Like Tree31Likes
Futaba 4PX
Old 01-28-2020 | 11:18 PM
  #2371
Roelof's Avatar
Originally Posted by rbc626
HI, can anyone confirm if you can do this in with 4PX? I just bought a Futaba S9373 SErvo. Can you program that servo with 4PX?
thanks!
Did you ever read the manual??????
http://manuals.hobbico.com/fut/4px-manual.pdf
page 126
Roelof is offline
Old 01-29-2020 | 11:36 PM
  #2372
page 126
thanks for the reply, Yes I read the manual, I saw that it does, but I was not sure if the 4PX will do the S9373. Can you just connect it directly or do you need to connect it with a hub and in parallel with a 6.6Life battery?
rbc626 is offline
Old 01-30-2020 | 01:07 AM
  #2373
Roelof's Avatar
As the manual states you will not have all options through the transmitter but it seems to me that all basic options are available with all servo's
If a battery is needed I do not think so, just give it a try.
Roelof is offline
Old 04-16-2020 | 02:53 PM
  #2374
2056dennis's Avatar
hi guys ive got a 4px radio and it is now starting to twitch when I turn the wheel is there a fix for it thanks for any info
2056dennis is offline
Old 04-16-2020 | 04:15 PM
  #2375
Joel Lagace's Avatar
I removed the steering wheel down as far as i could down to the steering pot.. hit with compressed air can, electronics cleaner and compressed air to make 100% it was clear and dry.
Been working perfectly since that..
Joel Lagace is offline
Old 04-16-2020 | 05:00 PM
  #2376
2056dennis's Avatar
I love the radio and I race in doors mostly , but I will give it a try thanks for that info
Old 04-29-2020 | 07:08 PM
  #2377
Default Button issue
Not sure how to fix this. Every time I turn on radio the aux 3 goes all the way to -100 and sounds alarm. I diagnosed that the Dt3 button by the wheel is the issue. The button will only move one direction, I can get it to go back to zero by pushing the button and alarm stops, but every time radio is turned off then on it does it. I took wheel off, but can’t figure out how to take the wheel unit apart to get to the buttons. So I guess my question is there a way to get inside of the wheel unit without breaking it to see if something is wrong with the button?
Also is there anywhere to get the outside plastic screen? Futaba said that they don’t sell it and has to be sent in for repair for $35 plus shipping of course. Really scratched up from previous owner.
CoryRC is offline
Old 05-06-2020 | 05:56 PM
  #2378
Anyone.
CoryRC is offline
Old 11-06-2020 | 10:45 AM
  #2379
Anyone know where I could find an Imbue carbon drop down brace for a 4PX?
penning4544 is offline
Old 11-06-2020 | 12:45 PM
  #2380
Roelof's Avatar
https://www.ebay.ie/itm/Futaba-4PX-C...740?nav=SEARCH
Roelof is offline
Old 11-06-2020 | 01:27 PM
  #2381
the link didn't work
Old 06-19-2021 | 05:39 PM
  #2382
1/8 IC Fan's Avatar
Bumping it up, replaced my receiver pack with a Trinity Graphene 7.4V and now all of a sudden the Servos are twitching like crazy...
Running a R304SB receiver and 2 ea. S9532HV servos... never had this issue ever before when running a NiMh pack... everything should be good. Radio reads the receiver just fine, just now its acting weird. Looked through the specs and the Servos and Receiver should be good with 7.4V.
Any insights?
1/8 IC Fan is offline
Old 06-19-2021 | 06:31 PM
  #2383
TOADYY's Avatar
Any insights?
Did you change the battery type on the 4PX? If the Trinity is a LiFE battery type you must change the setting from NiMH to LiFE. Page 148 of the manual.
1/8 IC Fan likes this.
TOADYY is online now
Old 06-20-2021 | 05:39 AM
  #2384
1/8 IC Fan's Avatar
TOADYY, yeah i had done that, as well as played with the faiösafe settings, but the servos are still acting the same. I think I will switch back to a 6V Nimh and see what Futaba support (Japan) has to say.
Old 07-05-2021 | 03:47 AM
  #2385
Default Futaba 4PX Signal lost or freeze problem
Greetings to all of you, I've been using 4px since its first release, and I love it. But I have a big problem, 4PX completely froze in a race 2 separate times, the whole screen was on but none of the buttons were working and of course the vehicle was damaged. It repeated this again the following year. The only solution is to remove and reinsert the battery. This seems at least once a year It does this only in 1 track in our country, there is no problem any other buggy and in-door onroad tracks other than that, I race every 2 weeks continuously, only this track can cause problems
However today, in race wanted to cut off speed and enter the corner while driving at full throttle with my 1/10 nitro car on the same track, but for a moment loss of signal and caused my car to hit the pit wall at full throttle, costing me 300 €, Interestingly, there was no problem after the accident and all the servos were working. So I can't trust my 4PX anymore. It is not clear when it will do that again.
Likewise, one of my friend said that he had a signal loss in 1/10 EP Car class today too
Software Version is 1,4E
Any solution or ideas are well come
Alentino is offline
