hello to eveyone.
I am just building my new MTX5 , and do you have any suggestions that i should watch? i build my diffs with the xray 0.3 washers in both the diffs and both the crown gears.They seem a litle tight, not to much and i think they need a litle running in and they will be fine. Should i pay attention to anything else?
Thank you in advance for all your replies!!
#1524
Hello to eveyone.
also, when installing the carriers to the spur gears, heat up the spur with a hair dryer or in an oven at 80 degrees. by heating the gears you avoid the screws warping the gears when you screw them in.
#1526
#1527
#1530
