MTX 5
#1546
Kindest regards,
Lars.
#1547
Lars
It seems like it is the one way... takes quite a bit of throttle to get the mid shaft to spin up.
I had a slipping bearing in my V1R and G4S and both times i have tried cleaning them and applying new oil to no avail. I am just going to order a replacement bearing...
Has anyone else had any issues with the bearing as yet?
Andrew
#1548
Lars
Andrew
Andrew
I think it's just bad luck at times.
Kindest regards,
Lars.
#1550
Hello today I was finally able to test the car thoroughly, all day and no problem of coronation, the car as best I went to my style of pilotage was with the xray springs, so if you notice is that the tour Centax defectuozamente, the dismantle and mushroom does not turn straight, it makes an oval and sprockets are strangers to him happened to others a alguien.Por 10 very happy with the
#1553
Extract from Hudy Set-up book:
Effects of Spring Selection
Stiffer
springs
Makes the car more responsive.
Car reacts faster to steering inputs.
Stiff springs are suited for tight, high-traction tracks that aren’t too bumpy.
Usually when you stiffen all of the springs, you lose a small amount of
steering, and reduce chassis roll.
Softer
springs
Makes the car feel as if it has a little more traction in low grip conditions.
Better for bumpy and very large and open tracks.
Springs that are too soft make the car feel sluggish and slow, allowing
more chassis roll.
Stiffer
front
springs
Makes the car more stable, but with less front traction and less steering.
Car will be harder to get the car to turn.
Turning radius increases.
Car will have much less steering at corner exit.
Very stiff springs are preferred on very high-grip tracks, or if the track
itself feels tacky or sticky.
Softer
front
springs
Makes the car have more steering, especially mid-corner and at corner exit.
Front springs that are too soft can make the car oversteer (lose rear grip).
Stiffer
rear
springs
Makes the car have less rear traction, but more steering mid-corner
and at corner exit. This is especially apparent in long, high-speed
corners.
Softer
rear
springs
Makes the car have more rear side traction mid corner, through
bumpy sections, and while accelerating (forward traction).
Softer spring are often used to increase grip; but funny enough, stiffer springs can at times can actually give better grip. You will always have to test to find the ideal set-up, the top drivers employed by manufacturers always do. Springs are quick to change so if you're not sure; test by using medium stiff springs first, and then change to hard or soft to test which works best. Only trouble with it is that damping should also be changed to suit springs.
Kindest regards,
Lars.
Stiffer
springs
Softer
springs
more chassis roll.
Stiffer
front
springs
Softer
front
springs
Stiffer
rear
springs
corners.
Softer
rear
springs
Kindest regards,
Lars.
#1554
#1555
#1557
Hi, in my centax, I have the same problem. The soluction is buy another one "End Bit" ?Itīs a problem of the first kistīs?
#1558
It appears like Mugen's engineering contractor has drilled the very deep holes after turning the shaft; instead of turning the shaft out from the center of a hole that was drilled first. Ridicilous it seems; and quiet basic which any engineer should have known.
Kindest regards,
Lars.
