Old 11-06-2011, 10:32 PM   #1366
PinoyCali's Avatar
Originally Posted by Bishop View Post
During first setup of the car, or after you have run it?.
Cause when you first build the car it's got no brakes no matter what you do, the pads etc need to be run in, takes at least a couple of heats, mine were biting well towards the end of it's first meeting.
During first set up an 4-5 tanks of nitro.
PinoyCali is offline   Reply With Quote
Old 11-06-2011, 11:11 PM   #1367
Bishop's Avatar
It was towards the end of my first meet that mine were biting well, and I did a small session of just hard stops to bed mine in, did you clean all the parts down with meths as well?, my disk was covered in oil out of the packet, which will likely either contaminate the pads or slow down the bed in.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 11-07-2011, 12:11 AM   #1368
asw7576's Avatar
Originally Posted by PinoyCali View Post
Hello guys,
Is this normal when u braking?
I adjusted the epa down up to no chassis flex but no brakes.
What em I doing wrong?
Thanks,
1. Open air filter, ..... you need to see the carburator air opening position during neutral and full throttle.
2. check and re-adjust throttle linkage during this position : full throttle, neutral, full brake. ( use your common sense )
3. check and re-adjust brake linkage during this position : full throttle, neutral, full brake.
4. check and re-adjust EPA through your transmitter.
Old 11-07-2011, 07:49 PM   #1369
Suspended
Thumbs up
http://www.rctech.net/forum/r-c-item...ugen-mtx5.html
King Nitro is offline   Reply With Quote
Old 11-08-2011, 06:45 AM   #1370
RC MARKET's Avatar
New Option Parts
RC MARKET is offline   Reply With Quote
Old 11-09-2011, 01:05 AM   #1371
jaykay's Avatar
Well, i have had 2 races and in booth races in the final run the diff has been broken. i hope that the new diff parts will arrive soon. but was i also noticed, that the car has always a little bit understeer on throttle. have you mentioned it also?
jaykay is offline   Reply With Quote
Old 11-09-2011, 03:39 AM   #1372
postopitcrew's Avatar
1.what type colour of spring that you using?
2.type of number for diff oil and shock oil ?
3.how much toe in at rear?
4.did you using the accelerator function on your remote?
just want to know..my car are very stable right now..when i throttle don't have any understeer on my car..hope i can help you soon..
best regds..
```````* NOVA + RB + O.S *```````
**MTX4R*MTX5*NT1*RX8*2.4 FASSTs**
*** GERMAN TANKER***
postopitcrew is offline   Reply With Quote
Old 11-09-2011, 04:31 AM   #1373
nikoskar's Avatar
What you mean? EXP?
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 11-09-2011, 07:44 AM   #1374
Originally Posted by nikoskar View Post
What you mean? EXP?
if you are using futaba 4pk controller,you have the accelerator functions,means that if you pull the trigger to some point,you can open the air intake (curberator) of your engine more faster,that's depend to your setting,more higher you set,more faster it's open..i don't know about other controller..maybe EXP is the same things with futaba..what i notice is EXP stands for throttle expose if i don't mistaken....if you set to high your car become unstable while exit from corners..other wise it's depend to your driving style for sure....this is just my opinion..
best regds.
Old 11-09-2011, 07:49 AM   #1375
Seisick's Avatar
perhaps 2 additionals 5x15x0.1 shim next time will help as it has with some racers
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 11-10-2011, 07:13 AM   #1376
jaykay's Avatar
best regds..
I used the standard springs, with 500 oil, 3 degree toe in in the rear and i have no accelerator function.
i also tried softer springs in the front, but the effect was not much better. i also changed the front roll-center but was not really better.
diff oil i used 200.000 front, 80.000 rear
Old 11-10-2011, 05:51 PM   #1377
rmdhawaii's Avatar
Wassup guys!
Plastic diff gears? ftw! That's what happens when Swauger isn't testing for Mugen. I bet he could shred those in one tank!
Not enough turn in? What body are you guys running?
Just remember...
The pros don't have problems like some of us mere mortals. They can easily identify and work around any issues on a new car and make it perform. What we see as a design/manufacturing flaw is nothing more than a minor inconvinience for the pros. They see it, fix it (by any means necessary) and the problem disappears. We end up struggling with it and eventually one of us figures it out - or a pro takes pitty on us and gives us the fix.
It's too bad that nitro has declined as much as it has in the U.S. I miss the "old crew" that did all the grunt work to figure things out make our lives easier.
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 11-10-2011, 05:56 PM   #1378
DS Motorsport's Avatar
Try reducing the front droop, i.e. go from 1 to 2mm downstops.
Softer front springs won't change a lot on on throttle understeer.
If the track is smooth enough you can also try harder rear springs or a stiffer rear anti roll bar.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 11-10-2011, 11:50 PM   #1379
ok..my suggestion you should try this setting;
1.use all 1.6 purple spring front and rear
2.use 400-450 shock oil
3.try two hole shock piston in front suspension (same with the rear)
4.make 1.5mm down stop at front,the rear is 0mm which is like free play
5.front roll bar make it flat to end
6.upper arm position is all down,if your car have a little bit shaky,change to center hole.
7.all purple spring make sure it's free roll(you can play cw and ccw) means not to tied end to end
8.rear toe is ok for 3 degree in,but your car become slow in high speed line,better in and out tied corner.front toe try 1.5 out
your diff is ok if your are aggressive driving style.
best regds.
Old 11-11-2011, 03:40 AM   #1380
rave1010hk's Avatar
Originally Posted by NikoRacing View Post
anyone knows? Thanks again
2.0mm
MUGEN MTX5、MTX4-R、NR FLASH 12.PTS/MRX5、NR FLASH 21.PTS/MBX6、NR BONITO 21-7XLBS/SPP 966、733、811、411、120、120L、240、100/TAMIYA 417、F104X1、M05/XRAY RX8、T3/FUTABA 4PKS
rave1010hk is offline   Reply With Quote
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 01:16 PM
Mugen MTX-4 Grasshopperr Nitro On-Road 9087 08-30-2011 07:15 PM
Singapore National Series, 2009 Round 2 bullygod Singapore R/C Racers 21 06-27-2009 07:00 AM
Inter-State Racing Competetion Mie3R Malaysian R/C Racers 510 08-12-2008 10:41 PM
INTI College 1/10 Gas Touring (Sarawak,Kuching) LAKIA Malaysian R/C Racers 41 10-18-2007 06:46 PM
TQ With Serpent 720 on 23 & 24 December 2006 in Miri weechor Malaysian R/C Racers 119 02-01-2007 07:04 AM
LRP Nitro Masters 2006 Malaysia HPC II Malaysian R/C Racers 435 06-28-2006 09:03 AM
