Old 07-24-2012, 12:52 AM   #2266
i hope this one is better than last after market one i tried if some has one better than mugen i will by it i bent old aftermarket in about 3 tanks gen/one lasted a lot longer
greg.dawn is offline   Reply With Quote
Old 07-24-2012, 01:57 AM   #2267
rc-goods's Avatar
Manufacturer has conducted multiple simulations, and from official website, message shown as below:
"Integrating various trial-proven features, our flex controller system strengthens chassis pliability. Rigid chassis frames can safely hold the engine in an accurate position and serve as a great prevention against the many common issues caused by frame movements. Now you can enjoy the thrills of racing without worrying about thread damages in gear box, contact fracture, pressing crack and more. "
For more useful information, you may go to official site
Source: http://www.evo-workshop.com
rc-goods is offline   Reply With Quote
Old 07-24-2012, 05:33 AM   #2268
Bishop's Avatar
Very interesting chassis, though I'm not convinced about what their site says about a stiffer chassis making more grip, but for other reasons I kind of like the design tweaks.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 07-28-2012, 07:03 PM   #2269
NITTO550's Avatar
Anyone knows how much this car weighs stock.?
There are only two ways to do things. The wrong way or my way!
Rich D..
~Mugen Seiki Racing MTX-6 ~,
Novarossi racing Engines ~Ko Propo, ~Avid Bearings..
VBC Racing Wildfire D07 ~LRP Electronics ~ Fantom Racing
NITTO550 is offline   Reply With Quote
Old 07-28-2012, 10:42 PM   #2270
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
more than a MTX4
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 07-29-2012, 02:31 AM   #2271
you will have to go to a weigh bridge baileys is 1850 with light shell you nead life/small servos and it will be under
Old 07-29-2012, 05:12 AM   #2272
Bishop's Avatar
1650g with a 1450mah LiFe and modern servos, that is with no effort to be light, although I don't run the carbon wheel things, which add in some weight.
Last I checked, my car was bang on the current AARCMCC regulating using two larger Mugen weights on the chassis weight holes, if I used a light weight shell or put any lighter parts on mine, I'd have to add more weight somewhere.
QRCCRA
www.qrccra.org.au
Old 07-29-2012, 05:51 AM   #2273
NITTO550's Avatar
And 1650 was with the composite diff gears or steel gears?
Thanks in advance.
Rich D..
Old 07-29-2012, 06:29 AM   #2274
Bishop's Avatar
Thanks in advance.
Probably with steel rear and plastic front, which is what I'm running now, I think it was 1620 or so at one point, and I could get it to a run weight of 1600 flat without that much trouble.
Actually I think even right now I likely need just a little more weight, get the feeling I'd fail a check if I ran my tyres down low enough.
QRCCRA
www.qrccra.org.au
Old 07-29-2012, 06:33 AM   #2275
NITTO550's Avatar
I also find myself fighting the car because the rear tends to be a little loose with a p37 shell , anybody using something different and does it keep the rear planted?
Rich D..
Old 07-29-2012, 07:01 AM   #2276
Bishop's Avatar
P37 is quite balanced, if anything I still often struggle with finding turn on my five, but not usually any issues with the back end, they are saying the new SRSN has more 'turn' and back end.
I think in our state champs just held this weekend, the SRSN was the most used body in the event.
QRCCRA
www.qrccra.org.au
Old 07-29-2012, 07:10 AM   #2277
NITTO550's Avatar
My five is the complete opposite, excellent turn in and corner speed. 1 toe out works well. Or try a softer spring in front, or lay the stock shock down one position.
Rich D..
Old 07-29-2012, 07:12 AM   #2278
NITTO550's Avatar
I tried a friends srs shell, didnt care for it too much, mabey ill give it another shot.
Rich D..
Old 07-30-2012, 02:45 AM   #2279
after the QLD TITLES it was nealey under the mower but he finished 8 in final after 2 second gear changes finished 2 good heats/and afinal after 4 days of playing
Old 07-30-2012, 05:47 PM   #2280
afm
afm's Avatar
Default SPUR BREAKING
Any news on Mugen adressing the spur breaking issue officially? I read somewhere that for the European championship they would release an improved version off gearbox/clutch/spurs.
Ive tried every tip, building process, recomendation, et.etc. and can't have a running stream larger than 15 minutes before spurs go.....BTW i'm no novice in this hobby and in my 12 years in it, i've had all the major brands of cars, and never seen something like this..
AFM
afm is offline   Reply With Quote
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 01:16 PM
Mugen MTX-4 Grasshopperr Nitro On-Road 9087 08-30-2011 07:15 PM
Singapore National Series, 2009 Round 2 bullygod Singapore R/C Racers 21 06-27-2009 07:00 AM
Inter-State Racing Competetion Mie3R Malaysian R/C Racers 510 08-12-2008 10:41 PM
INTI College 1/10 Gas Touring (Sarawak,Kuching) LAKIA Malaysian R/C Racers 41 10-18-2007 06:46 PM
TQ With Serpent 720 on 23 & 24 December 2006 in Miri weechor Malaysian R/C Racers 119 02-01-2007 07:04 AM
LRP Nitro Masters 2006 Malaysia HPC II Malaysian R/C Racers 435 06-28-2006 09:03 AM
